Lala81 Hypersonic March 29, 2022 Share March 29, 2022 7 minutes ago, 13177 said: I never like vacuum. Mop rebot i am interested to try, but after i got one, find that i use magiccleaner wipe faster and cleaner to sweep the floor. Lucky that time i bough one cheap mop robot to try. Lol. I used to wipe with bucket and a cloth. At least that's how I was brought up. Nowadays I rarely do that. Or only clean it when moving furniture around. Too time consuming. Just use vacuum robot or hand held vacuum. But also lesser since the main issue in my house is dog hairballs. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Jman888 Moderator March 29, 2022 Share March 29, 2022 3 hours ago, RH1667 said: ok, waiting for review. Must make sure buy the " correct " " good to use " one, else, wasting the amount paid is one thing, the long long period of " last time you bought XXX also say is to help, but end up no use " nagging is more deadly 😁 done with the first clean, overall very happy with the result. As my place is next to a bto construction site, though it is in the last phrase of completion, the house still quite dusty everyday. 1. weight, it is quite heavy for a some size housewife to 'carry/lifting' it around, but the good thing is you dun have to. The roller 'roll' itself forward in quite a fast speed, I was pull by it when first started. When pull front and back for mopping, the pull back part need a tiny bit of strength as the roller is going forward. 2. the cleaning agent come with the packaging is very good, for 900ml of clean water only need 1/3-1/2 of the cap, which is quite small. The result my floor feel smoother than the weekly manual mop with my own concoction of detergent +dettol +vinegar + baking soda... 3. After mopping about area of 600sqft, power left 70% and more than half tank of clean water under the econ mode, Then let it do a quick self cleaning (there is a stronger self cleaning mode which i will probably do it once a month). 4. the dirty water is ... really dirty although I just mopped the floor 2 days ago and vaccum before trying it. It does a better job than my manual mopping cos I can see the tough stain have been scrubbed off that i couldn't do it earlier (maybe i weak). 5. the voice instructions is quite pleasant, you can set the language and volume level. 6. it can only bend up to 140deg, which also depends on the height of the furniture, hence can't reach the inner part under the sofa, cabinets and beds. overall very happy with this 2 in 1 vacuum mop, i think in future I will skip the vacuum part and just do both at the same time. * this is not a sponsored review and not even sponsor by wife for doing the house work 7 2 Link to post Share on other sites More sharing options...
RH1667 Hypersonic March 29, 2022 Share March 29, 2022 (edited) 9 minutes ago, Jman888 said: done with the first clean, overall very happy with the result. As my place is next to a bto construction site, though it is in the last phrase of completion, the house still quite dusty everyday. 1. weight, it is quite heavy for a some size housewife to 'carry/lifting' it around, but the good thing is you dun have to. The roller 'roll' itself forward in quite a fast speed, I was pull by it when first started. When pull front and back for mopping, the pull back part need a tiny bit of strength as the roller is going forward. 2. the cleaning agent come with the packaging is very good, for 900ml of clean water only need 1/3-1/2 of the cap, which is quite small. The result my floor feel smoother than the weekly manual mop with my own concoction of detergent +dettol +vinegar + baking soda... 3. After mopping about area of 600sqft, power left 70% and more than half tank of clean water under the econ mode, Then let it do a quick self cleaning (there is a stronger self cleaning mode which i will probably do it once a month). 4. the dirty water is ... really dirty although I just mopped the floor 2 days ago and vaccum before trying it. It does a better job than my manual mopping cos I can see the tough stain have been scrubbed off that i couldn't do it earlier (maybe i weak). 5. the voice instructions is quite pleasant, you can set the language and volume level. 6. it can only bend up to 140deg, which also depends on the height of the furniture, hence can't reach the inner part under the sofa, cabinets and beds. overall very happy with this 2 in 1 vacuum mop, i think in future I will skip the vacuum part and just do both at the same time. * this is not a sponsored review and not even sponsor by wife for doing the house work Thank you!! 👍 Point 1 will be concern as if that is the case, than it will become my full and sole responsibility to do the floor cleaning in future 😅 Edited March 29, 2022 by RH1667 2 Link to post Share on other sites More sharing options...
