Eyke Supercharged September 3, 2022 Share September 3, 2022 12 minutes ago, Mkl22 said: Crazy. When you get many others with oil bundle for 70-140 my problem is that hard to find shop that stock ACEA A5 oil that my S60 needs so boh pian gotta buy own oil and find shop to do the labour. anyone can recommend shop that change oil for $50 or less? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
QQDreamer 4th Gear September 4, 2022 Share September 4, 2022 go thomson caltex Link to post Share on other sites More sharing options...
mersaylee Supersonic September 4, 2022 Share September 4, 2022 18 hours ago, Eyke said: my problem is that hard to find shop that stock ACEA A5 oil that my S60 needs so boh pian gotta buy own oil and find shop to do the labour. anyone can recommend shop that change oil for $50 or less? Which S60 engine that requires you to buy your own oil? Run on 5W30 or 0W20? Even so, both are common and readily available for volvo petrol engines be it castrol or original... Link to post Share on other sites More sharing options...
Eyke Supercharged September 4, 2022 Share September 4, 2022 Just now, mersaylee said: Which S60 engine that requires you to buy your own oil? Run on 5W30 or 0W20? Even so, both are common and readily available for volvo petrol engines be it castrol or original... it's not the weight (0W30, 5W30) but the ACEA A5 requirement Link to post Share on other sites More sharing options...
inlinesix Supersonic September 4, 2022 Share September 4, 2022 Just now, Eyke said: it's not the weight (0W30, 5W30) but the ACEA A5 requirement Low SAP requirement. Diesel? Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 4, 2022 Share September 4, 2022 (edited) 14 minutes ago, Eyke said: it's not the weight (0W30, 5W30) but the ACEA A5 requirement A5 is a bit harder to find. It's for long oil change intervals. If you change at 10k km A3 specs can be used. Can try to change your own engine oil. Just buy a fluid extractor. Volvo filters are easy to access. In fact I would prefer DIY. I just discovered my WS did not put in the o-ring on the filter cover during my last oil change. Really WTF! Edited September 4, 2022 by Volvobrick 1 2 Link to post Share on other sites More sharing options...
mersaylee Supersonic September 4, 2022 Share September 4, 2022 (edited) 16 minutes ago, Volvobrick said: A5 is a bit harder to find. It's for long oil change intervals. If you change at 10k km A3 specs can be used. Can try to change your own engine oil. Just buy a fluid extractor. Volvo filters are easy to access. In fact I would prefer DIY. I just discovered my WS did not put in the o-ring on the filter cover during my last oil change. Really WTF! That's why I always make it a point to supervise when I go for EO change...that gasket cums with the kit is for a good reason... Volvo service schedule is now every 15k or 12 months whichever earlier...but I usually change at every 8 month when oil was cheap and I could use 5W40 then...now only can 0W20 or 5W30 for the B4154T5 engine Edited September 4, 2022 by mersaylee 1 Link to post Share on other sites More sharing options...
mersaylee Supersonic September 4, 2022 Share September 4, 2022 40 minutes ago, inlinesix said: Low SAP requirement. Diesel? Oh it's a diesel...not familiar with those...most likely a D2 or D4...there's a super rare D3 here though. Link to post Share on other sites More sharing options...
Eyke Supercharged September 4, 2022 Share September 4, 2022 1 hour ago, inlinesix said: Low SAP requirement. Diesel? Petrol. From what i read ACEA A5 seems to be for better fuel economy, so may be fine even if use oil that is not A5 🤔 Link to post Share on other sites More sharing options...
Eyke Supercharged September 4, 2022 Share September 4, 2022 1 hour ago, Volvobrick said: A5 is a bit harder to find. It's for long oil change intervals. If you change at 10k km A3 specs can be used. Can try to change your own engine oil. Just buy a fluid extractor. Volvo filters are easy to access. In fact I would prefer DIY. I just discovered my WS did not put in the o-ring on the filter cover during my last oil change. Really WTF! my S60 2.0T (2011) is an exception, there's a fat (difficult to remove/move out of the way) hose blocking access to the filter, making it a pain 😅 1 Link to post Share on other sites More sharing options...
Eyke Supercharged September 4, 2022 Share September 4, 2022 (edited) 1 hour ago, Volvobrick said: A5 is a bit harder to find. It's for long oil change intervals. If you change at 10k km A3 specs can be used. Can try to change your own engine oil. Just buy a fluid extractor. Volvo filters are easy to access. In fact I would prefer DIY. I just discovered my WS did not put in the o-ring on the filter cover during my last oil change. Really WTF! these days easier, e.g. found SHU A5 spec imported from HK @Shopee: https://shopee.sg/Shell-Helix-Ultra-5W30-Engine-Oil-i.250388472.8279985746 Edited September 4, 2022 by Eyke 2 Link to post Share on other sites More sharing options...
Johnnylim 5th Gear September 6, 2022 Share September 6, 2022 On 9/4/2022 at 9:50 AM, Volvobrick said: A5 is a bit harder to find. It's for long oil change intervals. If you change at 10k km A3 specs can be used. Can try to change your own engine oil. Just buy a fluid extractor. Volvo filters are easy to access. In fact I would prefer DIY. I just discovered my WS did not put in the o-ring on the filter cover during my last oil change. Really WTF! What will happen to the car if the o-ring is not there? It is supposed to be replaced with new piece every servicing or can be recycled? Thanks. Link to post Share on other sites More sharing options...
Volvobrick Supersonic September 6, 2022 Share September 6, 2022 6 minutes ago, Johnnylim said: What will happen to the car if the o-ring is not there? It is supposed to be replaced with new piece every servicing or can be recycled? Thanks. Possible some oil leak. The cover is plastic so if tightened enough not so bad. Link to post Share on other sites More sharing options...
Naughty9795 2nd Gear December 5, 2022 Share December 5, 2022 Any Volvo specialize to recomend? Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 6, 2022 Share December 6, 2022 No O ring less tight fluid can seep out. Link to post Share on other sites More sharing options...
nzyld Neutral Newbie December 14, 2022 Share December 14, 2022 Hi does anyone have reliable workshop to recommend for cabriolet repair? Having some issue with the soft top opening, suspect there’s a broken part Link to post Share on other sites More sharing options...
Shibadog Turbocharged December 14, 2022 Share December 14, 2022 1 hour ago, nzyld said: Hi does anyone have reliable workshop to recommend for cabriolet repair? Having some issue with the soft top opening, suspect there’s a broken part try https://8cushion.sg/convertible-tops/ Link to post Share on other sites More sharing options...
Volvobrick Supersonic December 15, 2022 Share December 15, 2022 On 12/6/2022 at 7:58 AM, Naughty9795 said: Any Volvo specialize to recomend? Old wowo normal workshops can deal with it. New not sure. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Land Cruiser Mini
