Frost98 1st Gear April 13, 2016 Share April 13, 2016 Hi folks,I am thinking of buying Pioneer HU and speakers from Amazon.com. Will they be compatible to use in Singapore? ↡ Advertisement Link to post Share on other sites More sharing options...
Macrosszero Turbocharged April 14, 2016 Share April 14, 2016 Just buy from Mustafa if you're looking to save a buck 2 Link to post Share on other sites More sharing options...
Meemee 5th Gear April 14, 2016 Share April 14, 2016 (edited) I got a hu from Amazon - USA set may have some radio issue - cannot tune to 95.0 frequency etc- 99.5 , 93.3 , 98.7, 91.3, 90.5 got no issue For a non radio guy I'm ok with less radio selection Mostly 99.5 for me I got the pioneer 4800 Much better audio quality :) Hi folks, I am thinking of buying Pioneer HU and speakers from Amazon.com. Will they be compatible to use in Singapore? Speaker can try to get from Germany online retailCan get back 19% vat rebate :) Edited April 14, 2016 by Meemee Link to post Share on other sites More sharing options...
Watwheels Supersonic April 14, 2016 Share April 14, 2016 (edited) I have only tried buying the front speakers, connectors and adaptor plates from amazon so far. There are actually quite a lot of prep work to do before buying. I have to figure out how to pry open the door trim to get to the speakers. Take pictures of the connectors, mine required special adaptor plates for the speaker. Some back and forth email to the ventor to check on the sizes. Becoz I diy I know what to do and what to ask. I was actually lucky to get all the right sizes and even the right connectors. FYI the speakers do not come with connectors...it does come with a couple of universal adaptor plates. It depends on your car. You have to pry open your door trim to find out what you require. I think local vendors will be able to help you install. I dun think it's rocket science. HU wise you have to get the right size. If it requires a mounting bracket you got to get one too. HU not easy as you got to have the right tools to remove it if you want to DIY. Edited April 14, 2016 by Watwheels Link to post Share on other sites More sharing options...
Meemee 5th Gear April 14, 2016 Share April 14, 2016 (edited) I have only tried buying the front speakers, connectors and adaptor plates from amazon so far. There are actually quite a lot of prep work to do before buying. I have to figure out how to pry open the door trim to get to the speakers. Take pictures of the connectors, mine required special adaptor plates for the speaker. Some back and forth email to the ventor to check on the sizes. Becoz I diy I know what to do and what to ask. I was actually lucky to get all the right sizes and even the right connectors. FYI the speakers do not come with connectors...it does come with a couple of universal adaptor plates. It depends on your car. You have to pry open your door trim to find out what you require. I think local vendors will be able to help you install. I dun think it's rocket science. HU wise you have to get the right size. If it requires a mounting bracket you got to get one too. HU not easy as you got to have the right tools to remove it if you want to DIY. Yes - agree - you may have to learn to open up and check on the connector May need to get compatible connector Actually DIY is fun ...... I did the hu installation - DIY My second one :) Glad I change the stock hu As there is a vast improvement in the SQ Picture of my DIY project Edited April 14, 2016 by Meemee 1 Link to post Share on other sites More sharing options...
Kb27 Supersonic April 14, 2016 Share April 14, 2016 (edited) I bought HU, power amp and speakers from Amazon. The only issue will be the radio freq. is according to USA standards. You can only tune to FM 87.9, 88.1, 88.3, 88.5.. etc..odd numbers only. Pioneer HU with BT is cheap at Amazon. If you look at Sg standards or no standards, the FM channels are chapalang, odd and even numbers, unequally spaced. You have 90.5 (odd), then somewhere along a 92.4. (even) Edited April 14, 2016 by Kb27 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 14, 2016 Share April 14, 2016 I bought HU, power amp and speakers from Amazon. The only issue will be the radio freq. is according to USA standards. You can only tune to FM 87.9, 88.1, 88.3, 88.5.. etc..odd numbers only. Pioneer HU with BT is cheap at Amazon. If you look at Sg standards or no standards, the FM channels are chapalang, odd and even numbers, unequally spaced. You have 90.5 (odd), then somewhere along a 92.4. (even) In terms of frequency modulation or FM the radio stations are given a set of frequency from IDA to choose from. The 90.5 MHz or 92.4 MHz are VHF or very high frequencies. The television using VHF and UHF. There are also frequencies given to military & police to use. That's why certain electronics you cannot buy from overseas, especially walkie talkies. They are usually pre-set with a number of frequencies and if your country's millitary or police has the same set of the frequency you might get into trouble with the authorities. So if you want to buy walkie talkies buy it locally. If you are overseas and want to use walkie talkies buy from the country you are currently staying. Otherwise the police there can arrest you for suspicion of spying if your walkie talkie is bought elsewhere. HU from Japan and US better dun buy unless it's export model specifically for Singapore. Frequencies are very sensitive when it comes to security. And it can be tracked by radio frequency triangulation. Any frequency related device even for remote devices(like car alarm),GPS and BT it's better buy locally. Those which got the IDA approved sticker. 2 Link to post Share on other sites More sharing options...
