Vulcann 6th Gear February 18, 2016 Share February 18, 2016 Hi all, Was told by my regular WS after servicing that engine oil started to leak from the engine valve cover & plug seal of my Toyota Axio 1.5L 2007 model. The mechanic showed me the signs which was a streak of oil flowing down and some solid deposits at the valve cover. He quoted about $400 plus including labour for the replacement. Questions: (1) Is the quote reasonable? (2) Any recommended WS if answer to (1) is no? (3) As the lifespan of my Axio is only about a year plus, should I go for re-con parts? Thank you. ↡ Advertisement Link to post Share on other sites More sharing options...
Icecube187 2nd Gear February 18, 2016 Share February 18, 2016 (edited) I suggest you get a second opinion. When I replaced the valve cover gasket for my Toyota during servicing, I remember it was only 100 or less and a very simple job. But also not sure if we both are referring to the same thing Edited February 18, 2016 by Icecube187 1 Link to post Share on other sites More sharing options...
GLZT 6th Gear February 19, 2016 Share February 19, 2016 A gasket is usually a one time use thing, I dont think you are able to get a recon one and even if you do, it probably would not fit after the compression and heat it has been through and would give way in no time. Link to post Share on other sites More sharing options...
Macrosszero Turbocharged February 19, 2016 Share February 19, 2016 This one might enlighten you more. http://www.mycarforum.com/topic/2686835-my-engine-after-150000-kms/ Link to post Share on other sites More sharing options...
TL173 1st Gear February 19, 2016 Share February 19, 2016 Bought the Engine Valve Cover Gasket (11213-21011) from Ric-Tat @$14 b/f GST, in year 2013. Not sure the labor cost charge from workshop, as I DIY myself. By the way, my drive is Toyota VIOS 2006. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 19, 2016 Share February 19, 2016 if there is not much EO loss, just leave it. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear February 20, 2016 Share February 20, 2016 Hi all, Was told by my regular WS after servicing that engine oil started to leak from the engine valve cover & plug seal of my Toyota Axio 1.5L 2007 model. The mechanic showed me the signs which was a streak of oil flowing down and some solid deposits at the valve cover. He quoted about $400 plus including labour for the replacement. Questions: (1) Is the quote reasonable? (2) Any recommended WS if answer to (1) is no? (3) As the lifespan of my Axio is only about a year plus, should I go for re-con parts? Thank you. My Dad is driving a 2008 Toyota Axio and have the same problem. There isn't any recon parts available for valve cover, and I remember the valve cover itself is already about $250 excluding the rest and labour. Also paid about $400 odd in all including spark plug seals and gasket. I have always patronise and rely on Synergy Automobile since their old location at Lavendar Street Esso petrol kiosk, Hence, I think the quote you have been given is reasonable. Link to post Share on other sites More sharing options...
Ivan_06 5th Gear February 21, 2016 Share February 21, 2016 Hi all, Was told by my regular WS after servicing that engine oil started to leak from the engine valve cover & plug seal of my Toyota Axio 1.5L 2007 model. The mechanic showed me the signs which was a streak of oil flowing down and some solid deposits at the valve cover. He quoted about $400 plus including labour for the replacement. Questions: (1) Is the quote reasonable? (2) Any recommended WS if answer to (1) is no? (3) As the lifespan of my Axio is only about a year plus, should I go for re-con parts? Thank you. Your workshop is a con shop. Can get it replaced for around $80 or even less, inclusive of parts. 1 Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear February 21, 2016 Share February 21, 2016 Your workshop is a con shop. Can get it replaced for around $80 or even less, inclusive of parts. TS is referring to valve cover, the whole big engine cover, not just the gasket seal alone. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 21, 2016 Share February 21, 2016 No body change valve cover, only the gasket and valve seals. 1 Link to post Share on other sites More sharing options...
