SingtradeMarketing 1st Gear November 26, 2020 Author Share November 26, 2020 Mercedes A-Class Thank you for supporting us by installing: Focal and BEWITH 1080 DSP processor with amplifier The ES 165 K2 kit is composed of two 6½" (165 mm) woofers and has a very high sensitivity (92.8 dB/oct).The speaker drivers of the ES 165 K2 kit feature the K2 Power line’s famous yellow Kevlar cones. Light, rigid and with excellent damping, they provide extremely dynamic sound and perfect definition. Paired with the new TMD suspension, there’s no distortion whatsoever. The phase plug in the centre of the cone improves sound dispersion around the vehicle. The treble is reproduced by the two 'M'-shaped aramid-fibre TKM inverted dome tweeters equipped with high-fidelity bi-amplified crossovers. High frequencies (up to 22 kHz) are perfectly reproduced, smoothly and with precision. Don’t miss this chance to upgrade your sound system at our special package. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear November 26, 2020 Author Share November 26, 2020 Nissan x trail. Thank you for supporting us by installing: ESB Audio 5000series(5.2K2 way comp) Zapco ST-2 SQ 2 ch amplifier JBL active subwoofer ESB Audio philosophy of this project is to create a loudspeaker system with an extremely high transient response (dynamic), in order to obtain a music reproduction with a more realistic impact and involvement. To achieve this, the main goal was to reduce the moving masses in order to make the mobile part of the loudspeaker light and fast in its movements, favoring the sudden variations of movement transmitted by the piece of music through the amplifier. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear November 26, 2020 Author Share November 26, 2020 Toyota Camry Thank you for supporting us by installing: ESB Audio 5000series(5.2K2 way comp) Zapco ST-2 SQ 2 ch amplifier & pioneer Active subwoofer ESB Audio philosophy of this project is to create a loudspeaker system with an extremely high transient response (dynamic), in order to obtain a music reproduction with a more realistic impact and involvement. To achieve this, the main goal was to reduce the moving masses in order to make the mobile part of the loudspeaker light and fast in its movements, favoring the sudden variations of movement transmitted by the piece of music through the amplifier. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 New Mercedes-Benz CLA. Thank you for supporting us by installing: Focal PS 165 FXE speakers Zapco ST-4X DSP 4 Ch. Class AB Amplifier with DSP Soundstream active subwoofer THE FOCAL FLAX CONE, EXPRESSIVE AND NATURAL. This flax cone has been exclusively made in France by Focal since 2013. With its original design, it is 100% geared towards acoustic performance. This sandwich cone is formed of a flax fibre core placed between two thin sheets of glass fibre. Flax is a fibre with the unique ability to reproduce a very natural sound without colouration, with a rich reproduction in the midrange and clear bass strokes. Its lightness offers great dynamics, while its rigidity sustains the bass and provides good damping to deliver a faithful listening experience. Flax fibre is twice as light as glass fibre as it is hollow. Its very low elasticity makes it ideal for increasing the flexural rigidity module of a sandwich structure. Don’t miss this chance to upgrade your sounds system at our special package. For more details please call now @ Huat/92325621. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Mercedes Benz SLK 200 Kompressor. Thank you for supporting us by installing: Pioneer DMH-ZF 9350BT Pioneer reverse camera Don’t miss this chance to upgrade your sound system at our special package. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Toyota Sienta. Thank you for supporting us by installing: ESB Audio 5000series(5.2K2 way comp) Zapco ST-2 SQ 2 ch amplifier & pioneer Active subwoofer. ESB Audio philosophy of this project is to create a loudspeaker system with an extremely high transient response (dynamic), in order to obtain a music reproduction with a more realistic impact and involvement. To achieve this, the main goal was to reduce the moving masses in order to make the mobile part of the loudspeaker light and fast in its movements, favoring the sudden variations of movement transmitted by the piece of music through the amplifier. Don't miss the chance to upgrade your sound system. While stock last. