GS418 1st Gear December 17, 2018 Share December 17, 2018 (edited) Hi all, Needed some advice. Driving a Renault Grand Scenic 4 and intending to do some moderate upgrades to my ICE for better enjoyment (not an audiophile). This was suggested by a workshop after some discussion: 1) HU - Remain as stock (due to many integrated functions) 2) Replace both front and rear stock speakers with Rainbow SLC6.2 component speakers (so that rear passengers also gets enjoyable music, not just driver and front passenger) 3) Add a basic active sub under driver seat. 4) Sound proofing and door sealers to all 4 doors. 5) Still considering a DSP+Amp unit. Damage for S/N 1 to 3 is 1.9K with install + tuning. Like to seek comments! Edited December 17, 2018 by GS418 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
giraffey99 3rd Gear December 18, 2018 Share December 18, 2018 Hi all, Needed some advice. Driving a Renault Grand Scenic 4 and intending to do some moderate upgrades to my ICE for better enjoyment (not an audiophile). This was suggested by a workshop after some discussion: 1) HU - Remain as stock (due to many integrated functions) 2) Replace both front and rear stock speakers with Rainbow SLC6.2 component speakers (so that rear passengers also gets enjoyable music, not just driver and front passenger) 3) Add a basic active sub under driver seat. 4) Sound proofing and door sealers to all 4 doors. 5) Still considering a DSP+Amp unit. Damage for S/N 1 to 3 is 1.9K with install + tuning. Like to seek comments! Sound is subjective. Have you listened to the Rainbow Speakers before? Is the sound and its quality acceptable to you? The main thing first is to set a comfortable budget and lists down your main objectives/purpose of upgrading before considering what to do next. Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 18, 2018 Share December 18, 2018 Listen to a more brands and you still like that brand then listen to a lot more before deciding. Link to post Share on other sites More sharing options...
GS418 1st Gear December 18, 2018 Share December 18, 2018 Sound is subjective. Have you listened to the Rainbow Speakers before? Is the sound and its quality acceptable to you? The main thing first is to set a comfortable budget and lists down your main objectives/purpose of upgrading before considering what to do next. Yes, I chose Rainbow over several other brands. But configuration wise, (1) 2 Sets components (Front and Rear) with Active Sub Woofer. (2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP. Which is better or technically sound? 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear December 18, 2018 Share December 18, 2018 Whats the model of the speakers and woofer? Yes, I chose Rainbow over several other brands.But configuration wise,(1) 2 Sets components (Front and Rear) with Active Sub Woofer.(2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP.Which is better or technically sound? 1 Link to post Share on other sites More sharing options...
Ichibawa 5th Gear December 18, 2018 Share December 18, 2018 Yes, I chose Rainbow over several other brands. But configuration wise, (1) 2 Sets components (Front and Rear) with Active Sub Woofer. (2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP. Which is better or technically sound? Best is to overhaul the entire system one time at one go which includes 3 way speaker set ups, amps, subs and DSPs. By doing so you are already stepping into audiophile territory cos the amount spend will not be little. Other than listening to workshop recommendation, you have to assess it yourself. Does your rear seat passengers enjoys your music? Most of the time the rear volume will be tuned lower but if you don't want to waste time and have the money to splurge... by all means.. fire away. Link to post Share on other sites More sharing options...
giraffey99 3rd Gear December 18, 2018 Share December 18, 2018 Yes, I chose Rainbow over several other brands. But configuration wise, (1) 2 Sets components (Front and Rear) with Active Sub Woofer. (2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP. Which is better or technically sound? Link to post Share on other sites More sharing options...
Geoandre 2nd Gear December 18, 2018 Share December 18, 2018 Yes, I chose Rainbow over several other brands. But configuration wise, (1) 2 Sets components (Front and Rear) with Active Sub Woofer. (2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP. Which is better or technically sound? For car listening, the difference would be marginal unless volume up to very high level. Don't spend too much unless you have excess budget & intend to keep the car for at least five years Personally prefer to build slowly to appreciate the difference. Maybe more cumbersome but at least I know the dollar-sound value of each component of the audio system. Do not pay extra for expensive cables, not worth the money. FYI I have installed German-made Rainbow speakers & satisfied with the performance. 1 Link to post Share on other sites More sharing options...
giraffey99 3rd Gear December 18, 2018 Share December 18, 2018 Yes, I chose Rainbow over several other brands. But configuration wise, (1) 2 Sets components (Front and Rear) with Active Sub Woofer. (2) Front (Component), Rear (Coaxial), with Active Sub Woofer and DSP. Which is better or technically sound? here is my opinion.. option 1) you would lose the "staging" effect if using components. I would just use coaxial for the rear if really need one. But, it can be low priority. If unsure, do the front first. option 2) I would invest in an amp before a dsp. The downside of dsp is that you would need to do proper tuning, and its important to have a good tuner. If not tuned properly, a passive setup (option 1) would sound much better. Link to post Share on other sites More sharing options...
