Contented 1st Gear September 3, 2019 Share September 3, 2019 2 minutes ago, Davidtch said: When boot cover is closed, not locked meh? Whether noisy or not, it is not size related. Tyre price comparison: Kumho Solus 205/55 16: 73.83/pc Kumho Escta 215/45 17: 105.93/pc Very ex meh? Compare to 16 or 15inch.... boot close can be open from the back if you never lock centrally... ↡ Advertisement Link to post Share on other sites More sharing options...
Contented 1st Gear September 3, 2019 Share September 3, 2019 29 minutes ago, 13177 said: I believe DRL default cannot be off in cars and 17 inch tyre quite common in most cars nowadays la. Anyway, you can downgrade your tyre size if you find the 17 inch noisy and expensive to change lo. 😂 The only way to off DRL when Engine started as I figure out myself is to power off and then start engine with brake press with light switch off mode.. BM foreman and SE also don’t know told me cannot off at all!!?? Hmm... Link to post Share on other sites More sharing options...
inlinesix Supersonic September 3, 2019 Share September 3, 2019 (edited) 7 minutes ago, Contented said: Compare to 16 or 15inch.... boot close can be open from the back if you never lock centrally... I just show you price of 16 inch. How much lower is 15 inch? Your boot problem is similar to your door problem. Maybe you should consider Axio. Edited September 3, 2019 by Davidtch Link to post Share on other sites More sharing options...
Zxcvb Turbocharged September 3, 2019 Share September 3, 2019 Toyota Altis GR Sport!!! Link to post Share on other sites More sharing options...
Contented 1st Gear September 3, 2019 Share September 3, 2019 10 minutes ago, Davidtch said: I just show you price of 16 inch. How much lower is 15 inch? Your boot problem is similar to your door problem. Maybe you should consider Axio. Axio keyless entry too? I thought all keyless system is the same? Link to post Share on other sites More sharing options...
Octopus 3rd Gear September 6, 2019 Share September 6, 2019 Based on the Thailand Toyota website: https://www.toyota.co.th/en/model/altis The 1.6L engine would be 1ZR-FBE instead of the 1ZR-FAE as previously reported. So horsepower will be below 130bhp and within COE Category A. I wonder why the ground clearance for petrol version is only 135mm as compared to the hybrid version which is 155mm. A bit higher would be better for entry/exit as well as clearing the road kerb. 1 Link to post Share on other sites More sharing options...
13177 Supersonic September 6, 2019 Share September 6, 2019 On 9/3/2019 at 10:07 PM, Contented said: The only way to off DRL when Engine started as I figure out myself is to power off and then start engine with brake press with light switch off mode.. BM foreman and SE also don’t know told me cannot off at all!!?? Hmm... So the DRL can be off ah? Link to post Share on other sites More sharing options...
Contented 1st Gear September 6, 2019 Share September 6, 2019 13 minutes ago, 13177 said: So the DRL can be off ah? Can be off only at parking.. once driving it will be light up again... at least at night when at park the light can be off...haha 1 Link to post Share on other sites More sharing options...
13177 Supersonic September 6, 2019 Share September 6, 2019 20 minutes ago, Contented said: Can be off only at parking.. once driving it will be light up again... at least at night when at park the light can be off...haha But when you park with the engine off, all lights is off. 1 Link to post Share on other sites More sharing options...
Contented 1st Gear September 6, 2019 Share September 6, 2019 4 hours ago, 13177 said: But when you park with the engine off, all lights is off. When you still want to stay in the car enjoying the Aircon... Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 6, 2019 Share September 6, 2019 7 hours ago, Octopus said: Based on the Thailand Toyota website: https://www.toyota.co.th/en/model/altis The 1.6L engine would be 1ZR-FBE instead of the 1ZR-FAE as previously reported. So horsepower will be below 130bhp and within COE Category A. I wonder why the ground clearance for petrol version is only 135mm as compared to the hybrid version which is 155mm. A bit higher would be better for entry/exit as well as clearing the road kerb. FBE variant refers to Flex Fuel version as most of Thailand runs off a mix of ethanol. Rest of Asean should not need this. 2 Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged September 7, 2019 Share September 7, 2019 On 9/6/2019 at 11:35 AM, Contented said: Can be off only at parking.. once driving it will be light up again... at least at night when at park the light can be off...haha Ahhhh...now i see why switching off the DRL is so important to you...especially so in dark dark car parks and you need to keep the engine and aircon running right?? 😂 2 1 Link to post Share on other sites More sharing options...
Contented 1st Gear September 8, 2019 Share September 8, 2019 On 9/7/2019 at 12:14 PM, Toeknee_33 said: Ahhhh...now i see why switching off the DRL is so important to you...especially so in dark dark car parks and you need to keep the engine and aircon running right?? 😂 🙂 Link to post Share on other sites More sharing options...
Cheefarn 5th Gear September 9, 2019 Share September 9, 2019 On 9/6/2019 at 6:08 PM, t0y0ta said: FBE variant refers to Flex Fuel version as most of Thailand runs off a mix of ethanol. Rest of Asean should not need this. Yup Thailand is pushing hard for E85 fuel, which is what SG should have to lower the fuel cost. They continue to have E20 Actually most if not all modern engines can accept E20 without any modifications. Some mods will be required for E85. Thats 85% Ethanol in the fuel mix Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 9, 2019 Share September 9, 2019 On 9/6/2019 at 5:49 PM, Contented said: When you still want to stay in the car enjoying the Aircon... BTW engine on while parking for long while is technically illegal. And also bad for environment and inconsiderate. https://www.nea.gov.sg/our-services/pollution-control/air-pollution/air-pollution-regulations I know what I say will fall on your deaf ears... but eventually enforcement may catch up 2 1 Link to post Share on other sites More sharing options...
Contented 1st Gear September 10, 2019 Share September 10, 2019 On 9/9/2019 at 10:42 PM, t0y0ta said: BTW engine on while parking for long while is technically illegal. And also bad for environment and inconsiderate. https://www.nea.gov.sg/our-services/pollution-control/air-pollution/air-pollution-regulations I know what I say will fall on your deaf ears... but eventually enforcement may catch up What to do.. Singapore so hot... just don’t get caught.. haha 1 Link to post Share on other sites More sharing options...
Zxcvb Turbocharged September 17, 2019 Share September 17, 2019 https://toyota.jp/corolla/ Toyota Japan officially launched it's Corolla today. Many variants available from 1.8, hybrid, 1.2turbo manual transmission. Parallel importers mai tu liao!!!! 3 Link to post Share on other sites More sharing options...
Dafansu Turbocharged September 17, 2019 Share September 17, 2019 finally a nice one from Toyota ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota Corolla Cross
MAZDA 6
MAZDA 6
