SingtradeMarketing
Audi Q7
Thank you for supporting us to Install:
  • Bewith Plug & Play 1080 10ch/8ch DSP Processor with amplifier
  • Helix SDMI 25
  • Audible physics Avatar 6.1 2way component speakers
  • Audible physics Avatar 3"mid speaker
The BEWITH PLUG & PLAY 1080 is a combination audio processor and amplifier that combines a high-quality 8-channel amplifier (50 watts/channel) and 8 channels of digital processing. It can be connected to any aftermarket audio source or factory head unit-having a comprehensive 8 channels of high-level (speaker level) inputs, AUX input/output (2 channels each) and high-resolution optical digital input. It also features fully adjustable software, high-speed and high capacity components, making it the ideal combination processor/amplifier to get the best in-vehicle sound quality.
Don't miss the chance to upgrade your sound system.
For more details please call now.
Toyota Previa
Thank for supporting us to Install:
  • Bewith 1080 DSP 10/8ch with Amplifier & control
  • Pioneer DMH-ZS9350BT
  • Bewith lucent 2way component
BEWITH Lucent was planned as the fourth speaker series after the company's BEWITH brand "Confidence," "Accurate," and "Reference AM." Although it is the most reasonable price range in the BEWITH brand speaker series, but it is act meively selected in terms of sound preference and installability as well as other series. We aimed to become a new class.
The 2cm caliber dome tweeter (L-20L) uses the company's first new silk-based diaphragm material "Lucent Silk". It features an almost transparent diaphragm appearance, supple and pleasant to the ear, and a tone full of sharpness and transparency, and you can enjoy the charm of a new sound that is different from the conventional hard dome and soft dome. In addition, the driver unit is made as compact as possible.
The 16.5cm woofer (L-165L) is a combination of the company's original aluminum-magnesium (AM) diaphragm and a powerful magnetic circuit with a large ferrite magnet, which has a proven track record in the advanced reference AM series, and is combined with the L-20L tweeter. Careful sound quality matching was performed. While keeping the mounting depth dimension to 60 mm, which is easy to mount on many car models, a generous amplitude stroke is secured by adopting a newly designed cone shape with a shallow shape and a large roll edge.
The passive network dedicated to this system is particular about sound quality, such as using the BEWITH original cable "TRANSOLA OFC Hyper4N" as the wiring material. Only filtering on the tweeter side is performed, and the woofer side has a simple configuration that drives the full range to bring out the characteristics of each unit.
For more details please call now at 62661719. Thank you.
Subaru Forester
Bewith plug & play DSP 8ch with control.
Bewith plug & play 2ch amplifier X 3.
ESB Audio 5000 series 5.6K3
3 way component speakers.
𝗘𝗦𝗕 𝗔𝘂𝗱𝗶𝗼 Car Audio High-Quality Speakers.
𝗘𝗦𝗕, for over thirty years, has specialized in the engineering and construction of speakers for automotive applications, offering different product lines, united by the fact of true fidelity to the musical source. True to quality. True to the music. Pure performers, accurate reproducers.
For more details please call 62661719 now! Thank you.
Toyota Harrier
Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP.
FOCAL Flax Evo 2 ways component
FOCAL PC165 2 ways coaxial speaker.
Sound stream SB8AM active subwoofer.
6-Channel, Full Range,
Class A/B
On-Board, Full Function, 8-ch. Digital Signal Processing
High-pass and low-pass filters, phase control, signal delay, and 15 channels of parametric equalization on each channel
Optical Digital Input
Power @ 4Ω: 6 x 100 watts
THD @ Rated Power
< 0.5% THD
Power @ 2Ω: 6 x 150 watts
Power Bridged @ 4Ω: 3 x 300W RMS
Signal to Noise Ratio > 90dB
THD + Noise < 0.2%
Channel Separation >60dB
Frequency Response 15Hz to 30KHz ±1dB
The New Mercedes-Benz C-Class Coupé.
