Buadongdong Twincharged March 1, 2018 Share March 1, 2018 (edited) I posted my suggestion a few years ago. Dig big swimming pools in deserts like in Saudi Arabia and cover with glass made from sand from the desert. Fill the pools with sea water. The sun will evaporate the water on the glass roof and use the water to irrigate the desert. Collect the salt to use as molten salt in solar towers. This will reduce sea level, green the desert and privide molten salt for solar towers reducing the need for fossil fuels. How do one use the water being evaporated to irrigate the desert? The biggest challenge is where to find sea water in the midst of the desert? With natural gas I think my MIL can power a small building. So power ah?? SPPG should hire your MIL leh.. Then you can stop working and shake leg at home liao.. hahaha. @spring enuf to power planet earth for 200 years Paging for @spring, why you didnt volunteer earlier? Singapore's electrical tariff drop or rise depends on you liao (国宝).. Wahahahah Edited March 1, 2018 by Buadongdong ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 1, 2018 Share March 1, 2018 Japan have a lot of electronic engineers, a lot of coast line and a lot of typhoons. They should make wave power devices that work under the seas and the rougher the sea the better. Above the sea they can put wind mills. They also have hot springs and that geo thermal. Maybe they don't even need nuclear power of oil fired power stations. No more Fukushima. How do one use the water being evaporated to irrigate the desert? The biggest challenge is where to find sea water in the midst of the desert? So power ah?? SPPG should hire your MIL leh.. Then you can stop working and shake leg at home liao.. hahaha. Paging for @spring, why you didnt volunteer earlier? Singapore's electrical tariff drop or rise depends on you liao (å½å®ï¼.. Wahahahah Saudi Arabia has a coastline. Collect the distilled water and green the desert like the gardens of Babylon. 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged March 1, 2018 Share March 1, 2018 Japan have a lot of electronic engineers, a lot of coast line and a lot of typhoons. They should make wave power devices that work under the seas and the rougher the sea the better. Above the sea they can put wind mills. They also have hot springs and that geo thermal. Maybe they don't even need nuclear power of oil fired power stations. No more Fukushima. Yeah.. agree.. a greener method of generating electricity.. But I guess the amount generated by these means are not enough as compared to what the nuclear plant can generate with the same amount of land required. Geothermal also need to see whether got hotspots in Japan or not leh.. Not easy to find Geothermal farms underneath. Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 1, 2018 Share March 1, 2018 (edited) Yeah.. agree.. a greener method of generating electricity.. But I guess the amount generated by these means are not enough as compared to what the nuclear plant can generate with the same amount of land required. Geothermal also need to see whether got hotspots in Japan or not leh.. Not easy to find Geothermal farms underneath.When I get home I post my MIL Japanese relative hotspring photo for you. Edited March 1, 2018 by Jamesc Link to post Share on other sites More sharing options...
Blueray Hypersonic March 1, 2018 Share March 1, 2018 why sell to Microsoft and not to SP Services ? Link to post Share on other sites More sharing options...
Brass 6th Gear March 1, 2018 Share March 1, 2018 Japan have a lot of electronic engineers, a lot of coast line and a lot of typhoons. They should make wave power devices that work under the seas and the rougher the sea the better. Above the sea they can put wind mills. They also have hot springs and that geo thermal. Maybe they don't even need nuclear power of oil fired power stations. No more Fukushima. Saudi Arabia has a coastline. Collect the distilled water and green the desert like the gardens of Babylon. Provided that they draw from the correct sea. If they foolishly draw it from the Persian gulf..... Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 1, 2018 Share March 1, 2018 When I get home I post my MIL Japanese relative hotspring photo for you. My MIL relatives and their hot spring. 1 Link to post Share on other sites More sharing options...
Buadongdong Twincharged March 1, 2018 Share March 1, 2018 My MIL relatives and their hot spring. Wah.. Like sibeh song leh.. I scrub your back, you scrub mine.. Link to post Share on other sites More sharing options...
Mustank Hypersonic March 1, 2018 Share March 1, 2018 Hahaha.. can just ask her to google search Global Insolation rates. I've attached one of the links here for your easy reference. Aussie is one of the best countries to harvest solar energy.. Singapore ah?? We are one of the lowest globally.. Dunno why SG gov go waste taxpayer's money into solar cells. The ROI is 50yrs maybe? Or even longer.. https://www.quora.com/Which-are-the-countries-with-the-highest-solar-radiation Even solar water heater type also depends on our weather. Singapore weather is so unpredictable with Clouds overcover most of the days makes it not worth the investment. But thats on a home scale.. it might be worth doing it in a commercial scale. With the insolation rates that ASEAN have, its just not worth doing it. Unless the cost of PV cells go down so much such that the ROI is 10yrs, then it would be more worth it to do. Don't only think that one can get "free" energy once installed. There are maintenance costs and these sums are not small. Every 1mm of dust covering the PV cell will reduce its efficiency by 3-5%. Singapore, although not as dusty as our neighbours, is still considered dusty in global terms. So all in all, not worth lor.. Btw, the above is just my personal opinion. Solar water definitely can do becuase even for clouds, the heat is still highProblem is what to do with all the hot water Even use for bathing, the most is save $30 worth of gas a month why sell to Microsoft and not to SP Services ? Solar panel very troublesome oneIf you use the grid tie inverter to covert to ac and feed back the main More than donno how many kWh must get their engineer to come to certify Even if use taobao panels, very hard to justify the cost Only can consider solar water type My MIL relatives and their hot spring. Hmmmmmmmm 3 Link to post Share on other sites More sharing options...
