Lala81 Hypersonic December 18, 2022 Share December 18, 2022 (edited) 7 hours ago, Mkl22 said: Stainless steel? yup. Well strictly speaking most of these skillets/pans for frying/cooking usually have multiple layers of different materials, given the modern manufacturing processes and material sciences. Only cast iron/uncoated claypots are really WYSIWYG Edited December 18, 2022 by Lala81 ↡ Advertisement Link to post Share on other sites More sharing options...
Kb27 Supersonic December 18, 2022 Share December 18, 2022 2 hours ago, Lala81 said: Happy Call non stick uses PTFE (ie Teflon). Ceramic cookware uses a silicon dioxide type of coating, of which is even more uncertain what health risks is involved. There are only 2 so called true traditional non stick, - one is enamel/porcelain covered cookwhere like your Le Creuset cast iron dutch oven or your traditional enameled chinese claypots - 2nd one is carbon steel/cast iron which has polymerised oil acting as non stick coating Whether polymerised oil is so called safe is debatable also given how oil reacts under repeated heating, but that's another topic for another day. But these are the two traditional methods that at least have some 100-200 years of history. Recently bought a replacement rice cooker with stainless steel pot. I thought it might be healthier than aluminium pot. Less aluminium to ingest. 😁 My pressure cooker pot is non-stick coated teflon. It seems to rub off on my food, After heating (keep warm) for a long period of time, the food taste weird with metallic taste. Now, I found a SS pot, and will try cooking and see if it's due to the teflon. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 18, 2022 Share December 18, 2022 20 minutes ago, Kb27 said: Recently bought a replacement rice cooker with stainless steel pot. I thought it might be healthier than aluminium pot. Less aluminium to ingest. 😁 My pressure cooker pot is non-stick coated teflon. It seems to rub off on my food, After heating (keep warm) for a long period of time, the food taste weird with metallic taste. Now, I found a SS pot, and will try cooking and see if it's due to the teflon. I'm using the same brand as you I guess, the Sona one which you rec to me years ago. Mine is fine, but i dont keep it prolonged heated. I just cook and remove it. No visible scratches to the interior over the years, I try to be careful when i use my metal scoop with drain holes. My rice cooker also usual teflon coated. But that one only use the plastic rice spatula, so should be minimal damage. Link to post Share on other sites More sharing options...
Kb27 Supersonic December 19, 2022 Share December 19, 2022 17 hours ago, Lala81 said: I'm using the same brand as you I guess, the Sona one which you rec to me years ago. Mine is fine, but i dont keep it prolonged heated. I just cook and remove it. No visible scratches to the interior over the years, I try to be careful when i use my metal scoop with drain holes. My rice cooker also usual teflon coated. But that one only use the plastic rice spatula, so should be minimal damage. I bought a ss pot, after measuring, from shopee. It fit the Sona, except it's about 2mm thicker, just a little bit harder to close the top due to the silicone seal. So far, I've cooked rice and peanut soup. There is no weird taste unlike the original pot, after a long time at "keep warm". My old pot coating may be "wearing out", I dunno. The new ss pot is a nice investment. 😁 Now I can cook with acidic vinegar without much concern. The pressure cooker is very useful to me. I like to start cooking at "Saute" with cover off, oil, garlic, onion, veg/meat. Then I just add uncooked rice and water. Cover it, switch to pressure cooking "White rice". And it's done. Then I leave at keep warm. I cooked enough for lunch and dinner. Lazy way, but I get 2 meals and only 1 pot to clean. 2 Link to post Share on other sites More sharing options...
therock Supersonic December 19, 2022 Share December 19, 2022 A little zen after the hectic past week... 5 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 21, 2022 Share December 21, 2022 1212 loot has arrived...recommended by a bro here... Always skeptical about BT earpiece...this one is not bad for the price under 40 dollah...deafening noise cancellation...immediately couldn't hear my own voice when I put them on while talking to my son...shall try it out on the noisy mrt tomorrow 😁 No overwhelming bass, decent treble tho a bit more will be nice, vocal is clear albeit a bit hollow. The ear pods need some adjustments to get the best balanced sound stage... Just as good as my wired seinheiser earpiece at similar price. 8/10 from me for the performance and price. Only gripe is the super tiny print on the manual...so much wasted space...need to also loot a magnify glass...😅 6 Link to post Share on other sites More sharing options...
