Bluepica
Yokohama V115 or Bridgestone GR100
4th Gear
I have been using 2 sets of BS GR90... Now time to change... GR90 have been replaced by GR100. I like soft and quiet tires.
The shop recommend alternative to GR100 is V115... Anyone using this tire? Ant comment in terms of softness and noise? Thanks
  • Praise 2
Share this post
4th Gear
I am using GR100 now. Soft and comfortable and very quiet. Grip is decent and I have no complain after 20k usage.
  • Praise 2
Share this post
3rd Gear
Am using GR100 for all 4 also. So far so good. Quiet and good grip for both wet n dry. Was using Yoko advan sport previously, was alright but definitely nosier than GR100 :)
  • Praise 2
Share this post
2nd Gear
what size are you looking for?
I can make some recommendations for you.
  • Praise 2
Share this post
4th Gear
195/60 15
Share this post
Supersonic
the v115 is comfort tyres???
if not mistaken the most similar to GR100 for yokohama should be db551
Share this post
4th Gear
Maybe I heard wrongly thru the phone... Please correct me
Share this post
6th Gear (edited)
The equivalent of GR 100 for Yokohama is DB 551. I am right now on GR90 which is GR100 predecessor. Prior to this I went through 5 rounds of changes of DB501 which is the precession of DB 551.
I regret switching to GR90. As quiet as the Yokohama equivalent with similar handling capabilities but a harder drive. The Yokohama is slightly softer giving a more comfortable ride. Biggest negative for Bridgestone Gr90 is it will last me no more than 40k km ( 2 tyres already worn out now at 33k km despite regular tyre rotation) while the yokohama 501 lasted me 55k km.
Based on the assumption that their replacements GR100 and DB 551 should retain the basic attributes, my next tyre change will be 551.
Edited by Nav14
  • Praise 2
Share this post
4th Gear
Both my previous GR90 lasted less than 40k, as for the current one, only 30k + , but I try to tahan till now, 40k.
Yes, the thread went off very fast!
Maybe the new GR100 can last longer? I'm not sure
Or maybe DB551 perform worse than 501? I don't know...
Anyone using 551 now? Any comment?
Share this post
Heard the DB series is bad in wet, does it apply to the 551?
Share this post
Supersonic
the previous 501 is famous for very bad in wet, the new 551 never try b4.
the gr100 for japan mid size car still reasonable wear,
for heavy conti car, I dun think will tahan long like most bro mention .
but from many review I read and pass experience, I doubt the 551 will last any longer then gr100.
  • Praise 2
Share this post
6th Gear
The 500 was bad in wet but  501 was already a major improvement. I had no issues with 501 in wet .
The GR90 is no better than 501 in wet.
The Yokohama is more comfortable than Bridgestone and longer lasting.
Assuming GR100  is not an improved version than Gr90 in longevity, then you are going to get no more than 40k km on it even if rotating tyres every 10k km. I can show you the tyres on my car and the receipt on when I changed them.
40k km lifespan for tyres is pathetic.
Share this post
4th Gear (edited)
My current GR90 at just reached 30k !! Front tire... Back one better a lil' ...avante... Mostly travel in 2 person only
28015C0C-6B87-4140-8222-B6BBE1C45BBD_zps
Edited by Bluepica
Share this post
4th Gear
Sorry, I calculated wrongly... Not 40k, now is only 30k... 20k went for tire rotation, tire shop already informed me that the tire track are wearing out soon, I said WHAT??!!!! Only 20k!
Share this post
What's the tread wear indicated on the tyre? 200?
Think for these soft tyres rotate every 7000km instead of 10000km?
And Bluepica, from the tyre pic, u may wanna consider pumping up the tyre pressure by maybe additional 20-30kpa as the side seems to wear more.
Pumping additional 10-20% more pressure than the recommended pressure indicated on the door side will help extend tyre wear and bring better FC
Share this post
5th Gear (edited)
is it Truth that GR90 or new GR100 is shorter life than yokohama
v series.
SO we have to choose you think which suit you best.
Generally GR still more comfort and Quiet (little only) better wet grip
Edited by Roberttan
Share this post
