Thaiyotakamli Supersonic October 19, 2019 Share October 19, 2019 1 hour ago, TangoCharlie said: I checked my EO and coolant at 25k. EO no need top up. Skoda win Audi. Yah thats why i bought skoda, simply smart purchase lol ↡ Advertisement 8 Link to post Share on other sites More sharing options...
Mkl22 Twincharged October 19, 2019 Share October 19, 2019 7 hours ago, Hamburger said: I used to be in of the mpv chat until I gave up. Almost everyday fried cold rice and talked about FC , save fuel, EO used, car cam, dsg cannot creep etc. Gave up and exit. What do you expect? All uncles driving a bus. Link to post Share on other sites More sharing options...
flashbang Turbocharged October 19, 2019 Share October 19, 2019 1 hour ago, Mkl22 said: What do you expect? All uncles driving a bus. MPV for limousine service, need to save FC to maximize profit. Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 19, 2019 Share October 19, 2019 2 hours ago, Mkl22 said: What do you expect? All uncles driving a bus. Mostly mini bus though 2 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged October 20, 2019 Share October 20, 2019 (edited) 14 hours ago, Mkl22 said: What do you expect? All uncles driving a bus. Have u every seen an elephant out pacing a tiger.? what the point in trying to get a donkey to run like a horse ? It can be modded but do you want to is another matter most just end up with bigger rims and brake kit for stopping power. Edited October 20, 2019 by Sdf4786k 1 Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 (edited) On 10/19/2019 at 8:36 AM, Ody_2004 said: Jin rare to be so quiet here.. How's everyone Skoda? Happily driving them and no complain to raise? or all move to Whatsapp Telegram etc oredi? Me old man still prefer Forum. Found water pump housing was leaking last Friday when I went to add mods. Would not have found out if I waited until next service at 45K. I was monitor a slow decrease in coolant level over the past month, so now I know. Car mileage currently at 36500km. Slight possibility SCS aftersales service missed it because there is no need to remove the bottom engine cover to drain the oil. So I might have been running the past 6000km with a leaking water pump. Had always thought the over 100degC on water temps was consistent with the oil temp, but after getting it replaced, I beg to differ now, it's running within range of 85 to 95 degC. After my mods last friday, I am seeing below 100degC on my oil, no matter how hard I whack. So I recommend guys on the 2.0T engine to do a good undercarriage check every 10K mileage at least, because these water pumps are known to bust around there. The mechanic said I can run it over 30K is kinda impressive. Edited October 20, 2019 by adrian140180 4 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged October 20, 2019 Share October 20, 2019 2 minutes ago, adrian140180 said: So I recommend guys on the 2.0T engine to do a good undercarriage check every 10K mileage at least, because these water pumps are known to bust around there. The mechanic said I can run it over 30K is kinda impressive. mmmm kinda strange to have such failure at such mileage right? the pump or just the hose? Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 Just now, Ody_2004 said: mmmm kinda strange to have such failure at such mileage right? the pump or just the hose? Not strange for the 2.0T, it is possible to bust it at 10K. The housing cracked, and leak dribble dribble for the longest of time. The entire housing is made of plastic, so honestly no surprises how long they can last. In the picture below, there is 1 crack along the circumference on the left side where the harness goes, another crack is on the valve section facing you in the picture. 3 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged October 20, 2019 Share October 20, 2019 2 minutes ago, adrian140180 said: Not strange for the 2.0T, it is possible to bust it at 10K. The housing cracked, and leak dribble dribble for the longest of time. The entire housing is made of plastic, so honestly no surprises how long they can last. In the picture below, there is 1 crack along the circumference on the left side where the harness goes, another crack is on the valve section facing you in the picture. thanks for the info.. small leaks not easy to detect.. until it drip till got water stain.. if not need to dismantle to check liao. your no claim warranty right as was done by another workshop. How yr stage 1? Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 2 minutes ago, Ody_2004 said: thanks for the info.. small leaks not easy to detect.. until it drip till got water stain.. if not need to dismantle to check liao. your no claim warranty right as was done by another workshop. How yr stage 1? I cannot be bothered with warranty, I was doing hardware mod the same time, so just ask the shop order in the water pump for replacement. Part came within the hour from stockist. If I send back to SCS dunno how many donkey days later and paper work I have to fill, plus my car is pretty much unrecognizable if I send it back. Do not want to give the SCS guys a hard time. The software is still adapting to my drive style, hard to comment, but the torque is now across the entire rev range. How you know I did stage 1? Who in the group tipped you off? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged October 20, 2019 Share October 20, 2019 1 minute ago, adrian140180 said: How you know I did stage 1? Who in the group tipped you off? You posted in VAGSG mah 😁😁 Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 Just now, Ody_2004 said: You posted in VAGSG mah 😁😁 Oh yeah hor, chey. Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 Something I noticed the past 2 days of whacking this car. The burnt smell no longer appears when you rev high and hard. Usually comes past the 4000rpm mark, I still got it last tuesday with a little push. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged October 20, 2019 Share October 20, 2019 15 hours ago, adrian140180 said: Not strange for the 2.0T, it is possible to bust it at 10K. The housing cracked, and leak dribble dribble for the longest of time. The entire housing is made of plastic, so honestly no surprises how long they can last. In the picture below, there is 1 crack along the circumference on the left side where the harness goes, another crack is on the valve section facing you in the picture. is this with the metal impeller or the same plastic ones? Link to post Share on other sites More sharing options...
adrian140180 5th Gear October 20, 2019 Share October 20, 2019 2 minutes ago, Sdf4786k said: is this with the metal impeller or the same plastic ones? A few more pics and you will be as clear as day. 1 Link to post Share on other sites More sharing options...
TangoCharlie Supersonic October 20, 2019 Share October 20, 2019 15 hours ago, adrian140180 said: I cannot be bothered with warranty, I was doing hardware mod the same time, so just ask the shop order in the water pump for replacement. Part came within the hour from stockist. If I send back to SCS dunno how many donkey days later and paper work I have to fill, plus my car is pretty much unrecognizable if I send it back. Do not want to give the SCS guys a hard time. The software is still adapting to my drive style, hard to comment, but the torque is now across the entire rev range. How you know I did stage 1? Who in the group tipped you off? Since you can't be bothered with warranty, is there a reason why you go with AD and not PI or self import. I suppose most of us go to AD for peace of mind and it's 5 years warranty 1 Link to post Share on other sites More sharing options...
Sdf4786k Twincharged October 21, 2019 Share October 21, 2019 12 minutes ago, TangoCharlie said: Since you can't be bothered with warranty, is there a reason why you go with AD and not PI or self import. I suppose most of us go to AD for peace of mind and it's 5 years warranty Have you ask the PI if the keys are lost and you need to reprogram and replace , how to do it? Link to post Share on other sites More sharing options...
TangoCharlie Supersonic October 21, 2019 Share October 21, 2019 (edited) 7 minutes ago, Sdf4786k said: Have you ask the PI if the keys are lost and you need to reprogram and replace , how to do it? I go to AD never consider PI or self import. Pay more for peace of mind.... hopefully. Adrian seems a capable chap to do everything. Edited October 21, 2019 by TangoCharlie ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
National Service in Singapore