Frost98 1st Gear April 15, 2016 Author Share April 15, 2016 Thanks folks for the comments and advice. I was worried about the frequency of US head unit sets - looks like I am right. Class 95 is important to me. So I will probably only order the front speakers from Amazon. Will go Mustafa to look see look see. For class 95, can you set the frequency as 95.1 or 94.9 and still get a clear listen? I got a hu fromAmazon -USA set may have some radio issue - cannot tune to 95.0 frequency etc-99.5 , 93.3 , 98.7, 91.3, 90.5 got no issueFor a non radio guy I'm ok with less radio selectionMostly 99.5 for meI got the pioneer 4800Much better audio quality :)Speaker can try to get from Germany online retailCan get back 19% vat rebate :) Link to post Share on other sites More sharing options...
Meemee 5th Gear April 15, 2016 Share April 15, 2016 Thanks folks for the comments and advice. I was worried about the frequency of US head unit sets - looks like I am right. Class 95 is important to me. So I will probably only order the front speakers from Amazon. Will go Mustafa to look see look see. For class 95, can you set the frequency as 95.1 or 94.9 and still get a clear listen? Unable to ---- very distorted Link to post Share on other sites More sharing options...
clifflim Neutral Newbie July 6, 2016 Share July 6, 2016 Hi, I'm thinking of buying from Mustafa. Can anyone advise if Mustafa sets will not have limitations on the frequency? Also, looking at Pioneer 2 DIN HUs. Are they all compatible to GPS add-on modules like RoadNavi? Link to post Share on other sites More sharing options...
Hiton 1st Gear October 31, 2017 Share October 31, 2017 (edited) How abt amp and subwoofer? BOSS Audio AR1500M looks good Worth to buy from amazon and ask workshop to install? Edited October 31, 2017 by Hiton Link to post Share on other sites More sharing options...
justalex Neutral Newbie November 22, 2017 Share November 22, 2017 Mustafa ones are local export sets, local models but no warranty. Who is that? Why is he so popular here? Is it a safe seller? Link to post Share on other sites More sharing options...
Watwheels Supersonic November 23, 2017 Share November 23, 2017 Who is that? Why is he so popular here? Is it a safe seller? Mustafa yandao or not? He's popular for a reason. Safe or not I dunno. Link to post Share on other sites More sharing options...
Neutrino Supercharged November 23, 2017 Share November 23, 2017 https://www.youtube.com/watch?v=WTG31tiVvQg DL's Mad Chinaman CD is absolutely fabulous. Every song is great and The Mad Chinaman track is epic. Link to post Share on other sites More sharing options...
Kusje Supersonic November 23, 2017 Share November 23, 2017 Mustafa yandao or not? He's popular for a reason. Safe or not I dunno. You just make sure you use protection can already. Link to post Share on other sites More sharing options...
Kusje Supersonic November 23, 2017 Share November 23, 2017 Mustafa ones are local export sets, local models but no warranty. I have an old Accord (think 2005 or 2006 model) and thinking of upgrading to a simple HU that can at least play MP3 format cds... Need to upgrade the "shell" in the car as well right? Anyone know a rough cost? Link to post Share on other sites More sharing options...
Watwheels Supersonic November 23, 2017 Share November 23, 2017 I have an old Accord (think 2005 or 2006 model) and thinking of upgrading to a simple HU that can at least play MP3 format cds... Need to upgrade the "shell" in the car as well right? Anyone know a rough cost? A lot of single din HU has got a usb port, even for entry models. Just DL your music files to a thumb drive can already. I think all you have to do is go down to any audio shop and give them a budget to work with. Link to post Share on other sites More sharing options...
justalex Neutral Newbie November 23, 2017 Share November 23, 2017 I have an old Accord (think 2005 or 2006 model) and thinking of upgrading to a simple HU that can at least play MP3 format cds... Need to upgrade the "shell" in the car as well right? Anyone know a rough cost? at least 150$ I think ↡ Advertisement Link to post Share on other sites More sharing options...
Amazon.sg is launched
Component speakers, no amp?
Amazon Prime Day is nearing! 11 July!
Big Tech Companies
Big Tech Companies
Taobao Headunits
Taobao Headunits