Vulcann 6th Gear February 22, 2016 Author Share February 22, 2016 Paiseh to confuse. My original post was not clear on the cover leakage part. The mechanic did point to a spot on the cover itself above the gasket which showed some deposit and claimed that the cover cracked at that spot. So the quote included the replacement of the cover and the gasket itself, IIRC the cover was $300ish, labour $70ish plus seal $30-40ish and with GST net $400ish. Link to post Share on other sites More sharing options...
Hamburger Hypersonic February 22, 2016 Share February 22, 2016 Paiseh to confuse. My original post was not clear on the cover leakage part. The mechanic did point to a spot on the cover itself above the gasket which showed some deposit and claimed that the cover cracked at that spot. So the quote included the replacement of the cover and the gasket itself, IIRC the cover was $300ish, labour $70ish plus seal $30-40ish and with GST net $400ish. not sure if the workshop is smoking you, even if an engine is overheated, valve cover may not crack that easily unless it is over tightened in wrong sequence. Link to post Share on other sites More sharing options...
Vulcann 6th Gear February 22, 2016 Author Share February 22, 2016 not sure if the workshop is smoking you, even if an engine is overheated, valve cover may not crack that easily unless it is over tightened in wrong sequence. Bro, got the feeling of being treated as a carrot head so that's why need to ask MCF bros in this post lo. Didn't kena (touch wood) any accidents before and thus unlikely a solid metal cover would just crack like that. But still play safe soliciting opinions from you guys on this Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear February 22, 2016 Share February 22, 2016 No body change valve cover, only the gasket and valve seals. Toyota Axio engine has this common wear & tear problem where the engine valve cover is bloated underneath. Unless you own one and has the same experience and witness it yourself, you will not understand. FYI, Axio and Vios do not share the same engine. 1 Link to post Share on other sites More sharing options...
Fuelsaver Supercharged February 23, 2016 Share February 23, 2016 Toyota Axio engine has this common wear & tear problem where the engine valve cover is bloated underneath. Unless you own one and has the same experience and witness it yourself, you will not understand. FYI, Axio and Vios do not share the same engine. Just curious, does it mean its caved in from outside? how bout tge new axio? Btw,not usual to change valve cover. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear February 23, 2016 Share February 23, 2016 (edited) Just curious, does it mean its caved in from outside? how bout tge new axio? Btw,not usual to change valve cover. My Dad's Toyota Axio happened to have erratic idling issues which took a few days to find the root of the problem. Did the basic stuffs like cleaning throttle body, changing new spark plugs etc but problem persist. Changed the whole throttle body, did a calibration on the G-Sensor and even remove the engine valve cover to check valve clearance, This is when we found out that the engine valve cover is due to be changed as it is in pretty bad shape; we also changed the spark plug seals and engine gaskets at the same time as this car has clocked 110K, and left about 3 years to go. Edited February 23, 2016 by Mr_biscuit Link to post Share on other sites More sharing options...
Kklee 6th Gear February 23, 2016 Share February 23, 2016 (edited) IMHO, for issues relating to engine valve cover and gasket, a possible cause is the choice of engine oil. A tell-tale sign is the engine top is yellowish (or golden) when the engine valve cover is removed. This is when we found out that the engine valve cover is due to be changed as it is in pretty bad shape; we also changed the spark plug seals and engine gaskets at the same time as this car has clocked 110K, and left about 3 years to go. Eh... a Toyota changing valve cover at 110k is like a bit too soon. Edited February 23, 2016 by Kklee Link to post Share on other sites More sharing options...
Vulcann 6th Gear February 23, 2016 Author Share February 23, 2016 IMHO, for issues relating to engine valve cover and gasket, a possible cause is the choice of engine oil. A tell-tale sign is the engine top is yellowish (or golden) when the engine valve cover is removed. Eh... a Toyota changing valve cover at 110k is like a bit too soon. Mine was doing the 140k servicing when my mechanic advised me to change the both the valve cover & gasket. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
Toyota Safety Sense 3.0 and Driving Assists - Technical, Features & Use
2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6
Toyota Land Cruiser Mini
Nissan Claims Toyota RAV4 Hybrid Fuel Economy Estimates Are Unrealistic
