peasant 5th Gear June 19, 2019 Share June 19, 2019 How's the latest surface Pro 6? Did you spec it up? Been looking to go for it... My 4yr old macbook pro just wouldn't die.... Is lighter than pro 2, Battery life approx 4-6 hours. i just added some RAM. my pro 2 is about 6 yr old, i was waiting for it to kaput too. I bought the pro 2 in US and the display failed within 1 month. Microsoft SG unable to support me because it is not a local set. i need to send it to US for 1to1 exch ↡ Advertisement Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 1, 2019 Share July 1, 2019 Honestly abit disappointed. The unit works well though. Easy to setup, app is useful too. But maybe my expectation is too high. Vacuum works well but imo, abit too slow. It might be more useful if i'm going out and let the robot run on its own. Mopping, not very effective. Maybe i should put some diluted floor detergent. Then again, it might be faster (& cleaner) to mop manually. Anyone knows how to set a daily scheduled cleaning? I will use a few more times to determine if this is a keep or flip. 2 Link to post Share on other sites More sharing options...
Jman888 Moderator July 1, 2019 Share July 1, 2019 Capture.PNG Honestly abit disappointed. The unit works well though. Easy to setup, app is useful too. But maybe my expectation is too high. Vacuum works well but imo, abit too slow. It might be more useful if i'm going out and let the robot run on its own. Mopping, not very effective. Maybe i should put some diluted floor detergent. Then again, it might be faster (& cleaner) to mop manually. Anyone knows how to set a daily scheduled cleaning? I will use a few more times to determine if this is a keep or flip. what is the difference between this and roborock? I am thinking of getting the roborock as recommended by tank. Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 1, 2019 Share July 1, 2019 what is the difference between this and roborock? I am thinking of getting the roborock as recommended by tank. https://smartrobotreviews.com/reviews/roborock-s6-vs-viomi-v2.html I think viomi can set the room cleaning as well by determining the area using a function called virtual wall. Not too sure though, i only played with it for awhile. Link to post Share on other sites More sharing options...
Lala81 Hypersonic July 1, 2019 Share July 1, 2019 https://smartrobotreviews.com/reviews/roborock-s6-vs-viomi-v2.html I think viomi can set the room cleaning as well by determining the area using a function called virtual wall. Not too sure though, i only played with it for awhile. how much did u get this for? I'm thinking of getting one just for mopping during 11.11 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 1, 2019 Share July 1, 2019 how much did u get this for? I'm thinking of getting one just for mopping during 11.11 Slightly less than 400sgd. For now, I would not recommend for mopping. too slow and not very clean w/o detergent. If put detergent, maybe you need to go through a 2nd or 3rd round with water which will take 3x as much time. Vacuum on the other hand is okay. Just remove things on the floor, on the bot and go out have your meal. Should finish in about 1.5hrs for a 5 room flat. Link to post Share on other sites More sharing options...
Mustank Hypersonic July 1, 2019 Share July 1, 2019 Capture.PNG Honestly abit disappointed. The unit works well though. Easy to setup, app is useful too. But maybe my expectation is too high. Vacuum works well but imo, abit too slow. It might be more useful if i'm going out and let the robot run on its own. Mopping, not very effective. Maybe i should put some diluted floor detergent. Then again, it might be faster (& cleaner) to mop manually. Anyone knows how to set a daily scheduled cleaning? I will use a few more times to determine if this is a keep or flip. Haha all robots need time to workBest is when you put it on timer in app Or when you go out to eat, you ask it to work Asking it to work when you at home, not a fun thing to do 1 Link to post Share on other sites More sharing options...
Jman888 Moderator July 1, 2019 Share July 1, 2019 if can remote control from work when to start, I can view from my ip camera to 'monitor' it, make sure it doesn't eat snake Link to post Share on other sites More sharing options...
