Alpha 2nd Gear December 19, 2018 Share December 19, 2018 Is it normal to hear deep creaky sound from rear suspension when the passengers and drivers starts to disembark from the car when the car is put to P? Kia K3 seems to have similar issue which is normal, not sure about elantra???So far no for me. Passengers weight all below 80KG each ↡ Advertisement Link to post Share on other sites More sharing options...
Alpha 2nd Gear December 19, 2018 Share December 19, 2018 an update for my fc... due to holiday season. car on the road is less than usual. i am able to clock ard 15km/l on meter for 75% highway. the usual route i had before holiday season is 13.5km/l how you all manage such good FC? Remove unnecessary items from car? Tyre pressure optimal? Good petrol? Advice please. mine is 8.8L/100km Link to post Share on other sites More sharing options...
Sirjimmy 1st Gear December 19, 2018 Share December 19, 2018 My elantra ac totally die on me, blowing out hot air... Called komoco, the lady tell me wait till jan 2nd. Wonderful, leaving no choice but go outside servicing. Any1 have lobang for elantra ac in the west? 2 Link to post Share on other sites More sharing options...
Simpleonly 5th Gear December 19, 2018 Share December 19, 2018 My elantra ac totally die on me, blowing out hot air... Called komoco, the lady tell me wait till jan 2nd. Wonderful, leaving no choice but go outside servicing. Any1 have lobang for elantra ac in the west? How old is your elantra? If under warranty, they can ask u to wait till Jan 1 Meh? Link to post Share on other sites More sharing options...
Sirjimmy 1st Gear December 19, 2018 Share December 19, 2018 How old is your elantra? If under warranty, they can ask u to wait till Jan 1 Meh? 2 years old, under warranty, and yes, tell me earliest is 2nd jan. But she did tell me to try my luck to walk in... Link to post Share on other sites More sharing options...
Simpleonly 5th Gear December 19, 2018 Share December 19, 2018 2 years old, under warranty, and yes, tell me earliest is 2nd jan. But she did tell me to try my luck to walk in...Then go walk in bro, prepare to wait at least better to wait till Jan. No AC very hard to drive :( How to wait till Jan?? Go bang table a bit Somemore still under warranty, u go outside do, later say warranty void here n there is something happen. Link to post Share on other sites More sharing options...
teomingern 6th Gear December 19, 2018 Share December 19, 2018 2 years old, under warranty, and yes, tell me earliest is 2nd jan. But she did tell me to try my luck to walk in...Just walk-in and kick up a fuss lar... they'll deal... Link to post Share on other sites More sharing options...
Sktan10 5th Gear December 20, 2018 Share December 20, 2018 2 years old, under warranty, and yes, tell me earliest is 2nd jan. But she did tell me to try my luck to walk in...2 yrs die already. So fast? Are you a high mileage driver? Local fitted air con? Basic or S? Link to post Share on other sites More sharing options...
Huuray 2nd Gear December 20, 2018 Share December 20, 2018 2 years old, under warranty, and yes, tell me earliest is 2nd jan. But she did tell me to try my luck to walk in... Drive straight in.. Get them to repair / replace under warranty. If they try to push or delay then you ask to speak to their manager. Reason it out with them. How to drive without AC in SG climate? Link to post Share on other sites More sharing options...
Devilcup 3rd Gear December 20, 2018 Share December 20, 2018 (edited) how you all manage such good FC? Remove unnecessary items from car? Tyre pressure optimal? Good petrol? Advice please. mine is 8.8L/100km that is metered not on paper. on paper minus 1 km/l. on top of that i drive mainly on highway Edited December 20, 2018 by Devilcup Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 20, 2018 Share December 20, 2018 Hi Thanks for your detailed explanation. My previous car 1.8 litre, CVT transmission, hit 100km/h at 1750 rpm. It is good to know more on this car (Elantra) on the performance characteristics. Hyundai and kia are slightly different from say a nissan cvt. Thereis significant engineering in there which seems to drive better. Link to post Share on other sites More sharing options...
