jaja2000 1st Gear April 10, 2021 Share April 10, 2021 3 hours ago, tmloh1978 said: Yes, exactly same. Care to share which workshop you went? Will PM you the workshop. My phone not working properly. Sorry for the nuisance posting😓 3 hours ago, tmloh1978 said: 21 hours ago, LEWISSVF2098 said: ↡ Advertisement Link to post Share on other sites More sharing options...
LEWISSVF2098 Neutral Newbie April 10, 2021 Share April 10, 2021 @jaja2000 Hi jaja 2000, pls pm me the workshop, tkx Link to post Share on other sites More sharing options...
jaja2000 1st Gear April 10, 2021 Share April 10, 2021 8 minutes ago, LEWISSVF2098 said: @jaja2000 Hi jaja 2000, pls pm me the workshop, tkx Hi Lewis, done. Please check your inbox Link to post Share on other sites More sharing options...
nashstruck 1st Gear April 14, 2021 Share April 14, 2021 @jaja2000 Hi can also share which outside workshop did you go. I plan to go to TC for 60km servicing so I'm sure they'll suggest few things to change, which I can do outside instead for less probably. Link to post Share on other sites More sharing options...
jaja2000 1st Gear April 19, 2021 Share April 19, 2021 I been driving this Qashqai for the past almost 5 years and done about 90k mileage. All servicing done by TC. Just went for the mandatory 5 years inspection. But list a few common problems as encountered: 1. Brake tick tok sound when depress. Went TC for checks and they told me was due to the solenoid on and off. The SA at Ubi was rather rude and simply walk away as if wasting his time to check. 2. Front mounting replaced as there were "thud" sounds when making a right turn from stop and centering back steering. The workshop confirmed this problem. TC was unable to locate this problem eventhough leaving the car for their checks earlier. 3. Drive shaft oil seal slight seeping of oil and valve cover gasket. These were replaced by outside workshop. 4. Throttle pipe o-ring, oil sump gasket oil leaking. (Yet to confirm.) Item 3 and 4 were informed by TC. I would suggest to spent some time to confirm the defects to rectify the problems in order to save some (lots of) money for these repairs. Other than that, this car serves me well and have no other complaint. 1 Link to post Share on other sites More sharing options...
Latio80 Neutral Newbie April 20, 2021 Share April 20, 2021 hi , anyone had any issue with the gear box. i driving a 2015 QQ 1.2 . Link to post Share on other sites More sharing options...
Teesh Neutral Newbie April 22, 2021 Share April 22, 2021 @Latio80 change the cvt oil asap Link to post Share on other sites More sharing options...
nashstruck 1st Gear April 22, 2021 Share April 22, 2021 @jaja2000 thanks man Link to post Share on other sites More sharing options...
nashstruck 1st Gear April 22, 2021 Share April 22, 2021 Anyone changes their interior lights to LED? Link to post Share on other sites More sharing options...
mersaylee Supersonic April 22, 2021 Share April 22, 2021 On 4/19/2021 at 11:37 AM, jaja2000 said: I been driving this Qashqai for the past almost 5 years and done about 90k mileage. All servicing done by TC. Just went for the mandatory 5 years inspection. But list a few common problems as encountered: 1. Brake tick tok sound when depress. Went TC for checks and they told me was due to the solenoid on and off. The SA at Ubi was rather rude and simply walk away as if wasting his time to check. 2. Front mounting replaced as there were "thud" sounds when making a right turn from stop and centering back steering. The workshop confirmed this problem. TC was unable to locate this problem eventhough leaving the car for their checks earlier. 3. Drive shaft oil seal slight seeping of oil and valve cover gasket. These were replaced by outside workshop. 4. Throttle pipe o-ring, oil sump gasket oil leaking. (Yet to confirm.) Item 3 and 4 were informed by TC. I would suggest to spent some time to confirm the defects to rectify the problems in order to save some (lots of) money for these repairs. Other than that, this car serves me well and have no other complaint. Is yours a 1.2 or 2.0? Shouldn't TC fix all problems discovered since the warranty is of 5 years? Link to post Share on other sites More sharing options...
mersaylee Supersonic April 22, 2021 Share April 22, 2021 5 hours ago, Teesh said: @Latio80 change the cvt oil asap How much for this CVT oil change? Link to post Share on other sites More sharing options...
nashstruck 1st Gear April 30, 2021 Share April 30, 2021 @mersaylee Depends if warranty 3 yrs or 5 yrs. N they say many things also wear n tear, so not everything liable for warranty. 1 Link to post Share on other sites More sharing options...
jaja2000 1st Gear May 2, 2021 Share May 2, 2021 @mersaylee TC mentioned gear box oil change and spark plugs would cost $400. 1 Link to post Share on other sites More sharing options...
Teesh Neutral Newbie May 6, 2021 Share May 6, 2021 @mersaylee oil is about 50+ . i diy 1 Link to post Share on other sites More sharing options...
Des29 Neutral Newbie May 19, 2021 Share May 19, 2021 Hi. I’m driving 1.2 turbo. Manufacturinq 2016. Does the mirror auto fold when locking the car? Link to post Share on other sites More sharing options...
oleoleole 2nd Gear May 19, 2021 Share May 19, 2021 @Des29 yes, it does Link to post Share on other sites More sharing options...
Des29 Neutral Newbie May 19, 2021 Share May 19, 2021 @oleoleole oh. Mine doesn’t close. I have to manually press the mirror button to close. Is there different version? Link to post Share on other sites More sharing options...
Cheesey74 6th Gear May 19, 2021 Share May 19, 2021 1 hour ago, Des29 said: Hi. I’m driving 1.2 turbo. Manufacturinq 2016. Does the mirror auto fold when locking the car? Nope, no autofold when locked for the earlier batch, need to press button to fold it. Think only the facelift have it. ↡ Advertisement Link to post Share on other sites More sharing options...
2021 3rd Generation Nissan Note (E13)
2014 Mercedes CLA
2014 Mercedes CLA