GS418 1st Gear December 19, 2018 Share December 19, 2018 Many thanks to all the kind souls for the sharing and advices. Appreciate!! Decided to go ahead with the following configuration with considerations to my budget! 1) Rainbow SLC6.2 Component Speakers (Front and Rear) 2) Esatto Comado CO-D6 DSP (with built in Amp) 3) Esatto Underseat Active Subwoofer AS69 4) 3 layers Soundguard soundproofing (all 4 doors) 5) Door seals (all 4 doors + Boot door) 6) Initial Tuning + Follow up tuning (~1 month later after speakers run in period) **FOC. Installing today....And hopefully it will turn out well! Just to add that if budget had allowed, I would have preferred dedicated DSP and Amp, rather than an integrated unit. 3 way speakers instead of 2 way, and also soundproofing for Firewall and Wheel arcs. Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear December 19, 2018 Share December 19, 2018 Wah shioks.. Wats the demage like... 1 Link to post Share on other sites More sharing options...
GS418 1st Gear December 19, 2018 Share December 19, 2018 Wah shioks.. Wats the demage like...Approx. 4.5K! Link to post Share on other sites More sharing options...
Elepoo 2nd Gear December 20, 2018 Share December 20, 2018 Wow...that's expensive. 1 Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear December 20, 2018 Share December 20, 2018 Approx. 4.5K!Which shop? Link to post Share on other sites More sharing options...
Geoandre 2nd Gear December 20, 2018 Share December 20, 2018 Approx. 4.5K! Hmmm......if not too late, perhaps you should re-consider other configurations & set-up. Not an expert but generally you can achieve reasonably good sound production & audio experience for less than 3K as HU is stock. Link to post Share on other sites More sharing options...
GS418 1st Gear December 20, 2018 Share December 20, 2018 (edited) Soundproofing contributed to a significant part of the cost ~1K. 3 layers each door and door seals. And I chose the most expensive (hopefully the most effective and robust one) which is double the price of several other brands. Today driving it and well, road noise is negligible! Can't even hear the sound of big trucks and bus when they are beside me. But of course, not many will spend so much on soundproofing which they cannot 'see' or 'hear'. My friend spent 8K and nothing done on soundproofing. So really up to individual where soundproofing is concerned. So my main piority was to get soundproofing right first before I even consider any audio setup. Edited December 20, 2018 by GS418 Link to post Share on other sites More sharing options...
GS418 1st Gear December 20, 2018 Share December 20, 2018 (edited) Hmmm......if not too late, perhaps you should re-consider other configurations & set-up. Not an expert but generally you can achieve reasonably good sound production & audio experience for less than 3K as HU is stock.Agreed. It was 3.5K for me, but I had went for the Rainbow slightly better speakers which RRP was $688 per set before installation and materials. But if I had settled for Pioneer DSP, Amp and woofer, it would be below 3K! Haiz...Itchy finger and poison spreading. Edited December 20, 2018 by GS418 Link to post Share on other sites More sharing options...
giraffey99 3rd Gear December 20, 2018 Share December 20, 2018 Soundproofing contributed to a significant part of the cost ~1K. 3 layers each door and door seals. And I chose the most expensive (hopefully the most effective and robust one) which is double the price of several other brands. Today driving it and well, road noise is negligible! Can't even hear the sound of big trucks and bus when they are beside me. But of course, not many will spend so much on soundproofing which they cannot 'see' or 'hear'. My friend spent 8K and nothing done on soundproofing. So really up to individual where soundproofing is concerned. So my main piority was to get soundproofing right first before I even consider any audio setup. didnt do the floor, wheel arc and firewall? these will help in the overall soundproofing. ↡ Advertisement Link to post Share on other sites More sharing options...
Car Show 2024
Car Show 2024
Mitsubishi Space Star
Xtremez Audio - Your Choice for Audio Installation & Upgrade
The Doctor , Freelance ICE Tuner
