Coffee_boy 1st Gear June 14, 2017 Share June 14, 2017 Make my review already. Why never get my rewards? Really love this brand.. ↡ Advertisement Link to post Share on other sites More sharing options...
Bra85 Neutral Newbie June 14, 2017 Share June 14, 2017 a picture speaks a thousand words after the free trial... just a general review Glass Cleaner - applied as per instructions. wipers have slight juddering Wheel Cleaner - not very impressive, have to manually wash rims Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing Crystal Coat - here is the best part, it very easy to apply and results are superb! Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator June 15, 2017 Share June 15, 2017 Hi Sir, Thank you for your feedback! May I request you to help Bullsone to write a reveiw at Product Guide? http://www.sgcarmart.com/products/listing.php?BRD=Bullsone a picture speaks a thousand words after the free trial... just a general review Glass Cleaner - applied as per instructions. wipers have slight juddering Wheel Cleaner - not very impressive, have to manually wash rims Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing Crystal Coat - here is the best part, it very easy to apply and results are superb! Link to post Share on other sites More sharing options...
AltisOwner Turbocharged June 15, 2017 Share June 15, 2017 Just collected the giveaway items. Selected the Crystal Coat and Micro Fiber Cloths. The cloths come with 3 difference feeling, fine and soft and a bonus gift of Saladdin Deodorizer. Will try the Crystal coat and other items this afternoon and feedback. Thanks to Bullsone. Good morning. This is my review after using the Bullsone products last evening: 1. use the bonus gift Saladdin Deodorizer - follow the instruction and after 10 minutes removed it from the car. Have the fresh and clean air feeling, good smell inside the car. It is good to do it once in every 3-6 months but the only worry for me is because it needs to turn on the engine for at least 15 minutes that may cause over heating (10 mins for deodorizing and 5 mins for ventilating). 2. Crystal Coat - this is a very good product, easy to apply just spray and wipe it off and gave a very shinning and smooth surface. I put the bottle on and it just slide down. The result is much better than the quick wax I was using. 3. The Superfine cloths (40cm x 40cm) - it comes with 3 types of cleaning cloths. The textures are good, soft and easy to absorb water. It makes cleaning much easier. I may consider to try the Crystal Bubble car Shampoo once my Shampoo used up. Link to post Share on other sites More sharing options...
AltisOwner Turbocharged June 15, 2017 Share June 15, 2017 (edited) a picture speaks a thousand words after the free trial... just a general review Glass Cleaner - applied as per instructions. wipers have slight juddering Wheel Cleaner - not very impressive, have to manually wash rims Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing Crystal Coat - here is the best part, it very easy to apply and results are superb! "Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing" Hi Brother Bra85, would appreciate if you could give little more details with regard to Shampoo, please. What do you mean gona scratch while washing if surface is not smooth? Thanks in advance. Edited June 15, 2017 by AltisOwner Link to post Share on other sites More sharing options...
Bra85 Neutral Newbie June 15, 2017 Share June 15, 2017 "Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing" Hi Brother Bra85, would appreciate if you could give little more details with regard to Shampoo, please. What do you mean gona scratch while washing if surface is not smooth? Thanks in advance. the shampoo is spray on type.. just spray and wipe the car.. so unless ur car is free from dirt/sand.. u will be rubbing these dirt/sand together with the shampoo.. 1 Link to post Share on other sites More sharing options...
AltisOwner Turbocharged June 15, 2017 Share June 15, 2017 the shampoo is spray on type.. just spray and wipe the car.. so unless ur car is free from dirt/sand.. u will be rubbing these dirt/sand together with the shampoo.. Thanks Brother Bra85. You are referring to the waterless 2 in1 cleaner. Link to post Share on other sites More sharing options...
Bra85 Neutral Newbie June 15, 2017 Share June 15, 2017 Thanks Brother Bra85. You are referring to the waterless 2 in1 cleaner. nope..im referring to Crystal Shampoo (step 1) Link to post Share on other sites More sharing options...
AltisOwner Turbocharged June 15, 2017 Share June 15, 2017 nope..im referring to Crystal Shampoo (step 1) OIC....I think Bullsone named it as "shampoo" is a bit misleading. Shampoo should be diluted with water for washing a whole car. Thank you once again. Link to post Share on other sites More sharing options...
Bullsone-SG 1st Gear June 15, 2017 Share June 15, 2017 the shampoo is spray on type.. just spray and wipe the car.. so unless ur car is free from dirt/sand.. u will be rubbing these dirt/sand together with the shampoo.. Hi Sir, for the Crystal Car Shampoo, please wet your car before spraying on the shampoo as it is a high foaming shampoo. Once you have finished cleaning your car with a sponge/cloth, rinse with clean water and dry . Benefits of Using Crystal Car Shampoo instead of regular shampoo Being PH neutral, it is safe to use on all paintwork and especially designed for cars with PPS (Crystal Coat, Glass Coating, Ceramic Coat) as it will enhance the longevity of the PPS No need to use a bucket! Highly concentrated formula means you only need to wet your car with water and spray on to clean your car, finally rinse off your car with clean water Link to post Share on other sites More sharing options...
Coffee_boy 1st Gear June 15, 2017 Share June 15, 2017 I joined but have yet to receive PM from Admin Me too.. How to know if i am choosen? Link to post Share on other sites More sharing options...
Sdf4786k Twincharged June 15, 2017 Share June 15, 2017 a picture speaks a thousand words after the free trial... just a general review Glass Cleaner - applied as per instructions. wipers have slight juddering Wheel Cleaner - not very impressive, have to manually wash rims Shampoo - Nice smell, easy to apply. Downside is that you have to ensure the surface is smooth if not you gona scratch ur car while washing Crystal Coat - here is the best part, it very easy to apply and results are superb! yes.. that one is very true.. Link to post Share on other sites More sharing options...
