w7_lee 4th Gear May 6, 2018 Share May 6, 2018 (edited) Main button is to enable the cruise function. SET button is use to set (lock-in) the speed you want to cruise at; i.e. you drive to the speed you want to cruise at, then press SET. While auto cruising, you can adjust your cruising speed by using the RES(+) or SET (-) to increase or decrease the speed respectively. Cancel is to cancel the auto cruise. Stepping on the brake while auto cruising cancels the auto cruising. Mine don't have the other 2 buttons, think is the newer Sensing model. But from what I see on the internet, the lower button (when enabled) will keep the vehicle inside the lane. Of course, lane marking must be clear to the software/detector. The right button is to maintain your distance with the front car; if the front car slows down while you are auto cruising & it is enabled, your car 'should' slow down too. You will have to test it out. Good luck. Edited May 6, 2018 by w7_lee ↡ Advertisement Link to post Share on other sites More sharing options...
Eye Neutral Newbie May 6, 2018 Share May 6, 2018 Main button is to enable the cruise function. SET button is use to set (lock-in) the speed you want to cruise at; i.e. you drive to the speed you want to cruise at, then press SET. While auto cruising, you can adjust your cruising speed by using the RES(+) or SET (-) to increase or decrease the speed respectively. Cancel is to cancel the auto cruise. Stepping on the brake while auto cruising cancels the auto cruising. Mine don't have the other 2 buttons, think is the newer Sensing model. But from what I see on the internet, the lower button (when enabled) will keep the vehicle inside the lane. Of course, lane marking must be clear to the software/detector. The right button is to maintain your distance with the front car; if the front car slows down while you are auto cruising & it is enabled, your car 'should' slow down too. You will have to test it out. Good luck. WOW thank you very much for the inputs, greatly appreciated. I actually suspect the "MAIN" button is for auto cruising activation but did not try as "MAIN" really doesn't suggest a lot about it. But the older model had a very clear "Cruise" button at the same location as the "Main" on my model. I travel on the TPE quite often during off peak hours, will try out the cruising function :) Link to post Share on other sites More sharing options...
Kopites Supersonic May 7, 2018 Share May 7, 2018 Main button is to enable the cruise function. SET button is use to set (lock-in) the speed you want to cruise at; i.e. you drive to the speed you want to cruise at, then press SET. While auto cruising, you can adjust your cruising speed by using the RES(+) or SET (-) to increase or decrease the speed respectively. Cancel is to cancel the auto cruise. Stepping on the brake while auto cruising cancels the auto cruising. Mine don't have the other 2 buttons, think is the newer Sensing model. But from what I see on the internet, the lower button (when enabled) will keep the vehicle inside the lane. Of course, lane marking must be clear to the software/detector. The right button is to maintain your distance with the front car; if the front car slows down while you are auto cruising & it is enabled, your car 'should' slow down too. You will have to test it out. Good luck. my previous x model. any idea whether we can able to install the sensing on 16 model. Link to post Share on other sites More sharing options...
w7_lee 4th Gear May 7, 2018 Share May 7, 2018 I also dunno leh, you probably need to consult someone more professional. But I think maybe not so straight forward, likely need additional hardware change (for lane departure & following distance sensors) + plus software upgrade to work with the additional hardware. Link to post Share on other sites More sharing options...
Kopites Supersonic May 7, 2018 Share May 7, 2018 I also dunno leh, you probably need to consult someone more professional. But I think maybe not so straight forward, likely need additional hardware change (for lane departure & following distance sensors) + plus software upgrade to work with the additional hardware. thanks. no worry. just backside itchy. Link to post Share on other sites More sharing options...
LYC 3rd Gear May 7, 2018 Share May 7, 2018 May I know when you change your vezel gearbox oil, the first time? I changed mine at 20k in already almost black liao. My understanding is that it should be blood red colour. I mainly drive with start stop conditions, so decided to change early. Coming to 40k soon, gonna change again. Better be safe then sorry Link to post Share on other sites More sharing options...
Eye Neutral Newbie May 8, 2018 Share May 8, 2018 I changed mine at 20k in already almost black liao. My understanding is that it should be blood red colour. I mainly drive with start stop conditions, so decided to change early. Coming to 40k soon, gonna change again. Better be safe then sorry I have a colleague also driving a vezel and he also say need change gearbox oil every 20k. But he always deactivate the engine stop while idle function. Is that what you meant by "start stop condition"? Link to post Share on other sites More sharing options...
therock Supersonic May 8, 2018 Share May 8, 2018 Singapore driving := start stop conditions 1 Link to post Share on other sites More sharing options...