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 New Mercedes GLC 2020 Thank you for supporting us by installing: Zapco ADSP-Z8IV-8 DSP with 8 Ch. Amplifier Match -UPS4MB, W8MB. Speakers & woofer. Zapco ADSP-Z8 IV-8 8 Ch. DSP with 8 Ch. Amplifier. Specifications:- DSP Processor: Cirrus Logic CS47048 Power: 150 MHz/32 bit/48 KHz 8-Channels ADC: Cirrus Logic CS5368 24 bit/192 KHz ADC Dynamic Range/THD: 114 dB/-105 dB DAC: Cirrus Logic CS47048 32 bit/192 KHz DAC Dynamic Range/THD: 108 dB/-98 dB Low level (Pre)/Sensitivity: 8/1-5 VRMS High Level (Spk In)/Sens.: 6/2-20 V AUX Inputs/Sensitivity: 1/0.2-4 VRMS Optical IN: 24 bit-192 KHz Freq. Response (-3dB): 10 Hz - 22.5 KHz S/N Ratio only DSP Digital Input: 110 dBA S/N Ratio only DSP Analog Input: 106 dBA S/N Ratio Amp + DSP at max. power: 95 dBA THD+N only DSP Digital Input: 0,002 % THD+N only DSP Analog Input: 0,005 % THD+N Amplif. + DSP Analog Input: 0,07 % Crosstalk at 1 Khz only DSP: 90 dB Crosstalk Amplifier + DSP: 45 dB Amp Power @ 4Ω: 8 x 80 watts Amp Power @ 2Ω: 8 x 120 watts Amp Power @ 4Ω Bridged: 4 x 240 watts Amp Power @ 4Ω: 6 x 80 + 1 x 240 watts Amp Power @ 2Ω: 6 x 120 + 1 x 240 w. (4 Ω) F/R EQ: 1-6 ch Gr. & Par./31 poles Effect EQ: 7-8 ch Gr. & Par./11 poles Mute/Solo: Yes, each channel Time Align. (Range/Steps): 0/15 ms / 0.02 ms Max Delay (Cm/Steps): 515 cm / 0.68 cm Polarity: 0/180° Display (included): 1” LCD Display (optional): 3” LCD Touch-Screen Bluetooth Digital Streaming PC/Display Connection: USB/6-pin Mini DIN. Don't miss the chance to upgrade your sound system. While stock last. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Subaru Forester. BEWITH PLUG & PLAY 1080 is a combination audio processor and amplifier that combines a high-quality 8-channel amplifier (50 watts/channel) and 8 channels of digital processing. It can be connected to any aftermarket audio source or factory head unit-having a comprehensive 8 channels of high-level (speaker level) inputs, AUX input/output (2 channels each) and high-resolution optical digital input. It also features fully adjustable software, high-speed and high capacity components, making it the ideal combination processor/amplifier to get the best in-vehicle sound quality. Thank you for supporting us by installing: Focal Flax Evo PS 165 FXE 2ways component & BEWITH 1080 DSP with Amplifier , Pioneer TS-WX130DA active subwoofer. Don’t miss this chance to upgrade your sounds system at our special package. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 New 2020 Toyota RAV4. Thank you for supporting us by installing: Pioneer ZF-9350BT Zapco ADSP-Z8IV-II BEWITH reference L-165RW BEWITH plug and play 2 ch amplifier Don’t miss this chance to upgrade your sound system at our special package. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Kia Cerato Thank you for supporting us by installing: ESB Audio 5000series(5.2K2 ways compo speakers) BEWITH 1080 10ch/8ch DSP processor with amplifier & pioneer Active subwoofer. ESB Audio philosophy of this project is to create a loudspeaker system with an extremely high transient response (dynamic), in order to obtain a music reproduction with a more realistic impact and involvement. To achieve this, the main goal was to reduce the moving masses in order to make the mobile part of the loudspeaker light and fast in its movements, favoring the sudden variations of movement transmitted by the piece of music through the amplifier. Don't miss the chance to upgrade your sound system. While stock last. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 New Toyota Rav4. Thank for supporting us Install: The ZAPCO HDSP-Z16 V is the best hardware that Zapco has ever built, and the numbers attest to that. Although the HDSP is composed of 18 individual pieces put together in a modular version that is easy to adapt or update according to your needs, the background noise and the crosstalk numbers are superb. The end result surpassed even the expectations of the designers and engineers who built it. It took almost three years, but eventually came this unique piece of hardware that we believe will remain in the history of Zapco and set new standards for what is possible in audio reproduction. The numbers are the proof of the design, for example -140 dB of background noise and -115 dB of crosstalk. For a 16-channel device, crosstalk at -115 dB (average around 1 KHz) is proof of the accuracy with which the layout was made. But of course, background noise and crosstalk are not the only numbers that matter in audio devices. All the others, while not so spectacular as -140 dB floor noise, are superb. The digital inputs have 114 dB of A weighted signal/noise and the analog ones 109 dB at rated output. We kept the output voltage at 4 Volts to avoid added distortion of analog preamplification. Distortion of analog and digital inputs are lower than 0.001% at 4 Volt output and lower than 0.00175% at 1 Volt output. The HDSP-V power supply continues to work down to 6 Volts to solve the problem of cars that have the stop-start ignition system. The main processor is a dual core 456 + 456 MHz, 8 and16 channels solution have a 192 and 96 KHz sampling rate and the converters are new 32 bit/784 KHz devices from AKM. Very importantly, it is an HD Player that works at 24 bit/192 KHz integrated with DSP. There is no connection between the Player and the DSP, no PCB, no connectors, no cables. Player and DSP are integrated in one dual core chipset that has a total power of 912 MHz. