Mkl22 Supersonic December 20, 2018 Share December 20, 2018 Walau eh, just drive like any auto car. If MU spoils, just change it. So stress for what ? Buy a car to stress oneself, seriously . ..... stressed about how to drive it "correctly", stressed about WHEN it will break. life is just too hard with a DSG. ↡ Advertisement Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 20, 2018 Share December 20, 2018 stressed about how to drive it "correctly", stressed about WHEN it will break. life is just too hard with a DSG. for me i just enjoy the superiority of the GB and when time comes for required parts replacement, be prepare for it. Made the informed decision and lives with it. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 20, 2018 Share December 20, 2018 Ppl ask for advice You guys give lecture. Ai yo yo. 1 Link to post Share on other sites More sharing options...
Heartlander Turbocharged December 20, 2018 Share December 20, 2018 I am new to a DSG gearbox (been only a week) so would welcome some advice. When going up the incline in HDB car park, my VW Golf 1.4TSI seems remarkably reluctant. I do know why this is happening - as I approach the incline I need to slow down (brake) and turn right to get onto the slope. The DSG gearbox thinks I am going to stop, so it is not in the right gear as I complete my turn. Opening the throttle slightly does not move the car up the incline, and with more throttle it moves too quickly. Also I have noted that when going down the incline in HDB car park, when you take your foot off the brake, and step on the accelerator, it seems reluctant to get going again. Again, I do know why this is happening... the DSG gearbox thinks I am going to stop, so it is not in the right gear as I complete my turn Have you encountered the same issue, and do you have any techniques, or is it just a matter of getting used to it? Been driving AT & CVT, and none of them had this issue. Thanks in advance, Naresh. I suppose you are able to see the gear that the car is engaged to, which only DSG gearbox commonly can. You will observe that when the car seems reluctant to move up accompany with a loud wailing noise, most likely the car is in the wrong gear (higher gear) thus have no power to move up. Try to slow down till it is 2nd gear before it reach the ramp, then it will move up without any drama. As for downhill run, just tap more on accelerator and it will work fine. Jus typical characteristics of DSG gearbox. 1 Link to post Share on other sites More sharing options...
Cj12329 3rd Gear December 20, 2018 Share December 20, 2018 Nowadays the gearboxes will do the thinking, they think for you so they will do what is right for you and themselves so leave the job to them and just focus on your part, left right straight or reverse 1 Link to post Share on other sites More sharing options...
DK3410 4th Gear December 20, 2018 Share December 20, 2018 In general, treat the DSG as you would a manual, and don't do the things you wouldn't do on a manual. E.g, creep forward at low speeds at half-clutch position for extended duration, esp up slopes, etc.Dual-clutch set-ups are superior in shift response and fuel economy compared to a conventional auto with torque converter. They do need a bit of TLC though, and treating it as you would a manual is a good start. 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged December 20, 2018 Share December 20, 2018 They do need a bit of TLC though, and treating it as you would a manual is a good start. Agreed Having said that not all driver driven a manual or know how to drive a manual. Now most are class 3A license. Link to post Share on other sites More sharing options...
Ceecookie 5th Gear December 20, 2018 Share December 20, 2018 DCT is a good for those who want manual transmission characteristic without handling a clutch. Some adaption is required like being gentle on the accelerator for a moment, before flooring it when taking off. But these are quite minor. Ur right leg will still drive like an auto car. It sure make your driving more exciting than a lifeless CVT which give u the experience of a single speed transmission. That is only suited for tortoises on the road Link to post Share on other sites More sharing options...
Contipro 5th Gear December 20, 2018 Share December 20, 2018 I suppose you are able to see the gear that the car is engaged to, which only DSG gearbox commonly can. You will observe that when the car seems reluctant to move up accompany with a loud wailing noise, most likely the car is in the wrong gear (higher gear) thus have no power to move up. Try to slow down till it is 2nd gear before it reach the ramp, then it will move up without any drama. As for downhill run, just tap more on accelerator and it will work fine. Jus typical characteristics of DSG gearbox. it seem here mostly issue with DRY DSG..how about WET DGG, any valuable feedback from such car owner ? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 21, 2018 Share December 21, 2018 My 6 speed DSG lasted till 9 years 150000km then problem come. From 1st to 2nd gear got a violent jerk and thud. Somemore I changed DSG oil and filter every 40K. Suay I guess. Link to post Share on other sites More sharing options...
Jamesc Hypersonic December 21, 2018 Share December 21, 2018 Heat kills auto gearboxes. To extend life add an oil cooler. Link to post Share on other sites More sharing options...
Soya Supersonic December 21, 2018 Share December 21, 2018 My 6 speed DSG lasted till 9 years 150000km then problem come. From 1st to 2nd gear got a violent jerk and thud. Somemore I changed DSG oil and filter every 40K. Suay I guess. Where got suay? 9 years then problem come beri good liao. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 21, 2018 Share December 21, 2018 Where got suay? 9 years then problem come beri good liao.Is it bro? Read people drive more than 10 years and more than 200000km the gearbox no problem... Link to post Share on other sites More sharing options...
Soya Supersonic December 21, 2018 Share December 21, 2018 Is it bro? Read people drive more than 10 years and more than 200000km the gearbox no problem... 200k on DSG or conventional torque converter? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 21, 2018 Share December 21, 2018 200k on DSG or conventional torque converter?DSG, someone here posted but quite a while ago. Link to post Share on other sites More sharing options...
Soya Supersonic December 21, 2018 Share December 21, 2018 DSG, someone here posted but quite a while ago. I wouldn't expect a conventional torque convertor to last 200k without any sort of issues, let alone DSG with it's more complicated tech. But I would still take DSG (wet) anytime for the smooth & lightning shifts 1 Link to post Share on other sites More sharing options...
Contipro 5th Gear December 23, 2018 Share December 23, 2018 Heat kills auto gearboxes. To extend life add an oil cooler. dry DSG is air cooled. may be need special cooling fan for dry DSG so that can endure the multiple hours of jam at causeway Link to post Share on other sites More sharing options...
shrjun 5th Gear December 25, 2018 Share December 25, 2018 Exactly why manuals rule ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Xpeng is Coming to Town
Season Parking Around CBD - Inquiries / Buy / Sell
2022 Toyota GR Corolla
Volkswagen Sharan..
Volkswagen Sharan..
Carpark Gantry Cheats