LYC 3rd Gear May 8, 2018 Share May 8, 2018 I have a colleague also driving a vezel and he also say need change gearbox oil every 20k. But he always deactivate the engine stop while idle function. Is that what you meant by "start stop condition"? GO -> traffic light within 100m stop -> go -> next traffic light within 100m stop again. Or stucked in traffic jams etc. Link to post Share on other sites More sharing options...
Tt0408 1st Gear May 9, 2018 Share May 9, 2018 Hi, At the gearbox, there's a small orange light beside each gears (P, R, N, D, S and L). Anyone encounter this light blinking or not light up completely? Thanks. Link to post Share on other sites More sharing options...
LYC 3rd Gear May 9, 2018 Share May 9, 2018 Hi, At the gearbox, there's a small orange light beside each gears (P, R, N, D, S and L). Anyone encounter this light blinking or not light up completely? Thanks. Heard a lot of these cases with fellow owners. Mine so far so good in these 2.5 years. But it seems like the panel is quite hot after driving awhile in the 'P' area. Link to post Share on other sites More sharing options...
Eightfold Neutral Newbie May 24, 2018 Share May 24, 2018 Anyone changed Petrol tail lights for the Hybrid smoked tail lights? Any recommendations? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 25, 2018 Share May 25, 2018 (edited) Anyone changed Petrol tail lights for the Hybrid smoked tail lights? Any recommendations? One of the merchants under Marketplace column called Han Revolution has an ad on the Vezel Hybrid type rear lights at S$520.00 Edited May 25, 2018 by Mzrmazda3 Link to post Share on other sites More sharing options...
ml86 Neutral Newbie May 26, 2018 Share May 26, 2018 Hi Guys, I was looking around at Vezel's today. I would like to know if the honda sensing is a standard or optional thing. PI is saying it's 2k additional to have it, i read that this is supposed to be standard. Would love to hear thoughts on changing the rims to 18s, anyone have experience with this? better fuel consumption? thanks in advance Link to post Share on other sites More sharing options...
BlitzStryker 2nd Gear May 26, 2018 Share May 26, 2018 Think the new model of Hybrid has lesser features as shown on sgcarmart http://www.sgcarmart.com/new_cars/newcars_features.php?CarCode=11557&Subcode=5478 The features missing are: 1) Auto headlight 2) bluetooth interface 3) multi-zone aircon 4) audio aux/usb portPI cutting costs by importing lesser features? Hmm... Link to post Share on other sites More sharing options...
ml86 Neutral Newbie May 27, 2018 Share May 27, 2018 between honda jazz and vezel, it seems most people prefer the vezel. the only concern is the risk of PI. price wise, they are pretty much the same. anything else I should take note of when making comparisons between the 2? Link to post Share on other sites More sharing options...
Eightfold Neutral Newbie May 27, 2018 Share May 27, 2018 One of the merchants under Marketplace column called Han Revolution has an ad on the Vezel Hybrid type rear lights at S$520.00 Hi - Thank you for the comment. I just collected my Vezel petrol, not the facelift version. During times when stopping at traffic lights, and accelerating - there is a engine kick off noise as though the engine went idle. Could someone advice if this is expected? I checked previous threads and saw that there is a button to disable this but we have to do it every drive --> Not sure if this is the same thing i am describing. If so, where is this button? Thanks! Link to post Share on other sites More sharing options...
Leo72 6th Gear May 27, 2018 Share May 27, 2018 Hi - Thank you for the comment. I just collected my Vezel petrol, not the facelift version. During times when stopping at traffic lights, and accelerating - there is a engine kick off noise as though the engine went idle. Could someone advice if this is expected? I checked previous threads and saw that there is a button to disable this but we have to do it every drive --> Not sure if this is the same thing i am describing. If so, where is this button? Thanks! This is the Auto Start/Stop system. The button to disable is at the centre console area just in front of your gear shift. The Button with "A" when disable the Auto Start/Stop system, the amber light will be on. ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mitsuoka M55
2025 Mitsuoka M55