Achtung 6th Gear June 17, 2017 Share June 17, 2017 Went to collect my stuff on Friday, 16 June 2017. Was shocked when the lady at SG Car Mart claimed that some with the nick A*K*ng said that I gave him my free gift, which was the Salladin de-ordourizer. Are members here dishonest or that the lady there is careless? I really wonder. Link to post Share on other sites More sharing options...
spzen 2nd Gear June 19, 2017 Author Share June 19, 2017 Went to collect my stuff on Friday, 16 June 2017. Was shocked when the lady at SG Car Mart claimed that some with the nick A*K*ng said that I gave him my free gift, which was the Salladin de-ordourizer. Are members here dishonest or that the lady there is careless? I really wonder. Hi Achtung, Apologies for the miscommunication, please let me clarify. It was just the internal note I left at the inventory system that I passed your Saladdin Deodorizer item to another member as the item was out of stock, while the other member came here to collect first. So, it's just a reminder to myself that I need to allocate 1 Saladdin Deodorizer for you once the item is restocked. Once again apologies for the confusion. Thank you. Link to post Share on other sites More sharing options...
spzen 2nd Gear June 19, 2017 Author Share June 19, 2017 Members who are ready to groom their car 1. Buadongdong 2. SuPerBoRed 3. Sdf4786k 4. keanC 5. Cheong72 6. Johnson79 7. Little_prince 8. mycar888 9. Kurty 10. sbliew 11. Nutty 12. Xingkia 13. Rootkie 14. Keromond 15. Mini19 16. Bra85 17. Itachino 18. Solar 19. Aukang 20. Will_I_Am 21. Achtung 22. Heman75 23. hsl118 24. hpy090909 25. Multi 26. Deeq 27. Insaneguy 28. AltisOwner 29. alex976 30. Fuelsaver 31. Kys99 For selected premium members who have completed the payment, you may collect your Bullsone items at venue & timing you have chosen during the registration! 30 first reviewers who are qualified to receive Bullsone Bullsoneshot Pro (worth $19.90) 1. Sdf4786k 2. Cheong72 3. mycar888 4. keanC 5. Nutty 6. Kurty 7. Rootkie 8. Johnson79 9. Little_prince 10. sbliew 11. Heman75 12. Raychay 13. Sony 14. Buadongdong 15. AltisOwner You may self-collect the item at this timing and venue: SGCM Office, Monday - Friday, 10 AM - 5 PM. Thank you! Link to post Share on other sites More sharing options...
Achtung 6th Gear June 19, 2017 Share June 19, 2017 Hi Achtung, Apologies for the miscommunication, please let me clarify. It was just the internal note I left at the inventory system that I passed your Saladdin Deodorizer item to another member as the item was out of stock, while the other member came here to collect first. So, it's just a reminder to myself that I need to allocate 1 Saladdin Deodorizer for you once the item is restocked. Once again apologies for the confusion. Thank you. No problem Link to post Share on other sites More sharing options...
spzen 2nd Gear June 19, 2017 Author Share June 19, 2017 Me too.. How to know if i am choosen? Hello! 1) You have to meet the criteria of joining this giveaway (Premium member, Neutral Newbie needs to at least have 20 posts) 2) Register for the giveaway. If you are qualified, we will send you the PM for the payment link. 3) Once payment is made, you can collect the items, try it out, and write 2 reviews of the items that you tried out. 4) First 30 members who submitted 2 reviews will receive Bullsone Bullsoneshot Pro Hope that helps! Link to post Share on other sites More sharing options...
Buadongdong Twincharged June 19, 2017 Share June 19, 2017 Members who are ready to groom their car 1. Buadongdong 2. SuPerBoRed 3. Sdf4786k 4. keanC 5. Cheong72 6. Johnson79 7. Little_prince 8. mycar888 9. Kurty 10. sbliew 11. Nutty 12. Xingkia 13. Rootkie 14. Keromond 15. Mini19 16. Bra85 17. Itachino 18. Solar 19. Aukang 20. Will_I_Am 21. Achtung 22. Heman75 23. hsl118 24. hpy090909 25. Multi 26. Deeq 27. Insaneguy 28. AltisOwner 29. alex976 30. Fuelsaver 31. Kys99 For selected premium members who have completed the payment, you may collect your Bullsone items at venue & timing you have chosen during the registration! 30 first reviewers who are qualified to receive Bullsone Bullsoneshot Pro (worth $19.90) 1. Sdf4786k 2. Cheong72 3. mycar888 4. keanC 5. Nutty 6. Kurty 7. Rootkie 8. Johnson79 9. Little_prince 10. sbliew 11. Heman75 12. Raychay 13. Sony 14. Buadongdong 15. AltisOwner You may self-collect the item at this timing and venue: SGCM Office, Monday - Friday, 10 AM - 5 PM. Thank you! Lai Lai Lai.. lets all meet for lunch.. @tianmo, wanna join us?? @pchou & @kobayashiGT, what say you?? ↡ Advertisement Link to post Share on other sites More sharing options...
Revol Car Grooming
Revol Car Grooming
M’sia Girl Asks Customer For Restaurant Review Before Entering, Patron Gives Feedback By Shaking Head
New Age Polish --> Volkswagen Portfolio
Recommended places for Car Wash
Pump Petrol In JB - Worth it
New Age Polish --> Hyundai Portfolio