  • Ground Zero GZCS 100MB 4" Component Speaker
    - Mercedes-Benz Compatibility List:
    C Class - W205, S205,C205,A205
    GLC - X253, C253
    E Class - W213 , S213, C238,A238
    S Class -W222
  • Ground Zero GZCS W-200ML 8" Footwell Woofer - Mercedes
Power Handling (RMS/max.): 110 / 220 Watts
Impedance 4 Ohms
Efficiency 88 dB
Frequency Response 30 – 1500 Hz
Voice Coil 38 mm / 1.5" copper
Membrane Coated glass-fiber.
BMW 6 Series
  • HELIX V EIGHT DSP MK2
  • Gound Zero GZCS 200BMW-SW
  • Rainbow MP-S4BMW
The new multi-tool for professionals
The small addition in the product name makes the big difference – the V EIGHT DSP MK2 is the logical evolution of its already more than impressive predecessor. Same look as before but in the inside Audiotec Fischer brought in all of his expertise and substantially optimized the hardware. The result is an 8-channel amplifier with ten processed DSP channels that is unrivalled in many ways.
Extra speed – thanks to ACO
Faster is better – the particularly powerful 32 Bit ACO platform takes over all control tasks and ensures the decisive speed increase, especially for data communication with our DSP PC-Tool software but also for the lightning-fast switching between up to ten sound setups. But ACO offers much more – fantastic sound effects such as Augmented Bass Processing or RealCenter are implemented as well as a channel-separated Input EQ including the Input Signal Analyzer (ISA) for easy analysis and compensation of input signals of OE radios.
New signal converters for optimized sound quality
Instead of a combined codec, the new V EIGHT DSP MK2 uses separate AD and DA converters of the latest generation from Asahi Kasei with a native resolution of 32 Bit. This ensures maximum signal resolution in the entire signal path from input to output – and thus also guarantees optimal sound quality.
Power pack in a noble design
Despite its further increased feature set and up to 160 Watts RMS output power per channel (@ 2 Ohms) the V EIGHT DSP MK2 presents itself in the classic, clean HELIX design which provides ideal preconditions for a quick and easy integration.
High-tech performance could hardly be more noble and elegant!
Kia Sorento
  • Focal K2Power ES 165 KX3 3 way component speakers.
  • Alpine PXE-0850S 8-Channel 25W x 8 RMS Amplifier with Digital Signal Processing.
  • Soundstream SB8AM 8"active subwoofer.
  • Sound stream RX652 3 way coaxial speakers.
  • Sound stream 10.1" Android player.
Alpine PXE-0850S
Adjustment Details: 12-channel 32-bit 300 MHz digital processor, 31-band EQ with fine tuning, Adjustable high-, low-, and band-pass filters (20-20 KHz), Selectable filter slopes (12, 18, 24, 30, 36, 42, 48 dB/octave), Selectable filter characteristics (Butterworth, Bessel, and Linkwitz-Riley), Delay: 0-20 milliseconds (0-273"), Phase adjustment: 0 or 180°.
While stock lasts.
For more details please call 88476629 Thanks
Toyota Wish
  • ESB Audio 5000 series
  • 5.6K3 – 3-way speaker system.
  • Zapco ST-6X DSP 6 Ch. Class AB Amplifier with DSP.
  • Sound stream SB8AM active subwoofer.
  • Sound stream 10'1 Android player.
  • Pioneer rev camera.
ESB Audio 5000series: 5.6K3 – 3-way speaker system.