Mustank Hypersonic July 1, 2019 Share July 1, 2019 if can remote control from work when to start, I can view from my ip camera to 'monitor' it, make sure it doesn't eat snake These robots got map in app oneYou will tell you they cover where, how many meter2, when start when end, damn.... seriously insane Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 2, 2019 Share July 2, 2019 Haha all robots need time to work Best is when you put it on timer in app Or when you go out to eat, you ask it to work Asking it to work when you at home, not a fun thing to do Thats what i figure. The droning sound can be exhausting to listen after awhile. On it last night before going out for dinner. Got stuck a couple of times. All in all, vacuum not bad. One problem is that i cant enable the timer to work in Mihome app. Will try out the Viomi app later today. These robots got map in app one You will tell you they cover where, how many meter2, when start when end, damn.... seriously insane For mine, the app only works in the house. Went out and the connection will drop. Yours able to view the status when you are out? Link to post Share on other sites More sharing options...
Mustank Hypersonic July 2, 2019 Share July 2, 2019 Thats what i figure. The droning sound can be exhausting to listen after awhile. On it last night before going out for dinner. Got stuck a couple of times. All in all, vacuum not bad. One problem is that i cant enable the timer to work in Mihome app. Will try out the Viomi app later today. For mine, the app only works in the house. Went out and the connection will drop. Yours able to view the status when you are out? Yes my one I can ask the robot to work even when I am not at homeBut my one is rockrobo 2 The xiaomi robot with mop one Link to post Share on other sites More sharing options...
Buadongdong Twincharged July 4, 2019 Share July 4, 2019 Loot came late. But better than never arrive. 9 Link to post Share on other sites More sharing options...
Ender Hypersonic July 4, 2019 Share July 4, 2019 Got two pairs of new running shoes, to prep for end of year SCSM. A past season Nike Pegasus 35 and a current Nike Odyssey React Flyknit 2. The 2nd one is abit kiddish, but it's the cheapest design/color among the model when I bought them. 12 Link to post Share on other sites More sharing options...
inlinesix Supersonic July 4, 2019 Share July 4, 2019 Got two pairs of new running shoes, to prep for end of year SCSM. A past season Nike Pegasus 35 and a current Nike Odyssey React Flyknit 2. The 2nd one is abit kiddish, but it's the cheapest design/color among the model when I bought them. How much did you pay for Pegasus 35? I compared 35 vs 36. Visually not much diff Link to post Share on other sites More sharing options...
Ender Hypersonic July 4, 2019 Share July 4, 2019 How much did you pay for Pegasus 35? I compared 35 vs 36. Visually not much diff $120. The changes in 36 in really not much from review. The most obvious change is the tongue, coz some people complain the 35 is protrudes too much. Anyway from what I gather from reviews, no point 'upgrading' to 36, the changes are minimal, midsole is the same. 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 4, 2019 Share July 4, 2019 Yes my one I can ask the robot to work even when I am not at home But my one is rockrobo 2 The xiaomi robot with mop one tried again last night and i can view the status when out. But after go back charging dock, the connection was lost. Still cant seem to find the timer options on the mihome app though. Link to post Share on other sites More sharing options...
Mustank Hypersonic July 4, 2019 Share July 4, 2019 tried again last night and i can view the status when out. But after go back charging dock, the connection was lost. Still cant seem to find the timer options on the mihome app though. Maybe you house Wi-Fi the connect no goodYou see whether at the charging dock area, the Wi-Fi strgenth good or not This app call Wi-Fi sweet spot can see the strength You got add the robot into the mi home app? If added, then you click into that robot Then top right hand corner of the page got 3 dot Lols like this ... Click the ... click timer Then you can add time to vacuum alrrady 2 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 4, 2019 Share July 4, 2019 Maybe you house Wi-Fi the connect no good You see whether at the charging dock area, the Wi-Fi strgenth good or not This app call Wi-Fi sweet spot can see the strength You got add the robot into the mi home app? If added, then you click into that robot Then top right hand corner of the page got 3 dot Lols like this ... Click the ... click timer Then you can add time to vacuum alrrady Thanks. My living room no space to place the dock so I've put in the adjacent room. Strength is okay i guess. I've went to the options menu before. No timer option but there is a dnt option. Description is start at the setting period for each day. Going into the option. There is a start time and end time. Which I find weird. ↡ Advertisement Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
KSL City shopping mall in JB
Any good buy at Daiso?
Where can get big-size lady's court shoes?
Capital 21 - largest mall in JB
Shopping Malls Offering Vouchers For Shopping With Them
