Playtime Twincharged June 27, 2019 Share June 27, 2019 Of course I know this simple logic. What I don't is, why patch everything so nicely then dig again? Sometimes, it was for the same services. The notices on display will tell you which service is digging up the road. Unless they use the wrong one hahaNot necessarily same service, same road contractor can be carrying work for different providers, so it may look like sane people dig. Sometimes it's really same service though. Example.. water pipe need to divert. First you lay the new path. Test and confirm ok. Then arrange a date for shutdown. come back again to cut the old pipes and divert to the new. Knn.. may even come back a third time again to remove the abandoned pipes if required ↡ Advertisement Link to post Share on other sites More sharing options...
Victor68 Turbocharged June 27, 2019 Share June 27, 2019 Not necessarily same service, same road contractor can be carrying work for different providers, so it may look like sane people dig. Sometimes it's really same service though. Example.. water pipe need to divert. First you lay the new path. Test and confirm ok. Then arrange a date for shutdown. come back again to cut the old pipes and divert to the new. Knn.. may even come back a third time again to remove the abandoned pipes if required ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
National Service in Singapore
