Tckrto 2nd Gear February 8, 2018 Share February 8, 2018 Nope. It was a no brand stock unit. Suzuki wanted to charge me 1500 for a pioneer headunit which I find it expensive so decided to get it installed outside. I'm sure the Bluetooth and call function will work if I get it done at suzuki so there must be a way to get it to work.Try Bukit merah lane 1 BLK 125 specialist audio. I got my Kenwood unit wiring fix up and my steering remote now working fully even the Bluetooth button is working as well. ↡ Advertisement Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 8, 2018 Share February 8, 2018 Hi everyone, I'm new to the forum and I also recently installed the z5050bt about 3 months back. Malaysian here btw. I just would like to all the sifus here, if you guys encountered issues where Waze can be launch but not able to access the controls through the headunit (even though Waze's "control Waze from car unit toggle is switch to ON"). Also, when connected to Spotify, sometimes it the screen will be stalled showing previous song title, album and artiste instead of the current song title, album and artiste. It will be only be change after switching the headunit on and off. Phone connected is IPhone 7plus. Any recommendations / solutions is greatly appreciated! Thanks! Which shop install for you? Go back to them to complain. Link to post Share on other sites More sharing options...
Newbie31 Neutral Newbie February 8, 2018 Share February 8, 2018 Which shop install for you? Go back to them to complain. Installed in MY tho. Just would like to know if anyone encountered such issues. Link to post Share on other sites More sharing options...
Paladin298 Neutral Newbie February 9, 2018 Share February 9, 2018 (edited) Confirm can work. You need to download Android Auto apk from apkmirror. Anyway, I stopped using Android Auto on my z5050bt as I find it hard to see the screen for navigation and the voice interrupting radio is quite annoying. Also, when connected, the phone can't be used so I can't check for info while at red light, but can use voice commands to reply SMS, whatsapp and Allo. Maybe good for driving in MY. Recently I heard there's wireless Android Auto coming soon and I hope this HU can support that with a firmware upgrade. Doesn't work with my S7 Edge though. Have been trying since I collected my car last week. Which Android phone are you using? May I know what's your firmware version is running on your 5050 and what USB cable are you using to connect your phone to the 5050? What's your setting for USB MTP? On or Off? Edited February 9, 2018 by Paladin298 1 Link to post Share on other sites More sharing options...
Nicholas 5th Gear February 10, 2018 Share February 10, 2018 Doesn't work with my S7 Edge though. Have been trying since I collected my car last week. Which Android phone are you using? May I know what's your firmware version is running on your 5050 and what USB cable are you using to connect your phone to the 5050? What's your setting for USB MTP? On or Off? Even my 2015 galaxy A8 works with a alibaba cable so Samsung phones definitely are not the problem. The z5050 firmware shouldn't matter except for Apple phones. Mine worked from day 1. As for the USB MTP, I don't need to give access, use the default one. You just need to make sure you have a few things: 1) Android 5+ (lollipop and above) 2) Data cable (try connecting it to your pc to make sure it works) 3) Android Auto apk installed on phone. What I haven't test is if it'll work with custom firmwares. I suggest you try a different phone or a different cable. Most audio shop will provide a usb extension for you, maybe that is the problem. If nothing helps, you can always go back to your auto shop/dealer. Link to post Share on other sites More sharing options...
Paladin298 Neutral Newbie February 12, 2018 Share February 12, 2018 Even my 2015 galaxy A8 works with a alibaba cable so Samsung phones definitely are not the problem. The z5050 firmware shouldn't matter except for Apple phones. Mine worked from day 1. As for the USB MTP, I don't need to give access, use the default one. You just need to make sure you have a few things: 1) Android 5+ (lollipop and above) 2) Data cable (try connecting it to your pc to make sure it works) 3) Android Auto apk installed on phone. What I haven't test is if it'll work with custom firmwares. I suggest you try a different phone or a different cable. Most audio shop will provide a usb extension for you, maybe that is the problem. If nothing helps, you can always go back to your auto shop/dealer. Thanks, Nicholas! The few things you highlighted, I can tick all of them. From 1 to 3. When I connect the phone to the z5050BT, the S7 will detect the connection and it will cause a popup message on my S7. It says, "No installed apps work with this USB accessory. Learn more about this accessory.... blah blah blah" and it point me to google play store to install AppRadio app instead of activating Android Auto on my S7. My S7 is connected to the 5050 via Bluetooth at the same time. Do you shut down your phone's Bluetooth before plugging into the 5050? The 5050 came with my car hence I have no idea who was the installer. I am trying to see if I can sort this out first before going back to my SE for his installer's contact. Link to post Share on other sites More sharing options...
RogerNg_185295 6th Gear February 12, 2018 Share February 12, 2018 Thanks, Nicholas! The few things you highlighted, I can tick all of them. From 1 to 3. When I connect the phone to the z5050BT, the S7 will detect the connection and it will cause a popup message on my S7. It says, "No installed apps work with this USB accessory. Learn more about this accessory.... blah blah blah" and it point me to google play store to install AppRadio app instead of activating Android Auto on my S7. My S7 is connected to the 5050 via Bluetooth at the same time. Do you shut down your phone's Bluetooth before plugging into the 5050? The 5050 came with my car hence I have no idea who was the installer. I am trying to see if I can sort this out first before going back to my SE for his installer's contact. Just get the installer contact and rectify. Why crack your head over this? Link to post Share on other sites More sharing options...