Jman888 Moderator March 29, 2022 Share March 29, 2022 ordered Sunday evening and received today. 8 Link to post Share on other sites More sharing options...
therock Supersonic March 29, 2022 Share March 29, 2022 8 hours ago, Kb27 said: Been paying 20 cent for packet food. Thought I try to bring container. So I bought this: Double-wall insulated, with silicone cap seal, with 2 mini container inside. Food not included. 😁 https://www.heapseng.com/food-jars-lunch-boxes/double-stainless-steel-vacuum-insulated-thermal-food-jar-p-4503.html?cPath=1_25&osCsid=dsmapo5uki115lc4bfhs1d83o5 Endo is my gold standard for food containers... keeps warm for hours and is truly watertight... https://shopee.sg/Endo-Pro-2L-Double-Stainless-Steel-Vacuum-Insulated-Thermal-Food-Carrier-CX-4013-i.312861467.6555798313 6 Link to post Share on other sites More sharing options...
Kb27 Supersonic March 29, 2022 Share March 29, 2022 7 hours ago, 13177 said: How muchie? From where? I hope cheap one to try. It's useful so far, not a white elephant. 😁 https://shopee.sg/Vacuum-Insulated-Stainless-Steel-Thermos-Lunch-Box-Food-Jar-1L-i.12480907.2038815519 4 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 30, 2022 Share March 30, 2022 15 hours ago, Jman888 said: ordered Sunday evening and received today. I am quite sure you just took your bonus. 😂 5 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 30, 2022 Share March 30, 2022 37 minutes ago, kobayashiGT said: I am quite sure you just took your bonus. 😂 MCF buy car full cash one. i dont think need to wait for bonus to buy iphoon. 5 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 30, 2022 Share March 30, 2022 24 minutes ago, Stratovarius said: MCF buy car full cash one. i dont think need to wait for bonus to buy iphoon. he also bought a vacuum plus mop machine mah. hahaha. 😂 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 31, 2022 Share March 31, 2022 @Jman888 Just in case you need one more. https://www.greatdeals.com.sg/2022/03/22/tineco-ifloor-wet-dry-vacuum-qoo10-sale 4 Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 31, 2022 Share March 31, 2022 @kobayashiGT Bulky sia!! 1 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 31, 2022 Share March 31, 2022 20 minutes ago, Hamburger said: @kobayashiGT Bulky sia!! train ur arm. If not you buy for your wife lor. hahahahahaha 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 31, 2022 Share March 31, 2022 On 3/29/2022 at 6:19 PM, Kb27 said: I hope cheap one to try. It's useful so far, not a white elephant. 😁 https://shopee.sg/Vacuum-Insulated-Stainless-Steel-Thermos-Lunch-Box-Food-Jar-1L-i.12480907.2038815519 How to dabao rice? At first I thought this is for baby food or porridge. Lol Link to post Share on other sites More sharing options...
Jman888 Moderator March 31, 2022 Share March 31, 2022 2 minutes ago, Lala81 said: How to dabao rice? At first I thought this is for baby food or porridge. Lol is like dabao ccp, rice, veg, meat etc. it is able to keep warm till lunch time. My wife still pack lunch this way for herself and my girl occasionally. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic March 31, 2022 Share March 31, 2022 24 minutes ago, Jman888 said: is like dabao ccp, rice, veg, meat etc. it is able to keep warm till lunch time. My wife still pack lunch this way for herself and my girl occasionally. The jar mouth so small. How the stall scoop inside for u. I have food jars also. But dabao best to have those tingkat size at least bah the opening. Link to post Share on other sites More sharing options...
Kb27 Supersonic March 31, 2022 Share March 31, 2022 1 hour ago, Lala81 said: The jar mouth so small. How the stall scoop inside for u. I have food jars also. But dabao best to have those tingkat size at least bah the opening. Yea, the opening is a bit small, I just use this for noodle soup at the moment, since I'm always buying prawn noodle soup, takeaway. 3 Link to post Share on other sites More sharing options...
Jman888 Moderator March 31, 2022 Share March 31, 2022 On 3/28/2022 at 8:52 PM, therock said: My free oven arrived even before the toothbrushes 🙂 my free toaster oven also delivered but main product not here yet 7 Link to post Share on other sites More sharing options...
Tohto Hypersonic April 1, 2022 Share April 1, 2022 My coffee machine that used for about 8yrs is faulty. Loot a new one. ↡ Advertisement 12 Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
Online shopping fever
Worst Shopping Mall Carpark
KSL City shopping mall in JB
Any good buy at Daiso?
