RogerNg_185295 6th Gear October 10, 2018 Share October 10, 2018 Makes me wonder how much these people earn per month ? The point value of fuel saved is not worth the issues of putting to neutral bros.. If fuel costs are really that large an issue, there are other modes of transport.. ↡ Advertisement Link to post Share on other sites More sharing options...
SkimMilk 3rd Gear October 10, 2018 Share October 10, 2018 I think frequent shifting of gears would obviously wear out the gearbox components faster than if you don’t do it. This includes but is not limited to shifting from D to N when stopped at traffic lights. So, naturally the advice is not to do that unless necessary, if you intend to keep the car for a long long time. I've seen a few taxis setting to P mode (cos when they switch to D, can see reverse gear kick in) at red lights. Makes me wonder why they do that? Link to post Share on other sites More sharing options...
Joelwong 2nd Gear October 10, 2018 Share October 10, 2018 I've seen a few taxis setting to P mode (cos when they switch to D, can see reverse gear kick in) at red lights. Makes me wonder why they do that? Set to P leg can relax Link to post Share on other sites More sharing options...
13177 Supersonic October 10, 2018 Share October 10, 2018 I've seen a few taxis setting to P mode (cos when they switch to D, can see reverse gear kick in) at red lights. Makes me wonder why they do that? It is a habit for taxi drivers to shift from D to N or P at red lights and when car stops. Sometimes when i sit in their taxi, the continuously of shifting of the gear really irritating. Lol. Link to post Share on other sites More sharing options...
yishunite Turbocharged October 10, 2018 Share October 10, 2018 It is a habit for taxi drivers to shift from D to N or P at red lights and when car stops. Sometimes when i sit in their taxi, the continuously of shifting of the gear really irritating. Lol. My father is like this 1. He so loong drive manual car when switch to auto 10 yrs ago habit remain... left hand itchy at stoplight Link to post Share on other sites More sharing options...
adrianty 1st Gear October 10, 2018 Share October 10, 2018 If want to rest leg and don't want to spoilt gear box easily, remain as D and pull handbrake? Link to post Share on other sites More sharing options...
Sktan10 5th Gear October 10, 2018 Share October 10, 2018 I've seen a few taxis setting to P mode (cos when they switch to D, can see reverse gear kick in) at red lights. Makes me wonder why they do that? Not my taxi.lol..... Link to post Share on other sites More sharing options...
walkofwinners 4th Gear October 10, 2018 Share October 10, 2018 If want to rest leg and don't want to spoilt gear box easily, remain as D and pull handbrake? put at D and pull handbrake, your car will still roll la bro. try to drive ur car with handbrake up at D, your car still moves. Link to post Share on other sites More sharing options...
SkimMilk 3rd Gear October 10, 2018 Share October 10, 2018 (edited) Set to P leg can relax I mean, why P? N enough liao what... It's quite scary to see the reverse lights light up when you are "stuck". Edited October 10, 2018 by SkimMilk Link to post Share on other sites More sharing options...
Joelwong 2nd Gear October 10, 2018 Share October 10, 2018 I mean, why P? N enough liao what... It's quite scary to see the reverse lights light up when you are "stuck". N how to legs off if ground is not level Link to post Share on other sites More sharing options...
Ceecookie 5th Gear October 10, 2018 Share October 10, 2018 Set to P leg can relaxActually there's Auto Hold feature for that. Not available on the elantra, but it will hold the parking brake in D while ur leg is free to relax without having to step on brake Link to post Share on other sites More sharing options...
SkimMilk 3rd Gear October 10, 2018 Share October 10, 2018 (edited) N how to legs off if ground is not level N and hand brake like manual car? Doesn't P have a pin that may be broken if handbrake is not applied? Edited October 10, 2018 by SkimMilk Link to post Share on other sites More sharing options...
Joelwong 2nd Gear October 10, 2018 Share October 10, 2018 N and hand brake like manual car? Doesn't P have a pin that may be broken if handbrake is not applied? Pin break when u yank the P to S by force Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 10, 2018 Share October 10, 2018 I mean, why P? N enough liao what... It's quite scary to see the reverse lights light up when you are "stuck". Coz someone mentioned put at N will wear down your shift cable and clutch band. Putting at P will be like normal parking mode, I suppose. Link to post Share on other sites More sharing options...
13177 Supersonic October 10, 2018 Share October 10, 2018 Coz someone mentioned put at N will wear down your shift cable and clutch band. Putting at P will be like normal parking mode, I suppose. If it is really the case, then why is the point of having the N gear le? Lol. Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 10, 2018 Share October 10, 2018 The point value of fuel saved is not worth the issues of putting to neutral bros.. If fuel costs are really that large an issue, there are other modes of transport.. I dun think it's bcos of fuel saved issue. I dun even know can save fuel using this method. It's more of habit and/or relaxing the leg. If it is really the case, then why is the point of having the N gear le? Lol. I also wondering Link to post Share on other sites More sharing options...
yapjx100 1st Gear October 10, 2018 Share October 10, 2018 If it is really the case, then why is the point of having the N gear le? Lol.Google will tell you a few reasons, for example: https://carfromjapan.com/article/driving-tips/use-neutral-gear-automatic-transmission-car/ Link to post Share on other sites More sharing options...
Johnnylim 5th Gear October 10, 2018 Share October 10, 2018 Google will tell you a few reasons, for example: https://carfromjapan.com/article/driving-tips/use-neutral-gear-automatic-transmission-car/ Thks for the info. Key word for me: doing it frequently for a long time could damage the torque converter. So between perhaps having to change blown brake lights more frequently n cannot rest leg vs damaging the torque converter, I think I'll choose the former bah ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota GR Corolla
2018 Toyota Supra
2018 Toyota Supra
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
2018 Kia Cerato K3 / Forte (BD Series) + 2021 Facelift
[Official] 2023 2nd Generation Hyundai Kona
[Seek experts' views] Pioneer Z9250BT vs stock HU