SMFChia 1st Gear December 20, 2018 Share December 20, 2018 2 yrs die already. So fast? Are you a high mileage driver? Local fitted air con? Basic or S? Hi, my previous car was a japanese PI car. I used to let the engine idle and run the air-con for an hour or so, as I had my first child who liked to nap in the car. Within 3 years, the compressor started to give problems, after refrigerant leaked from one of the valves. After replacing the valve and topping up refrigerant, it was ok. But every year or so, I had to top up refrigerant. Finally, the car air-con specialist workshop recommended replacing the whole air-con compressor, pipings and condenser, then the leak problem went away. The technician also recommended switching off air-con a minute or two before reaching destination and just run in fan mode, to remove condensation on cooling coils to prevent mold and bad smells. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged December 21, 2018 Share December 21, 2018 I like the word best build, keep fingers crossed that it can be as smooth and quiet ride for the longest time. try this insight Link to post Share on other sites More sharing options...
teomingern 6th Gear December 21, 2018 Share December 21, 2018 Hi, my previous car was a japanese PI car. I used to let the engine idle and run the air-con for an hour or so, as I had my first child who liked to nap in the car. Within 3 years, the compressor started to give problems, after refrigerant leaked from one of the valves. After replacing the valve and topping up refrigerant, it was ok. But every year or so, I had to top up refrigerant. Finally, the car air-con specialist workshop recommended replacing the whole air-con compressor, pipings and condenser, then the leak problem went away. The technician also recommended switching off air-con a minute or two before reaching destination and just run in fan mode, to remove condensation on cooling coils to prevent mold and bad smells. To be expected lar... your aircon is extracting heat but as your car is stationary, the heat extracted has nowhere to go... so it builds up inside the bonnet and all the relevant rubber and silicone gaskets and seals will all get worn out faster... your compressor is running on maximum power to keep the car cool as a result... sure die faster lar... Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 21, 2018 Share December 21, 2018 (edited) Hi, my previous car was a japanese PI car. I used to let the engine idle and run the air-con for an hour or so, as I had my first child who liked to nap in the car. Within 3 years, the compressor started to give problems, after refrigerant leaked from one of the valves. After replacing the valve and topping up refrigerant, it was ok. But every year or so, I had to top up refrigerant. Finally, the car air-con specialist workshop recommended replacing the whole air-con compressor, pipings and condenser, then the leak problem went away. The technician also recommended switching off air-con a minute or two before reaching destination and just run in fan mode, to remove condensation on cooling coils to prevent mold and bad smells. Been doing that for years since i met my wife and have kids. Altis changed compressor etc at 5 years old. My current car just about 4 years, bo taichi. I don't really think it's an issue at all. To have no AC problems in our climate over a lifespan of a car is just heng suay. If Idling is an issue here in singapore, i guess cars would just die in 40 degree weather in Middle east and Texas etc? Summers in other countries, easily is 37-38 degrees one. Edited December 21, 2018 by Lala81 Link to post Share on other sites More sharing options...
Alpha 2nd Gear December 23, 2018 Share December 23, 2018 Kid vomitted in car in afternoon. Immediately wind down windows and on hot air as I heard one bro/sis shared before the smell stays in car. Luckily for me the smell went off in the evening. Just sharing.. Link to post Share on other sites More sharing options...
Vicloo 1st Gear December 23, 2018 Share December 23, 2018 Anyone tried to bring better engine oil to KMC for servicing example Mobil 0w-40? Will KMC refuse to use it as it is not the recommended Shell 5w-40? 1 Link to post Share on other sites More sharing options...
Acewin 4th Gear December 24, 2018 Share December 24, 2018 Anyone tried to bring better engine oil to KMC for servicing example Mobil 0w-40? Will KMC refuse to use it as it is not the recommended Shell 5w-40? No issue they will use your oil but they will charge you for the oil filter change unless you bring your own as well. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
Kia Stonic
Kia Stonic
