teomingern 6th Gear September 12, 2020 Share September 12, 2020 Totally true in Singapore... most cars don't even hit 150,000 km before getting scrapped... but it must also mean the manufacturers are confident that the transmission fluid will hold up lar... ↡ Advertisement Link to post Share on other sites More sharing options...
ceratokaki Neutral Newbie September 12, 2020 Share September 12, 2020 k3, 2017, also using sealed transmission, but cnc change ATF every 40,000 km, Service C. Link to post Share on other sites More sharing options...
teomingern 6th Gear September 12, 2020 Share September 12, 2020 1 hour ago, ceratokaki said: k3, 2017, also using sealed transmission, but cnc change ATF every 40,000 km, Service C. That's why they've changed it now? Link to post Share on other sites More sharing options...
Cw1985 Neutral Newbie October 14, 2020 Share October 14, 2020 Hi guy. May I know the pre installed dash cam (Black vac) by kia when u brought the car, can it record 24/7? Because I didn't found any battery pack attached to it. Thank you. Link to post Share on other sites More sharing options...
Bolster Neutral Newbie October 21, 2020 Share October 21, 2020 Hi guys, Can the Kia K3 2018 model L series change to keyless? Any workshop to recommend? Link to post Share on other sites More sharing options...
Vinceng Turbocharged October 21, 2020 Share October 21, 2020 On 10/14/2020 at 9:39 AM, Cw1985 said: Hi guy. May I know the pre installed dash cam (Black vac) by kia when u brought the car, can it record 24/7? Because I didn't found any battery pack attached to it. Thank you. You can set the Blackvue dash cam to be on standby mode, and tap on your car battery power. Set it to auto turn off when you r car battery voltage goes below 12V. Link to post Share on other sites More sharing options...
Vinceng Turbocharged October 21, 2020 Share October 21, 2020 (edited) 6 hours ago, Bolster said: Hi guys, Can the Kia K3 2018 model L series change to keyless? Any workshop to recommend? Keyless entry and keyless start can be done here - https://www.sgcarmart.com/directory/merchant.php?MID=11262 Edited October 21, 2020 by Vinceng Link to post Share on other sites More sharing options...
daoyan 1st Gear October 22, 2020 Share October 22, 2020 Hi guys, possible to advise where can we buy original brake pad for our ride? Try checking with min ghee but is out of stock. Any recommend good oem brake pad will be great also. Thanks!!! Link to post Share on other sites More sharing options...
teomingern 6th Gear October 23, 2020 Share October 23, 2020 9 hours ago, daoyan said: Hi guys, possible to advise where can we buy original brake pad for our ride? Try checking with min ghee but is out of stock. Any recommend good oem brake pad will be great also. Thanks!!! Try Song Yi? Link to post Share on other sites More sharing options...
daoyan 1st Gear October 23, 2020 Share October 23, 2020 1 hour ago, teomingern said: Try Song Yi? Yup. I had tried calling song yi also They claimed they only sell Hyundai part only, unless we can confirm that Hyundai's brake pad part numbers is the same as our ride..... Link to post Share on other sites More sharing options...
teomingern 6th Gear October 24, 2020 Share October 24, 2020 On 10/23/2020 at 9:43 AM, daoyan said: Yup. I had tried calling song yi also They claimed they only sell Hyundai part only, unless we can confirm that Hyundai's brake pad part numbers is the same as our ride..... Should be the same... I used Kia oil filter for my Hyundai Sonata leh... Link to post Share on other sites More sharing options...
Cw1985 Neutral Newbie October 24, 2020 Share October 24, 2020 On 10/21/2020 at 11:19 PM, Vinceng said: You can set the Blackvue dash cam to be on standby mode, and tap on your car battery power. Set it to auto turn off when you r car battery voltage goes below 12V. Bro, it required a battery regulator right? That system cost $400. I looking at connecting to external battery when car engine off Link to post Share on other sites More sharing options...
Vinceng Turbocharged October 24, 2020 Share October 24, 2020 50 minutes ago, Cw1985 said: Bro, it required a battery regulator right? That system cost $400. I looking at connecting to external battery when car engine off You don't need a battery regulator Link to post Share on other sites More sharing options...
daoyan 1st Gear October 25, 2020 Share October 25, 2020 On 10/24/2020 at 2:05 PM, teomingern said: Should be the same... I used Kia oil filter for my Hyundai Sonata leh... Hmm... any idea which is the part number for the brake pad?? Link to post Share on other sites More sharing options...
therock Supersonic October 30, 2020 Share October 30, 2020 With the Elantra going upmarket, the K3 is now the VFM car, especially if the buyers don't mind a few less airbags.. Link to post Share on other sites More sharing options...
13177 Supersonic October 30, 2020 Share October 30, 2020 (edited) 37 minutes ago, therock said: With the Elantra going upmarket, the K3 is now the VFM car, especially if the buyers don't mind a few less airbags.. Maybe when cerato launch their next generation brand new model, they also follow hyundai go upmarket? Lol. Edited October 30, 2020 by 13177 Link to post Share on other sites More sharing options...
daoyan 1st Gear November 3, 2020 Share November 3, 2020 Hi guys, any review for Brand : Hi-Q brake pad? Heard is oem for Kia K3 and Hyundai... Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear November 4, 2020 Share November 4, 2020 12 hours ago, daoyan said: Hi guys, any review for Brand : Hi-Q brake pad? Heard is oem for Kia K3 and Hyundai... Heard from who? Workshop? ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Kia EV6
2022 Kia EV6
Kia EV9 Concept
Kia EV9 Concept
KIA K3 Owners check-in!
Kia Stonic
Kia Stonic