Buadongdong Twincharged March 1, 2018 Share March 1, 2018 Solar water definitely can do becuase even for clouds, the heat is still high Problem is what to do with all the hot water Even use for bathing, the most is save $30 worth of gas a month Solar panel very troublesome one If you use the grid tie inverter to covert to ac and feed back the main More than donno how many kWh must get their engineer to come to certify Even if use taobao panels, very hard to justify the cost Only can consider solar water type Hmmmmmmmm Wow wow wow.. We have an electrical background boss in da house!!Agree solar water heater can be used.. But on a larger scale than residential.. Commercial more viable.. 1 Link to post Share on other sites More sharing options...
Mustank Hypersonic March 1, 2018 Share March 1, 2018 Wow wow wow.. We have an electrical background boss in da house!! Agree solar water heater can be used.. But on a larger scale than residential.. Commercial more viable.. Simi simi Link to post Share on other sites More sharing options...
Buadongdong Twincharged March 1, 2018 Share March 1, 2018 (edited) Simi simi Let me guess.. LEW? Electrical QP? Those things u said only insider knows.. Confirm plus chop.. Edited March 1, 2018 by Buadongdong Link to post Share on other sites More sharing options...
kdash Supersonic March 1, 2018 Share March 1, 2018 Let me guess.. LEW? Electrical QP? Those things u said only insider knows.. Confirm plus chop..waa @mustank is electric boss? Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 1, 2018 Share March 1, 2018 Hahaha.. can just ask her to google search Global Insolation rates. I've attached one of the links here for your easy reference. Aussie is one of the best countries to harvest solar energy.. Singapore ah?? We are one of the lowest globally.. Dunno why SG gov go waste taxpayer's money into solar cells. The ROI is 50yrs maybe? Or even longer.. https://www.quora.com/Which-are-the-countries-with-the-highest-solar-radiation Even solar water heater type also depends on our weather. Singapore weather is so unpredictable with Clouds overcover most of the days makes it not worth the investment. But thats on a home scale.. it might be worth doing it in a commercial scale. With the insolation rates that ASEAN have, its just not worth doing it. Unless the cost of PV cells go down so much such that the ROI is 10yrs, then it would be more worth it to do. Don't only think that one can get "free" energy once installed. There are maintenance costs and these sums are not small. Every 1mm of dust covering the PV cell will reduce its efficiency by 3-5%. Singapore, although not as dusty as our neighbours, is still considered dusty in global terms. So all in all, not worth lor.. Btw, the above is just my personal opinion. Agree. I can hardly charge my tough solar g shocks in sg. Even 10 yrs ROI is too much. Had a project previously thinking to install solar panels. But the cost is way too high. I wonder why hdb is still installing solar panels on our roof tops. Link to post Share on other sites More sharing options...
Mustank Hypersonic March 1, 2018 Share March 1, 2018 Let me guess.. LEW? Electrical QP? Those things u said only insider knows.. Confirm plus chop..Simi simiI google only lah Pub website say one Got some pdf inside got say one I cannot remember where liao I just like renewal energy stuff that’s all waa @mustank is electric boss?If boss then is huat liao loh Confirm drive Mercedes liao loh Where got drive one lousy pigkarp Link to post Share on other sites More sharing options...
Mustank Hypersonic March 2, 2018 Share March 2, 2018 I kope from here one https://www.bca.gov.sg/publications/others/handbook_for_solar_pv_systems.pdf Page 24 I really not engineer lah 1 Link to post Share on other sites More sharing options...
Kusje Supersonic March 2, 2018 Share March 2, 2018 Solar water definitely can do becuase even for clouds, the heat is still high Problem is what to do with all the hot water Even use for bathing, the most is save $30 worth of gas a month Solar panel very troublesome one If you use the grid tie inverter to covert to ac and feed back the main More than donno how many kWh must get their engineer to come to certify Even if use taobao panels, very hard to justify the cost Only can consider solar water type Hmmmmmmmm u engineer or accountant? If boss then is huat liao loh Confirm drive Mercedes liao loh Where got drive one lousy pigkarp Mercedes engine what. Link to post Share on other sites More sharing options...
Mustank Hypersonic March 2, 2018 Share March 2, 2018 u engineer or accountant? Mercedes engine what. I wanted to be engineer but was forced to be accountant by circumstances ↡ Advertisement Link to post Share on other sites More sharing options...
Rare Annular Solar Eclipse on 26 Dec 11.30 am to 3.30 pm
Money does buy happiness but only up to $670k
COE Bidding - October 2023
COE Bidding - September 2023
COE Bidding – July 2022
Lazada good deals lobang!
Solar film JB
Solar film JB
COE Bidding – March 2023