Nicholas 5th Gear February 12, 2018 Share February 12, 2018 (edited) Thanks, Nicholas! The few things you highlighted, I can tick all of them. From 1 to 3. When I connect the phone to the z5050BT, the S7 will detect the connection and it will cause a popup message on my S7. It says, "No installed apps work with this USB accessory. Learn more about this accessory.... blah blah blah" and it point me to google play store to install AppRadio app instead of activating Android Auto on my S7. My S7 is connected to the 5050 via Bluetooth at the same time. Do you shut down your phone's Bluetooth before plugging into the 5050? The 5050 came with my car hence I have no idea who was the installer. I am trying to see if I can sort this out first before going back to my SE for his installer's contact. If ask you to install appradio, means the cable is ok. Did you install android auto apk from apkmirror? Under system settings of 5050, you can also set android auto, auto launch. Edited February 12, 2018 by Nicholas Link to post Share on other sites More sharing options...
Nicholas 5th Gear February 12, 2018 Share February 12, 2018 Thanks, Nicholas! The few things you highlighted, I can tick all of them. From 1 to 3. When I connect the phone to the z5050BT, the S7 will detect the connection and it will cause a popup message on my S7. It says, "No installed apps work with this USB accessory. Learn more about this accessory.... blah blah blah" and it point me to google play store to install AppRadio app instead of activating Android Auto on my S7. My S7 is connected to the 5050 via Bluetooth at the same time. Do you shut down your phone's Bluetooth before plugging into the 5050? The 5050 came with my car hence I have no idea who was the installer. I am trying to see if I can sort this out first before going back to my SE for his installer's contact. Missed out one of the question. No need to shut down bluetooth. In fact, android auto uses the bluetooth to transmit music and calls. If still cannot, tmr you come to punggol I try to fix. (Free but no promises it'll work) Link to post Share on other sites More sharing options...
Mach23 2nd Gear February 17, 2018 Share February 17, 2018 Does anyone know how to mute the HU automatically upon engaging the reverse gear? Mine doesn’t even ATT (attenuate to lower volume) and the reverse beeper is hard to listen to. Link to post Share on other sites More sharing options...
Acegem84 1st Gear February 22, 2018 Share February 22, 2018 i have a local set (with warranty) Pioneer AVH-Z5050BT for sale. Selling due to trading in car to dealer. Let me know if you're interested thanks 1 Link to post Share on other sites More sharing options...
Caveman5708 Neutral Newbie February 27, 2018 Share February 27, 2018 Morning to all e gurus here..i am planning to install a 5050.wanna check if it is possible to mirror youtube videos or my personal downloaded videos after i install APK on my samsung hp? Thinkin of buying 5050 instead if 8850. Thanks a million. Sorry i also posted this in e 8850 thread. My bad. 1 Link to post Share on other sites More sharing options...
Nicholas 5th Gear February 27, 2018 Share February 27, 2018 Morning to all e gurus here..i am planning to install a 5050.wanna check if it is possible to mirror youtube videos or my personal downloaded videos after i install APK on my samsung hp? Thinkin of buying 5050 instead if 8850. Thanks a million. Sorry i also posted this in e 8850 thread. My bad. https://www.androidpolice.com/2018/01/14/youtubeauto-brings-youtube-playback-android-auto-unit/ Haven't tried yet. Will try soon and feedback. Link to post Share on other sites More sharing options...
Nicholas 5th Gear March 1, 2018 Share March 1, 2018 Morning to all e gurus here..i am planning to install a 5050.wanna check if it is possible to mirror youtube videos or my personal downloaded videos after i install APK on my samsung hp? Thinkin of buying 5050 instead if 8850. Thanks a million. Sorry i also posted this in e 8850 thread. My bad. Video showing youtube in Z5050BT: https://drive.google.com/file/d/1qNHGLskrSltXSXCIbpWPBZc-WqPLaFRV/view?usp=sharing Needs to use pre-3.0 AA. Link to post Share on other sites More sharing options...
sneggg 1st Gear March 2, 2018 Share March 2, 2018 i just installed this hu can’t get waze to work on iphone. Link to post Share on other sites More sharing options...
Nicholas 5th Gear March 2, 2018 Share March 2, 2018 i just installed this hu can’t get waze to work on iphone. Did you update the Z5050BT? The latest update fixes IOS issues. Link to post Share on other sites More sharing options...
sneggg 1st Gear March 2, 2018 Share March 2, 2018 Did you update the Z5050BT? The latest update fixes IOS issues.i tried to update but the update function is blank out can’t click. any idea? Link to post Share on other sites More sharing options...
Nicholas 5th Gear March 2, 2018 Share March 2, 2018 (edited) i tried to update but the update function is blank out can’t click. any idea? You need to use a usb drive https://www.pioneer.com.sg/common/files/firmware/FW%20Update%20Instructions_AVH-Z7050BT_AVH-Z5050BT_AVH-Z2050BT_AVH-Z1050DVD.pdf DL firmware here: https://www.pioneer.com.sg/sg/support/firmware/index.html/ Edited March 2, 2018 by Nicholas ↡ Advertisement Link to post Share on other sites More sharing options...
[Seek experts' views] Pioneer Z9250BT vs stock HU
pioneer sda-835 tab
pioneer sda-835 tab
Pioneer z9250bt keep losing GPS after sometimes.
Need to borrow Microphone for Pioneer Auto-EQ
Pioneer AVH-Z9150BT
Pioneer AVH-Z9150BT
Connecting Pioneer sub TS-WX130DA to Output RCA of amp GM-D8704
