Bluepica 4th Gear May 22, 2016 Share May 22, 2016 Hi, Looking for an electrician to rewire my friend's resale HDB. Actually do we need EMA certified electrician to do the work? Cos I guess a lot of electrician from the north do not have such certification but of course their price are cheaper. By the way, if you have any good electrician pls recommend.... I found some with $45 for single 13A power gang and $55 for double power gang, $28 for light point.... See any can be better than this... Thanks!! ↡ Advertisement Link to post Share on other sites More sharing options...
Blueblueman 4th Gear May 22, 2016 Share May 22, 2016 93899459 northern singapore pr chinese who did my house last year. AH shun 4 Link to post Share on other sites More sharing options...
Jtb 6th Gear May 22, 2016 Share May 22, 2016 yr town council can help with pricing on the website 2 Link to post Share on other sites More sharing options...
Dafansu Turbocharged May 22, 2016 Share May 22, 2016 can call Derrick 93832155 for quote 3 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 22, 2016 Share May 22, 2016 (edited) make sure cheap, they also use good expensive wires... hahahahaha... If not, later wire insulation melts burn down house. If you noticed, many of today's USB charging wires for smartphones fray or melt. Here, we are talking about small current. Will be more interesting for your house electricity supply. If concealed wiring, it will be subjected to more initial wear and tear (abrasion) when electrician pull in the new wires. If quality no good, good luck... Edited May 22, 2016 by Kangadrool 5 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 22, 2016 Share May 22, 2016 Wiring is about thickness of the cable. The thicker it is, the more expensive, but it will carry more current, without overheating. If the circuit breaker is rated for 25A, then only a lmited thickness is good enough. No need for giant, expensive cables. 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic May 22, 2016 Share May 22, 2016 Ts ownself buy wire then get that guy do lor 1 Link to post Share on other sites More sharing options...
2BDriver Hypersonic May 22, 2016 Share May 22, 2016 Hi, Looking for an electrician to rewire my friend's resale HDB. Actually do we need EMA certified electrician to do the work? Cos I guess a lot of electrician from the north do not have such certification but of course their price are cheaper. By the way, if you have any good electrician pls recommend.... I found some with $45 for single 13A power gang and $55 for double power gang, $28 for light point.... See any can be better than this... Thanks!! It will be more helpful for HDB owner currently sourcing sub-contractors if it includes below : Electrical Air-con Plumping & Sanitary Wall & Kitchen Cabinets Floor Tiling & Cementing works Doors & Window Grille CCTV 3 Link to post Share on other sites More sharing options...
Kenneve888 4th Gear May 22, 2016 Share May 22, 2016 Wiring is about thickness of the cable. The thicker it is, the more expensive, but it will carry more current, without overheating. If the circuit breaker is rated for 25A, then only a lmited thickness is good enough. No need for giant, expensive cables. This is one consideration - insulation thickness. I learnt from my aircon installer that there was a batch of MIC cables that contain more that normal amount of aluminium than copper. This resulted in my aircon wirings broke circuit and I had to re-wire again, in less than 2 years. 3 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 22, 2016 Share May 22, 2016 This is one consideration - insulation thickness. I learnt from my aircon installer that there was a batch of MIC cables that contain more that normal amount of aluminium than copper. This resulted in my aircon wirings broke circuit and I had to re-wire again, in less than 2 years. It's not really about insulation thickness. Aluminum is less conductive than copper. It is also cheaper. By adding more aluminum, conductivity reduces, resistance increases and heating effect increases. Bcuz pure copper is expensive, sometimes they "cheat" by using cheaper aluminum-clad copper. In this case, the wire size would need a bit of upsizing to increased heating effect. Insulation breaks down over the years due to heating effect. So if you have old wiring that handles a lot of current, like those you use for electric kettle, aircon, then you should consider replacing the wiring. Circuit breakers in most of our houses, apartments, act like a fuse. It trips when insulation breaks down and a small leakage current is detected. 3 Link to post Share on other sites More sharing options...
Raychay 6th Gear May 22, 2016 Share May 22, 2016 This is one consideration - insulation thickness. I learnt from my aircon installer that there was a batch of MIC cables that contain more that normal amount of aluminium than copper. This resulted in my aircon wirings broke circuit and I had to re-wire again, in less than 2 years. Ya I also kenna. My wiring was 3-4 yrs old when it started to trip, Aircon contractor said they were conned by supplier with MIC wires and since my warranty was over I have to pay 'friendship' price to rectify! Got a few quotes but they were cheapest so lan lan suck thumb Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 22, 2016 Share May 22, 2016 Wiring is about thickness of the cable. The thicker it is, the more expensive, but it will carry more current, without overheating. If the circuit breaker is rated for 25A, then only a lmited thickness is good enough. No need for giant, expensive cables. HDB circuit breakers are now all rated for 40 amps, only some old ones pre-upgrading are at 30amps. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged May 22, 2016 Share May 22, 2016 One thing for sure, better get a certified electrician and house owner on site when work is carried out. 2 Link to post Share on other sites More sharing options...
Kb27 Supersonic May 22, 2016 Share May 22, 2016 (edited) HDB circuit breakers are now all rated for 40 amps, only some old ones pre-upgrading are at 30amps. My old hdb only 20A breaker for mains and 6A for lighting. If you have 40A breaker, then I think the wires running from that breaker should be thicker. If you go buy electrical wires (100ft coil), they will ask you what capacity you are running. The higher capacity, thicker wire is obviously more expensive. Edited May 22, 2016 by Kb27 Link to post Share on other sites More sharing options...
Kangadrool Supersonic May 23, 2016 Share May 23, 2016 Anyone here with concealed wiring changed to "traditional" external wiring when renewing their wires? Link to post Share on other sites More sharing options...
Lala81 Hypersonic May 23, 2016 Share May 23, 2016 My old hdb only 20A breaker for mains and 6A for lighting. If you have 40A breaker, then I think the wires running from that breaker should be thicker. If you go buy electrical wires (100ft coil), they will ask you what capacity you are running. The higher capacity, thicker wire is obviously more expensive. I see. That was the information i gleaned from reading renovation forums previously. Link to post Share on other sites More sharing options...
Jtb 6th Gear May 23, 2016 Share May 23, 2016 HDB may just allowed max of 20A circuit breaker. Rewire concealed wiring only solution just above skirting will be partial hidden. Link to post Share on other sites More sharing options...
Beehive3783 Turbocharged May 23, 2016 Share May 23, 2016 Better get EMA certified for peace of mind. Hi,Looking for an electrician to rewire my friend's resale HDB.Actually do we need EMA certified electrician to do the work? Cos I guess a lot of electrician from the north do not have such certification but of course their price are cheaper. By the way, if you have any good electrician pls recommend....I found some with $45 for single 13A power gang and $55 for double power gang, $28 for light point.... See any can be better than this...Thanks!! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Simple home DIY repairs
Wheel Spacer Installation DIY
