Othello Supersonic June 7, 2016 Share June 7, 2016 (edited) * double post * Edited June 7, 2016 by Othello ↡ Advertisement Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 7, 2016 Share June 7, 2016 How to get that "ferrule" on a bare copper pipe so can connect to a joint? On the other hand, I saw some piping end were being forced to open slightly larger and flatten the opening so that it can also joint to any fixture using just a rubber ring. How did they do that? That is what a flaring tool is used for. To flar the pipe end. I think you got no idea how to join copper pipe. My advise is to get a plumber. Otherwise here leak, there leak, even more headaches. 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 I ended up doing this to cut the hole for the sockets Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 7, 2016 Share June 7, 2016 I ended up doing this to cut the hole for the sockets This is double job. If my senior see me doing such thing, sure kena a knock on the head. Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 That is what a flaring tool is used for. To flar the pipe end. I think you got no idea how to join copper pipe. My advise is to get a plumber. Otherwise here leak, there leak, even more headaches. It's like dat, I swear... Let me try to find a pic or see my house piping got such instances for it... There is no "ferrule" knob, just the flattened pipe end... Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 7, 2016 Share June 7, 2016 It's like dat, I swear... Let me try to find a pic or see my house piping got such instances for it... There is no "ferrule" knob, just the flattened pipe end... I know what u mean. Here is a pic : Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 This is double job. If my senior see me doing such thing, sure kena a knock on the head. I'm not pro ma, don't have the right tools, must think of way to work around Lo... Link to post Share on other sites More sharing options...
Othello Supersonic June 7, 2016 Share June 7, 2016 I ended up doing this to cut the hole for the sockets and you gonna do the same thing (or already done) for the other 2 holes beside ?? wah, shack Link to post Share on other sites More sharing options...
Jtb 6th Gear June 7, 2016 Share June 7, 2016 copper piping installation not Tom Dick Harry can do the job even you are hands-on You really needs tools & skill for this job especially the bending angle and the strength!!! Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 and you gonna do the same thing (or already done) for the other 2 holes beside ?? wah, shack done...haha 1 Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 I know what u mean. Here is a pic : Yes! this is what I meant! how they did it? Link to post Share on other sites More sharing options...
Mercury1 Turbocharged June 7, 2016 Share June 7, 2016 How to get that "ferrule" on a bare copper pipe so can connect to a joint? On the other hand, I saw some piping end were being forced to open slightly larger and flatten the opening so that it can also joint to any fixture using just a rubber ring. How did they do that? Why not just use white tape and ferrule, be a lot easier 1 Link to post Share on other sites More sharing options...
UncleAtas Turbocharged June 7, 2016 Share June 7, 2016 I paid $80 to a plumber to just cut a 10cm copper and relocate the tap. Link to post Share on other sites More sharing options...
Adrianli Hypersonic June 7, 2016 Share June 7, 2016 Yes! this is what I meant! how they did it? Use the flaring tool lah. Link to post Share on other sites More sharing options...
Hotamp 3rd Gear June 7, 2016 Share June 7, 2016 Why not just use white tape and ferrule, be a lot easier ya...thats the easiest option, just a small project not worth to buy too many tools, i guess just a made in china pipe cutter, white tape, cheap spanners and few 90 degree and straight joints will do. Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 Why not just use white tape and ferrule, be a lot easier I think so too Use the flaring tool lah. ooh.. Link to post Share on other sites More sharing options...
Mercury1 Turbocharged June 7, 2016 Share June 7, 2016 ya...thats the easiest option, just a small project not worth to buy too many tools, i guess just a made in china pipe cutter, white tape, cheap spanners and few 90 degree and straight joints will do.also if you're sercuring to the wall get the pipe brackets, if need to drill thru tile ask the shop how it's done otherwise might crack the tile. Good luck! Link to post Share on other sites More sharing options...
Bluepica 4th Gear June 7, 2016 Author Share June 7, 2016 ya...thats the easiest option, just a small project not worth to buy too many tools, i guess just a made in china pipe cutter, white tape, cheap spanners and few 90 degree and straight joints will do. I think I have pipe cutter... last time used it to cut my mountainbike seat post... should be ok gua ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
DIY Dashcam Installation vs Poor Worksmanship from Installation Workshops
Cooking: All About Beef
