Hamburger Hypersonic January 12, 2016 Share January 12, 2016 The 500 was bad in wet but 501 was already a major improvement. I had no issues with 501 in wet . The GR90 is no better than 501 in wet. The Yokohama is more comfortable than Bridgestone and longer lasting. Assuming GR100 is not an improved version than Gr90 in longevity, then you are going to get no more than 40k km on it even if rotating tyres every 10k km. I can show you the tyres on my car and the receipt on when I changed them. 40k km lifespan for tyres is pathetic. i disagree. 40k is the benchmark for me as the profile i used on few rides is 45 series. unless 60 series and above, then longevity should be better. ↡ Advertisement Link to post Share on other sites More sharing options...
Nav14 6th Gear January 12, 2016 Share January 12, 2016 i disagree. 40k is the benchmark for me as the profile i used on few rides is 45 series. unless 60 series and above, then longevity should be better. You mean the thread is less deeper for lower profile tyres? All things being equal, a tyre with profile of 55 should last longer than that of 55? Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 12, 2016 Share January 12, 2016 You mean the thread is less deeper for lower profile tyres? All things being equal, a tyre with profile of 55 should last longer than that of 55? its not about dept of thread but the compound used. Lower profile series has softer compound and thus wear faster. Thats why they also grip better. To add on, people upgrade their tyre size and fit in lower profile tyre and experience better grip. This is because of the softer compound used and not because the tyres are wider. Wider or narrower tyre, the contact on the ground remains the same. Link to post Share on other sites More sharing options...
Bluepica 4th Gear January 12, 2016 Author Share January 12, 2016 What's the tread wear indicated on the tyre? 200? Think for these soft tyres rotate every 7000km instead of 10000km? And Bluepica, from the tyre pic, u may wanna consider pumping up the tyre pressure by maybe additional 20-30kpa as the side seems to wear more. Pumping additional 10-20% more pressure than the recommended pressure indicated on the door side will help extend tyre wear and bring better FC but pumping too much will make the rise harder and bumpy :( Link to post Share on other sites More sharing options...
Baal Supersonic January 14, 2016 Share January 14, 2016 What's the tread wear indicated on the tyre? 200? Think for these soft tyres rotate every 7000km instead of 10000km? And Bluepica, from the tyre pic, u may wanna consider pumping up the tyre pressure by maybe additional 20-30kpa as the side seems to wear more. Pumping additional 10-20% more pressure than the recommended pressure indicated on the door side will help extend tyre wear and bring better FC So for 230 kpa, thats adding like bringing up to 250-275kpa. Quite a lot. 2 Link to post Share on other sites More sharing options...
FanLex Neutral Newbie July 4, 2016 Share July 4, 2016 Hi, any recommendation or lobang to buy bridgestone or yokohama tyres? Preferably in the east/ north/ central area. Thanks! Link to post Share on other sites More sharing options...
Deckbuild 6th Gear August 26, 2016 Share August 26, 2016 I am using GR100 now. Soft and comfortable and very quiet. Grip is decent and I have no complain after 20k usage. Bro whats your mileage for your GR100? Link to post Share on other sites More sharing options...
Earthboy 4th Gear August 28, 2016 Share August 28, 2016 Bro whats your mileage for your GR100?3k short of 30k. Still doing well. Probably can use for another 5k. Most likely will change to another set. I like it. Link to post Share on other sites More sharing options...
lun71 2nd Gear September 27, 2016 Share September 27, 2016 Love the Bridgestone GR series all along. Its managed to maintain the balance between safety grip and eliminating road noise. Thus far, I feel only Continental tyres are coming close on this. ↡ Advertisement Link to post Share on other sites More sharing options...
Yokohama BluEarth Ace-AE50
Yokohama BluEarth-RV-02
Primacy 3 ST or Turanza GR100?
Bridgestone GR100
Bridgestone GR100
Bridgestone GR100
Bridgestone GR100
An interesting ECO Tyres comparasion and testing
Do comfort tyres improve on harshness of ride?
