MQX87511 5th Gear August 21, 2018 Share August 21, 2018 If the fuel economy improves, then it is likely to be a thinner grade of oil that allows the pistons to move more easily. I'm concerned whether the oil breaks down easily if used for 10,000 km. In addition, there are some car workshops that charge only $60 for very basic car servicing that includes Shell Ultra Helix 5W40 and oil filter. The engine oil itself has a market value of about $35, so these workshops seem to be value for money. I'm thinking of utilizing the saving to do serious maintenance like changing spark plugs or cleaning the oxygen sensor more regularly etc. Japanese cars are rugged, don't mind the low grade oil, if Conti cars better don't take the risk, go for reputed brands ↡ Advertisement Link to post Share on other sites More sharing options...
Matrix0405 5th Gear August 22, 2018 Share August 22, 2018 Just bought this EO but no longer $17.90. Now $19.90 Wah, price went up! Available from Giant? How much is Snell & Carlube for HariRaya? Link to post Share on other sites More sharing options...
tomicacars August 23, 2018 Share August 23, 2018 Wah, price went up! Available from Giant? How much is Snell & Carlube for HariRaya? I went to buy 6 bottles during their warehouse sale yesterday. Some bro gave the heads up for this sale in the other thread so I quickly went down. Got it at $17.90. Think it is back to $19.90 Snell and Carlube no sale Link to post Share on other sites More sharing options...
Hachi 3rd Gear August 24, 2018 Share August 24, 2018 (edited) Drain it out at 2000km, not smooth no power. And cause my fuel consumption up by 0.5km per litre. Lucky brought one bottle to try only. Treat it as engine cleaner. Pour, drive and flush out. My own experience. Better stick with csr lube or shall.. Hoho Edited August 24, 2018 by Hachi 1 Link to post Share on other sites More sharing options...
nazerath Turbocharged August 24, 2018 Share August 24, 2018 (edited) Did you go from a thinner viscosity oil to it? It’s hard to understand why it would result in higher fuel consumption. I personally have not tried it though coz they only have api rating. Edited August 24, 2018 by nazerath 2 Link to post Share on other sites More sharing options...
Hachi 3rd Gear August 24, 2018 Share August 24, 2018 I used csr lube and shall, no issue. I also advocate cheap engine oil and I change it often as my mileage quite high. 1 Link to post Share on other sites More sharing options...
nazerath Turbocharged August 24, 2018 Share August 24, 2018 I used csr lube and shall, no issue. I also advocate cheap engine oil and I change it often as my mileage quite high. Oh, thanks for the heads up. Then fc shouldn’t be much different. Have you tried Schnell? I find quite good but more expensive at 24.99. Link to post Share on other sites More sharing options...
tomicacars August 24, 2018 Share August 24, 2018 How you guys get better FC from engine oil? Is it even possible? Link to post Share on other sites More sharing options...
Kklee 6th Gear August 24, 2018 Share August 24, 2018 How you guys get better FC from engine oil? Is it even possible? IMHO, it depends on the engine. But usually if a good quality low viscosity engine oil i used, FC will improve. Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 24, 2018 Share August 24, 2018 Did you go from a thinner viscosity oil to it? It’s hard to understand why it would result in higher fuel consumption. I personally have not tried it though coz they only have api rating. If 2 oils have the same viscosity and one has lower fuel consumption this is because the oil has friction modifiers inside and it reduces fiction inside the engine. Base oil price should be quite similar but better oils have more additives including friction modifiers. Anyway that's what they claim. 1 Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear August 25, 2018 Share August 25, 2018 can this be used on Ferrari and Porsche. Got any manufacturer approval? Link to post Share on other sites More sharing options...
Kklee 6th Gear August 26, 2018 Share August 26, 2018 If 2 oils have the same viscosity and one has lower fuel consumption this is because the oil has friction modifiers inside and it reduces fiction inside the engine. Base oil price should be quite similar but better oils have more additives including friction modifiers. Anyway that's what they claim. Two oil may have the same viscosity on the bottle, but yet can have different viscosity when in use. Lower viscosity usually improves FC unless the engine doesn't call for it. If want more friction modifiers, use Caltex with Techron Clean & Glide Technology. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 26, 2018 Share August 26, 2018 Two oil may have the same viscosity on the bottle, but yet can have different viscosity when in use. Lower viscosity usually improves FC unless the engine doesn't call for it. If want more friction modifiers, use Caltex with Techron Clean & Glide Technology. 1 Link to post Share on other sites More sharing options...
tomicacars August 29, 2018 Share August 29, 2018 (edited) can this be used on Ferrari and Porsche. Got any manufacturer approval?Drive supercars then shouldn't you go for branded EO? Anyway this EO so far so good. My car heavy drinker maybe becoz old car so must keep topping up. At this price worth every penny. Edited August 29, 2018 by tomicacars Link to post Share on other sites More sharing options...
awhtc 6th Gear August 29, 2018 Share August 29, 2018 As long as the driving distance is not excessive at one stretch e.g. Grab driving, then normal engine oil of 5W40 should be sufficient. Link to post Share on other sites More sharing options...
Silviasam September 4, 2018 Share September 4, 2018 This oil is safe for car engine? 1 Link to post Share on other sites More sharing options...
tomicacars September 12, 2018 Share September 12, 2018 This oil is safe for car engine? What a question. It's fully synthetic EO and you ask if safe for car engine? lol Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear September 13, 2018 Share September 13, 2018 Its as safe as Durex. No wollies. ↡ Advertisement Link to post Share on other sites More sharing options...
Facebook changes its name to Meta
Motul 8100 X-cess 5W40
Metaverse: 5 things to know about tech's latest buzzword
Iceland : Has anybody driven in Iceland before?
Is Taiwan's WU BAI the best rocker in the east?? who else??
SCHNELL Engine Oil 5W40