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 (edited) Audi A3 Thank you for supporting us by installing: Focal and BEWITH plug and play 2ch amplifier, Pioneer active subwoofer. The ES 165 K2 kit is composed of two 6½" (165 mm) woofers and has a very high sensitivity (92.8 dB/oct). The speaker drivers of the ES 165 K2 kit feature the K2 Power line’s famous yellow Kevlar cones. Light, rigid, and with excellent damping, they provide extremely dynamic sound and perfect definition. Paired with the new TMD suspension, there’s no distortion whatsoever. The phase plug in the centre of the cone improves sound dispersion around the vehicle. The treble is reproduced by the two 'M'-shaped aramid-fibre TKM inverted dome tweeters equipped with high-fidelity bi-amplified crossovers. High frequencies (up to 22 kHz) are perfectly reproduced, smoothly, and with precision. Don’t miss this chance to upgrade your sound system at our special package. For more details please call now. WhatsApp 👉 Huat/92325621 Edited February 4, 2021 by SingtradeMarketing Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Toyota Sienta Thank you for supporting us to Install: Zapco HDSP-Z16V Zapco Z150.4AP X 2pcs Zapco ST-1000XM II Focal ES 165KX3 Audible physics ram 3c The ZAPCO HDSP-Z16V is the best hardware that Zapco has ever built, and the numbers attest to that. Although the HDSP is composed of 18 individual pieces put together in a modular version that is easy to adapt or update according to your needs, the background noise and the crosstalk numbers are superb. The end result surpassed even the expectations of the designers and engineers who built it. It took almost three years, but eventually came this unique piece of hardware that we believe will remain in the history of Zapco and set new standards for what is possible in audio reproduction. The numbers are the proof of the design, for example - 140 dB of background noise and -115 dB of crosstalk. For a 16-channel device, crosstalk at -115 dB (average around 1 KHz) is proof of the accuracy with which the layout was made. But of course, background noise and crosstalk are not the only numbers that matter in audio devices. All the others, while not so spectacular as -140 dB floor noise, are superb. The digital inputs have 114 dB of A weighted signal/noise and the analog ones 109 dB at rated output. We kept the output voltage at 4 Volts to avoid added distortion of analog preamplification. Distortion of analog and digital inputs are lower than 0.001% at 4 Volt output and lower than 0.00175% at 1 Volt output. The HDSP-V power supply continues to work down to 6 Volts to solve the problem of cars that have the stop-start ignition system. The main processor is a dual core 456 + 456 MHz, 8 and16 channels solution have a 192 and 96 KHz sampling rate and the converters are new 32 bit/784 KHz devices from AKM. Very importantly, it is an HD Player that works at 24 bit/192 KHz integrated with DSP. There is no connection between the Player and the DSP, no PCB, no connectors, no cables. Don't miss the chance to upgrade your system. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Porsche Boxster Thank you for supporting us to Install: ESB Audio 5000series(5.6K3 ways comp) & Pioneer DMH-ZF9350BT. ESB Audio philosophy of this project is to create a loudspeaker system with an extremely high transient response (dynamic), in order to obtain a music reproduction with a more realistic impact and involvement. To achieve this, the main goal was to reduce the moving masses in order to make the mobile part of the loudspeaker light and fast in its movements, favoring the sudden variations of movement transmitted by the piece of music through the amplifier. Don't miss the chance to upgrade your sound system. While stock last. