Jamesc Hypersonic September 27, 2021 Share September 27, 2021 2 hours ago, lexiton said: the face really CMI The girl or the car? ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
Winningeleven 4th Gear October 1, 2021 Share October 1, 2021 @Eynit Not many GR3 owner can advise. But GK5 stock is also the same spec stock 185/55/R16 with offset + 52. With 16x7 with +42 and fitted with 205/50/R16 wheels. The rear wheel look OK and flushed with fender but the front will be protruding out by 1 to 2cm. Personally I would not accept it. And when u made a hard turning. The wheel will rub the fender. Unfortunately all replica rims 16 inch rims usually come with 7 width with offset +40 to 42. Ideally. The prefect rims size is 16x6.5 with offset at least 46mm above. Only those original rims such as enkei etc will have. Link to post Share on other sites More sharing options...
stanbucks Clutched October 7, 2021 Share October 7, 2021 On 9/19/2021 at 5:29 PM, Eynit said: Hi guys, Owners for mk4 honda jazz/fit (GR3), did you guys change rims for your car? If yes, what are the specs? Currently running stock - 185/55/16, 6" width and offset i believe is +50 Plan - 205/50/16, 7" width with +42 offset. Any issues with the suggested wheel specs? Especially fender rubbing as i cant take that. TIA! Mine is GR1, on 16"x6.5J, offset 47. With 205/50r16 tyres, the front is very very slightly protruding. Will be going to 195/50r16 next as i feel 205 is too wide for the car, but this is just my personal driving feel after using 205. if you are going for taiwan/china rims, most likely you won't be able to get the correct offset as they are usually around 35 +/-. for this, the front will definitely protrude, even with 185 tyres. hope this helps. Link to post Share on other sites More sharing options...
Eynit Neutral Newbie October 8, 2021 Share October 8, 2021 On 10/1/2021 at 3:15 PM, Winningeleven said: @Eynit Not many GR3 owner can advise. But GK5 stock is also the same spec stock 185/55/R16 with offset + 52. With 16x7 with +42 and fitted with 205/50/R16 wheels. The rear wheel look OK and flushed with fender but the front will be protruding out by 1 to 2cm. Personally I would not accept it. And when u made a hard turning. The wheel will rub the fender. Unfortunately all replica rims 16 inch rims usually come with 7 width with offset +40 to 42. Ideally. The prefect rims size is 16x6.5 with offset at least 46mm above. Only those original rims such as enkei etc will have. On 10/7/2021 at 10:47 AM, stanbucks said: Mine is GR1, on 16"x6.5J, offset 47. With 205/50r16 tyres, the front is very very slightly protruding. Will be going to 195/50r16 next as i feel 205 is too wide for the car, but this is just my personal driving feel after using 205. if you are going for taiwan/china rims, most likely you won't be able to get the correct offset as they are usually around 35 +/-. for this, the front will definitely protrude, even with 185 tyres. hope this helps. Thanks guys for the input. I have changed my wheels 2 weeks ago and never regret it ever since. just sharing with those who bought the hybrid from Kah Motor (GR3), the stock wheels come with 16x6 with offset of +50 The wheels I changed to are 16x7 with offset of +42. The front protrudes out a tiny little bit but not by much. You could barely notice it. As for the back, it's nearly flush. Overall, with stock height, I have not once experienced any rubbing. So for guys out there with GR3, you do not need to worry about fender rubbing. As for those who actually dislike the looks of 4th gen jazz, I agree that the looks can be quite controversial. It's either you hate it or love it. I absolutely dislike it when I first saw it. However, after some time, I start to feel that the looks give the car a character that is not found in many modern cars. When comes to the ride, I assure you that the ride quality and comfort have improved significantly from the previous generation. Most things you feel inside are more premium than before, but of course, cannot compare to conti cars lah. Overall, the 4th gen Jazz has definitely improved from the previous generation in terms of ride and build quality. As for looks, it is very subjective and no one is right or wrong. 3 Link to post Share on other sites More sharing options...
SL13 Neutral Newbie October 10, 2021 Share October 10, 2021 @Eynit what is your GR3 consumption so far ? Link to post Share on other sites More sharing options...
Eynit Neutral Newbie October 10, 2021 Share October 10, 2021 @SL13 current mileage is 2k plus. Consumption between 24 -25 km/l 1 Link to post Share on other sites More sharing options...
Skenki Neutral Newbie October 18, 2021 Share October 18, 2021 @Eynit hi On 10/10/2021 at 3:19 PM, Eynit said: @SL13 current mileage is 2k plus. Consumption between 24 -25 km/l Hi jus sign the deal for jazz…any thing to look out for or advice for newbie like myself. did u send your car for any ceramic coat or paint protection? thks Link to post Share on other sites More sharing options...