Tweeter – 5028
1.1″/28 mm Dome Tweeter, 28 mm aluminum voice coil
32.8 mm nominal diameter, High-grade neodymium magnet
Carbon fiber dome, Ferrofluid cooling and damping
Acoustic resistance Qts. control, Computer optimized design.Motor metal parts CNC machined, Under-dome dB Cloth® damping material
Nominal Impedance: 4 Ohm
Nominal Power Handling: 110 Watt. Transient Power: 220 Watt.Frequency Response: 900 Hz ~ 25 KHz
Sensitivity: 91 dB 1W/1m
Mid-range – 5050
2″/50 mm Dome Midrange, 50 mm aluminum voice coil
High-grade neodymium magnet, Carbon fiber dome
Ferrofluid cooling and damping, Acoustic resistance Qts control
Computer optimized design, Motor metal parts CNC machined .Under-dome dB Cloth® damping material, Nominal Impedance: 4 Ohm
Nominal Power Handling: 120 Watt.Transient Power: 240 Watt
Frequency Response: 500 Hz ~ 6 KHz.Sensitivity: 91 dB 1W/1m
Mid-woofer – 5165
6.5″/165 mm Mid-Woofer, Carbon fiber cone
TWS® rubber surround, Copper and aluminum voice coil
25 mm voice coil diameter, Y35 oversized magnet
Aluminum former, ABS housing
Conex® progressive spider, Motor metal part CNC machined.Computer optimized design, Nominal Impedance: 4 Ohm.Nominal Power: 160 Watt
Transient Power: 320 Watt
Frequency Response: 50 Hz ~ 3.5 KHz
Sensitivity: 92 dB 1W/1m
While stock lasts.
Honda Freed
  • Focal Flax Evo PS165FXE 2way component speakers.
  • Bewith Plug & play 1080 10ch/8 ch DSP Processor with amplifier.
  • Pioneer active subwoofer.
For more details please WhatsApp 88476629. Thanks.
Toyota Camry
Tweeter – 5028
Acoustic resistance Qts. control, Computer optimized design.Motor metal parts CNC machined, Under-dome dB Cloth damping material
Mid-range – 5050
Computer optimized design, Motor metal parts CNC machined .Under-dome dB Cloth damping material, Nominal Impedance: 4 Ohm
Mid-woofer – 5165
TWS rubber surround, Copper and aluminum voice coil
Conex progressive spider, Motor metal part CNC machined. Computer optimized design, Nominal Impedance: 4 Ohm.Nominal Power: 160 Watt
While stock lasts.
Edited by SingtradeMarketing
Last job for 🐁 Year.
BMW 6 Series
Full set for Bewith series.
  • Bewith 1080 Plug & play 10/8ch DSP Processor with amplifier.
  • Bewith Reference L-25R +L-88R
  • Bewith Reference L-88R for center speakers.
  • Bewith Reference L-165R.
  • Bewith Reference series.
Next-generation standard model, featuring newly developed AM diaphragm
The Reference AM series further enhances reproduction of high-quality audio sources thanks to the newly developed AM (Aluminum/Magnesium) diaphragm and other new features, and is particulary designed for ease-of-installation to the latest sports cars and luxury automobiles. The line-up consists of three speaker unit models, three models combined with a dedicated network, and five dedicated network models, for a total of eleven models. This is the series completion of Bewith’s next-generation models, featuring timbre uniformity across all frequency bands, directivity control, and exceptional smooth and flat frequency response.
Alpine days.
Thank you Noah & Forester supporting us to install:
  •  Alpine Halo11 iLX-F2611E
THE BIGGEST 11-INCH SCREEN DISPLAY AUDIO
The new iLX-F2611E Alpine Halo Mech-Less (no CD/DVD) Audio/Video Receiver features the same “hovering” screen platform as its predecessors while boasting a larger, 11-inch touchscreen – 49 percent more surface area than the 9-inch.
For more details call 62661719. Thanks.
Aşağıdaki linke sizler için bu yılın en pahalı ve en lüks arabalarını ekledim.
https://oke.io/YakQ9a
https://www.facebook.com/107378898643628/posts/pfbid0Wb8SP9ZLFQTLh4YMuyiygg3KEiSV5PVdcysYVwLiYoepiCagutwK9NVMjb6bBV7wl/?sfnsn=scwspmo , would recommend reading it, if you're into RV's