Dafansu Turbocharged December 21, 2022 Share December 21, 2022 18 minutes ago, mersaylee said: 1212 loot has arrived...recommended by a bro here... Always skeptical about BT earpiece...this one is not bad for the price under 40 dollah...deafening noise cancellation...immediately couldn't hear my own voice when I put them on while talking to my son...shall try it out on the noisy mrt tomorrow 😁 No overwhelming bass, decent treble tho a bit more will be nice, vocal is clear albeit a bit hollow. The ear pods need some adjustments to get the best balanced sound stage... Just as good as my wired seinheiser earpiece at similar price. 8/10 from me for the performance and price. Only gripe is the super tiny print on the manual...so much wasted space...need to also loot a magnify glass...😅 Soundpeats? I owned one, good product at very reasonable price 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic December 21, 2022 Share December 21, 2022 9 minutes ago, Dafansu said: Soundpeats? I owned one, good product at very reasonable price Yessi, the "mini" but performance although not mega but definitely not mini either 😁 Link to post Share on other sites More sharing options...
Jman888 Moderator December 21, 2022 Share December 21, 2022 32 minutes ago, mersaylee said: Yessi, the "mini" but performance although not mega but definitely not mini either 😁 I also bought one (different model) to try, ok for day to day listening while traveling, but the sound stage not good for listening to acoustic and vocal songs. 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic December 23, 2022 Share December 23, 2022 Buy buy buy!!! 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic December 23, 2022 Share December 23, 2022 12 minutes ago, Mustank said: Buy buy buy!!! haha steam sale again? 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged December 23, 2022 Share December 23, 2022 Backside itchy again. Got this 😛 4 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic December 23, 2022 Share December 23, 2022 24 minutes ago, Lala81 said: haha steam sale again? I buy god of war from epic bec they got 25% discount Just nice got buy 3080 then can play shadow of tomb raider at 1440p ultra full ray tracing. CPU 7600x max ultilisation 30%. Gpu max 90%. 32gb Ram 20%. Anyway I can’t see 1080, 2k and 4k difference one. Eyes can’t see shit. Haha 2 years later then buy cyberpunk goty edition. Now too many games I never play before. 10 years of games never play before 4 1 Link to post Share on other sites More sharing options...
RadX Moderator December 26, 2022 Share December 26, 2022 Last loot for 2022! 17 Link to post Share on other sites More sharing options...
Arogab Turbocharged December 26, 2022 Share December 26, 2022 Looted this for my customer who is also my close buddy. An excuse to tell him I am not doing countdown with him as I will be going fishing. Haha 8 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged December 26, 2022 Share December 26, 2022 17 minutes ago, RadX said: Last loot for 2022! Nice 1 Link to post Share on other sites More sharing options...
Freeder Hypersonic December 26, 2022 Share December 26, 2022 51 minutes ago, RadX said: Last loot for 2022! Wah.. nice exquisite loot.. Goes well with your coupe..😂 2 1 Link to post Share on other sites More sharing options...
Scorpiong 3rd Gear December 26, 2022 Share December 26, 2022 1 hour ago, RadX said: Last loot for 2022! Bought from Rolex AD or gray market? ↡ Advertisement Link to post Share on other sites More sharing options...
Shopee Singapore
Shopee Singapore
Online shopping fever
Worst Shopping Mall Carpark
KSL City shopping mall in JB
Any good buy at Daiso?