Eynit Neutral Newbie October 19, 2021 Share October 19, 2021 @Skenki On 10/18/2021 at 8:55 AM, Skenki said: @Eynit hi Hi jus sign the deal for jazz…any thing to look out for or advice for newbie like myself. did u send your car for any ceramic coat or paint protection? thks Hi. There is nothing you need to worry about. Though a hybrid, but drive just like any other cars. You do get to enjoy the high torque from the electric motor. And yes, did ceramic coating on my car. Link to post Share on other sites More sharing options...
lexiton 2nd Gear October 19, 2021 Share October 19, 2021 2 hours ago, Eynit said: @Skenki Hi. There is nothing you need to worry about. Though a hybrid, but drive just like any other cars. You do get to enjoy the high torque from the electric motor. And yes, did ceramic coating on my car. whats the pickup 0 to 100 km/h? in seconds Link to post Share on other sites More sharing options...
Skenki Neutral Newbie October 19, 2021 Share October 19, 2021 3 hours ago, Eynit said: @Skenki Hi. There is nothing you need to worry about. Though a hybrid, but drive just like any other cars. You do get to enjoy the high torque from the electric motor. And yes, did ceramic coating on my car. Where did u do ur ceramic coating and how much? Link to post Share on other sites More sharing options...
Eynit Neutral Newbie October 20, 2021 Share October 20, 2021 10 hours ago, lexiton said: whats the pickup 0 to 100 km/h? in seconds Never measure. On paper is 9 sec plus? Some say in reality below 9. But kinda unnecessary in the real world? Not like we floor the accelerator pedal whenever the traffic light turn green. Lol Link to post Share on other sites More sharing options...
Panhard 1st Gear October 25, 2021 Share October 25, 2021 (edited) Hi, enjoying my new GR1. But the stock horn sounds funny. Any options to replace? Easy to DIY? Anyone done it? Edited October 25, 2021 by Panhard 1 Link to post Share on other sites More sharing options...
tanlc1988 Neutral Newbie November 27, 2021 Share November 27, 2021 hello folks, im planning to get a used honda fit/jazz. was searching around sgcarmart and found the below listing. https://www.sgcarmart.com/used_cars/info.php?ID=924212&DL=2984 new model honda fit with depre lower than older model. is the new model so unpopular? Link to post Share on other sites More sharing options...
Confusedboi Supercharged November 28, 2021 Share November 28, 2021 11 hours ago, tanlc1988 said: hello folks, im planning to get a used honda fit/jazz. was searching around sgcarmart and found the below listing. https://www.sgcarmart.com/used_cars/info.php?ID=924212&DL=2984 new model honda fit with depre lower than older model. is the new model so unpopular? erm the looks of the new fit is really polarizing both interior and exterior, that's why you hardly see the new model on the road. Link to post Share on other sites More sharing options...
Winningeleven 4th Gear November 28, 2021 Share November 28, 2021 The new model is avaliable on early 2021. Price of Cat A coe was already at min 40k already. The previous 1.3 gk3 was sold less than 70k when brand new due to less than. 30k coe . That why new model is lesser now. Link to post Share on other sites More sharing options...
Mooose 6th Gear December 2, 2021 Share December 2, 2021 On 11/28/2021 at 12:07 AM, tanlc1988 said: new model honda fit with depre lower than older model. is the new model so unpopular? not so much as being popular or unpopular, but buyers for the new car are limited by the amount of downpayment and loan quantum .. to me if can work out the numbers, buying new is a no brainer with its lower depreciation. older model will have higher depreciation plus (potentially/likely) higher maintenance/repair costs .. Link to post Share on other sites More sharing options...
lexiton 2nd Gear December 3, 2021 Share December 3, 2021 On 11/28/2021 at 12:07 AM, tanlc1988 said: hello folks, im planning to get a used honda fit/jazz. was searching around sgcarmart and found the below listing. https://www.sgcarmart.com/used_cars/info.php?ID=924212&DL=2984 new model honda fit with depre lower than older model. is the new model so unpopular? it looks like a girl car good for females Link to post Share on other sites More sharing options...
Vulkan 2nd Gear December 3, 2021 Share December 3, 2021 4 hours ago, lexiton said: it looks like a girl car good for females Yah looks too feminine IMO. ↡ Advertisement Link to post Share on other sites More sharing options...
Visiting Porsche Experience Centre Tokyo 🛞
2025 Mazda EZ-6
2025 Mazda EZ-6
[Official] 2024 Lexus LBX
Exercising and losing weight
