kobayashiGT Internal Moderator September 27, 2017 Share September 27, 2017 Hi Bro, Not too sure if this helps. But this product that is featured in sgCarMart has promised streak-free result. Not too expensive. You can give it a try if you want to. It is called the Invisible glass. http://www.sgcarmart.com/news/events_features.php?AID=3429 https://www.tchub.sg/our-products/automotive-construction/automotive-car-care/invisible-glass-glass-cleaner-spray-22-oz.html Sorry to hijack this thread. I'm new to the forum and do not have enough posts to start a new topic. Can I ask what could be the problem with my windscreen from the attached picture? Whenever light shines on the windscreen, there are lines streaks across the windscreen. I've replaced wipers, tried to clean and scrub the windscreen with windscreen cleaners, dishwashing liquid, baking soda and many other glass cleaners but doesn't solve the problem. I have solar film installed but the lines streaks ONLY appears in the area where the wipers cover. So I presume it's not due to the solar film. Anyone? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 27, 2017 Share September 27, 2017 Diamond paste is actually a very abrasive compound. It has been used to polish crystal on watches. So definitely it will help if you use it to polish the glass. But bigger surface like windscreen is risky to do it yourself. Best is to engage a professional like Glass Fix. You can find them here! They are on our sgCarMart's Recommended Merchant List! http://www.sgcarmart.com/directory/merchant.php?MID=11562 which one is more effective? diamond paste or cerium oxide? 1 Link to post Share on other sites More sharing options...
DACH Supersonic September 27, 2017 Share September 27, 2017 (edited) Try Dr Glass http://www.drglass.com.sg/about-us Type Of Services Windscreen Crack Repair Headlight Restoration Windscreen Watermark Restoration Windscreen Scratches Restoration Windscreen Bonding System Edited September 27, 2017 by DACH 1 Link to post Share on other sites More sharing options...
bemywife 1st Gear November 12, 2020 Share November 12, 2020 Don’t bother with Dr Glass, they are incompetent in polishing! Link to post Share on other sites More sharing options...
techjoe Neutral Newbie May 18, 2022 Share May 18, 2022 (edited) @Bluepica Hey, all windscreens manufactured now are laminated - this means there are two sheets of glass with a sheet of plastic laminate sandwiched in the middle. We call it safety glass as it does NOT shatter it just cracks, actually most vehicles from the 1920's on started using laminate glass as it was much safer for obvious reasons. One thing I would like to add is that driving with a cracked windscreen is actually 3 points and a fine now so just be advised on the risk when driving like this... (www.chipsahoywindscreens.co.uk) Edited May 18, 2022 by techjoe ↡ Advertisement Link to post Share on other sites More sharing options...
2024 Hyundai Kona Electric Debuts: Refreshed Design, 260-Mile Estimated Range
New Hyundai Tucson
New Hyundai Tucson
2017 Hyundai i30
2017 Hyundai i30
