Pioneer AVH-X8850BT
Idaddy88
Have you checked that your unit is wired correctly? It sounds like your constant power is not connected properly. Does the clock reset every time you turn it on? If it does, check the wiring. Sometimes the Acc power and the constant power wires get swapped accidently.
None of these errors on the HU. It just reset back to first file whenever i switch between video and music. The playback sequence doesn't seem to record the last file played.
hi guys , need some expert advice in here. I have downloaded some videos from Youtube , but only some can be played even though i used the same downloader and format .  Is there a full proof downloader compatible for 8850bt?  Would appreciate if there is any .. normally have the habit of d/l music videos...
