My 4 tyres are all same brands and using the exacts profile
ok. have you inspected the rear tyres compared to the front? any difference? if no. unlikely is the tyre noise. it could be some other parts creating the noise?
Edited by StreamRSZ
Share this post
The mech said its useless to rotate so i didnt do it. But he confirm not bearing coz when he rotate the tyre using his hand, he said he can feel rotatting smoothly. If bearing problem, he said he could feel the tyre not rotating smoothly. He just asked me to change the rear tyres. He didnt sell tyres btw, just when i serviced my car he checked for me when i told him i heard sounds from hear tyres
how did the mechanic verify that the sound issue is due to the rear tyres? what is the exact issue?
it is much cheaper to rotate the tyres than to buy a pair of new tyres wor.
Share this post
At the ws whe i service my car the mech inspect after test drive. He said rear tyre problem n not bearing. Front tyres are fine he said. When i asked to rotate he said no use already. I forgot wht his explaination why is the rear tyre problem but i only remember he siad when he spin they tyre it still rotated smoothly so cannot be bearing problem and its not tyre noise too coz last time it didnt havr the noise. I just dont want later after change tyre then ask me change bearing. Anyone ever encounter similar like this?mine is honda civic fd4
Share this post
bro i suggest you bring your car to SKM motors to let Ah heng check for you. SKM specialise in honda. Your mechanic may not have enough tech knowledge on your issue. let SKM check for you.
Share this post
Ok bro I will try to go there then. Thanks alot for the info bro
Share this post
Just curious, for a ride that travels around 20K a year, when will be a good time to change the brake pads? A mechanic took a look at mine and he said time to change liao. My ride is 2.5 years old, 50+ km traveled.
Share this post
imho...
there is an "indicator" at e brake/wheel area to tell u how much brake pad u hav left....if not sure best get a trustworthy tech to advice u and also show u where e indicator is. n how to read it.
Also, note that not all brake-pads are made equal....if u chg, make sure is a gd one. (at least car's manufacturer standard)
How long (time) or distance traveled to chg really depends on ur driving style and e type of roads u travel (flat/uphill/downhill) daily......
My 2¢..
  • Praise 5
Share this post
actually very easy to see how much meat the brake pads still left . can see from the top part. need a torch light.
this is how i monitor my brake pads usage. usually it depends on your driving style also. auto cars usually brake pads wear faster. average around 40K onwards. Just a rough guide.Some may need to change around 30K+ depends.
Share this post
Front or rear brake pad?
50+k km sounds normal for rear brake pad.
Share this post
It also depends on the weight of car.
Heavier car will wear brake pad out faster.
Share this post
Front bro. Rear is drum brakes and they are pretty lasting.
Share this post
agreed. heavier car need more braking power.
Share this post
Yup. Only 'xiong' part is remove the rim.
change brake pads is easy job.not difficult.
Edited by Discoburg
Share this post
nice job bro. it would also be good to service your guide pins at the same time taking it out to clean them and apply silicone paste on it. sot that the caliper will not jam due to guide pins no lubrication. This is often not done by workshop sadly. also apply coat of copper anti seize onto the brake pad shim so that it will not cause sound when braking. All these steps is sadly not done by our sg workshops.
If you happen to DIY change brake pads, it is good to do the above mentioned steps. Than your brakes performance will be optimal.
  • Praise 2
Share this post
Still can use until the middle groove is almost flush.
Share this post