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Hyundai Avante Thank you for supporting us to Install: Zapco HDSP-Z16V The next generation of Processing. It is hard to tell where science ends and passion begins, when they are running together with the same goal. Zapco's fifth generation processors were born in this area. The passion behind this project, and the driving force behind the required research, has been to create a digital system that had the sound of the best digital and analog systems available today. After all, listening to live music is absolutely an analog experience. The project's goal is not just the purest sound reproduction, but rather the purest sound reproduction in the listening environment, regardless of whether it is in a car, a homeroom, or a concert hall. We brought together scientists from electronics, acoustics, and digital processing, united in the effort to bring this to realization. Zapco introduces the next generation of in-car processing. The Zapco Gen-V. The V-Series of HDSPs brings tuning features and sound quality never before offered in a car DSP. Up to 16 channels mean you can build active systems at every corner of a multichannel sound system. HD means these are available with HD audio players as well. In fact, Zapco HD processors go beyond today's normal 24bit, 96/192 Khz high-resolution standard. This means that today you can reproduce music superior to MP3, and even superior to CD quality. And when the next step in HD reproduction comes the Zapco HDSP will be ready to play it. Included Wi-Fi and optional APTX HD Bluetooth allow the HDSP to connect to all auxiliary “smart” devices. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Subaru Levorg Thanks for supporting us to Install: Focal Flax Evo PS165FXE 2way compo speakers Zapco ST-2X SQ 2ch Sound Quality Class AB Amplifier Pioneer TS-WX130DA Active subwoofer Soundstream 2ways coaxial speaker. 𝕋ℍ𝔼 ℙ𝔼ℝ𝔽𝔼ℂ𝕋 𝔹𝔸𝕃𝔸ℕℂ𝔼 𝕊𝕋𝔸ℕ𝔻𝕀ℕ𝔾 𝕆𝕌𝕋 Evo stands for “evolution”. While our Flax line is synonymous with pure sound, natural midranges, and deep bass, Flax Evo only increases and revisits its assets for a high-end sound, with the same look embodied by the unique flax cone. FOCAL TECHNOLOGIES In addition to the Flax cone, this line incorporates the latest Focal technologies: the TAM Aluminium/Magnesium tweeter and the TMD surround featured on the tweeter, as well as all the speaker drivers for a refined yet powerful acoustic rendering. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Honda Jazz Thank you for supporting us to Install: Audible Physics 6.1 2way component speakers Audison APBX 8 AS active subwoofer Zapco ST-2X SQ 2ch amplifier Audison APBX 8 AS2ACTIVE SUB BOX The Prima APBX 8 AS2 active subwoofer, with 8-inch driver, features a dedicated high-performance amplification module which enhances all the passive box technologies, such as the 2S² (2 Sides / 2 Sounds) design, the Plug & Play terminal block, and ultra-compact size. The amplification module, with power outputs of 250W RMS is developed with he-li technology (high efficiency / low impedance), which thanks to the absence of the DC-DC voltage booster reaches the impressive 90% efficiency level, very close to the theoretical limit of the D-Class. New input stage DBT (Dynamic Bass Tracking) technology allows 100% use of the he-li (High-Efficiency Low Impedance) amplifier power and to enjoy a tense and dynamic bass even at very high listening volumes. Eliminating the voltage booster was made possible thanks to the development of the new dual coil drivers, which inherit all the technological background of the Prima subwoofers, but differ for the ultra-low impedance. This feature ensures a perfect synergy with the he-li (High-Efficiency Low Impedance) technology, maximizing the combination of amplifier, speakers, and sealed box, to obtain low, powerful, and crisp frequencies. The controls section is complete and provides an optimal regulation of the low-frequency emission in the car cabin. The Butterworth low pass filter at 12dB/Oct. with variable cut-off frequency (50-200 Hz) can be bypassed, when used with an AP bit processor with pre-out output dedicated to the sub. The adjustable bass-boost control (0 ÷ 6 dB) at 45 Hz allows the user to emphasize the response in the lower side of the spectrum. Don't miss the chance to upgrade your sound system! WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
SingtradeMarketing 1st Gear February 4, 2021 Author Share February 4, 2021 Toyota Hiace Thank you for supporting us to Install: Focal ES 165 KX3 K2 Power 6-1/2" 3-Way Component Speakers Zapco Z-400.2 AP 2 Ch. Class AB Audiophile Amplifier Zapco ST-2000XM II 2000 Watts Monoblock Class D Amplifier The ES 165 KX3 is a very complete kit offering remarkably extensive frequency response (45 Hz - 22 kHz). Its main advantages are the excellent power handling and the very realistic soundstage. Composed of two 6½" (165 mm) woofers and two 3" (80 mm) mid-range speaker drivers with Kevlar cones, it offers a very rich and dynamic mid-range and very low frequency response (45 Hz). The two bi-amped 'M'-shaped tweeters guarantee a precise high end with perfect definition. Don't miss the chance to upgrade your sound system. While stock lasts. For more details please call now. WhatsApp 👉 Huat/92325621 Link to post Share on other sites More sharing options...
Car air-con
Car air-con
Home Aircon
Home Aircon
Buying Ceiling fan and lighting from JB
Kia Cerato speakers spoilt. Advise pls
Car camera recommendation
