vincenttan67 April 26, 2019 Share April 26, 2019 (edited) May I ask advise from any Axio drivers year 2008 for NZE141? Q: This model fan motor only turns when you switch on the aircon right? When the aircon is not switch on, the fan motor doesn't rotate at all. Is your Axio works the same ? Unlike my previous old car corolla & corolla, even when aircon is not on, the fan motor automatically switch on when the radiator becomes hotter and hotter It will cools down the raidator thanks alot Edited April 26, 2019 by vincenttan67 ↡ Advertisement Link to post Share on other sites More sharing options...
cmcex 4th Gear April 26, 2019 Share April 26, 2019 May I ask advise from any Axio drivers year 2008 for NZE141? Q: This model fan motor only turns when you switch on the aircon right? When the aircon is not switch on, the fan motor doesn't rotate at all. Is your Axio works the same ? Unlike my previous old car corolla & corolla, even when aircon is not on, the fan motor automatically switch on when the radiator becomes hotter and hotter It will cools down the raidator thanks alot U should have 2 fans at ur radiator core. 1 for aircon and 1 for radiator. if radiator is not moving, ur motor is gone. this 2 fans are good buddy, 1 down u have to change 2 motor, the other one if u dont change will also be gone very soon Link to post Share on other sites More sharing options...
vincenttan67 April 26, 2019 Author Share April 26, 2019 (edited) Dear Sir, OLD car yes, always got 2 , one for Radiator, one for Aircon Now all 2008 Axio only have one Fan motor, the fan motor design is abit different, as I already mention and having doubts. It only Switch on aircon then the fan turns.Any Axio driver have similar problem? please advise I believe other AXio driver will have similar issue, my concern is once any owner drive a car without turning on the aircon,, the radiator cannot take it. hope for Axio owner or other car owner expert comment and answer, thanks U should have 2 fans at ur radiator core. 1 for aircon and 1 for radiator. if radiator is not moving, ur motor is gone. this 2 fans are good buddy, 1 down u have to change 2 motor, the other one if u dont change will also be gone very soon Edited April 26, 2019 by vincenttan67 Link to post Share on other sites More sharing options...
cmcex 4th Gear April 26, 2019 Share April 26, 2019 (edited) Dear Sir, OLD car yes, always got 2 , one for Radiator, one for Aircon All 2008 Axio only have one Fan motor, the fan motor design is abit different, as I already mention and having doubts. It only Switch on aircon then the fan turns.Any Axio driver have similar problem? please advise I believe other AXio driver will have this issue once the jam is more than 2 hours if entering JB, the radiator cannot take it. So I wait for Axio owner answer, thanks if single fan motor, it will be 2 steps, any point radiator fan not moving if aircon off despite radiator hot means motor gone. 2 steps mean 2 speed, 1 for dispersing heat for radiator, 2 for aircon. Edited April 26, 2019 by cmcex Link to post Share on other sites More sharing options...
Djonitan Clutched July 29, 2019 Share July 29, 2019 Hi, I presume you're still using your Axio, how is the acceleration like? I understand that Axio is using CVT (K310) and I'd like to know whether the pick up is good. I use Allion which has the same CVT and the pick up is not that good. Thank you. Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged July 29, 2019 Share July 29, 2019 Hi, I presume you're still using your Axio, how is the acceleration like? I understand that Axio is using CVT (K310) and I'd like to know whether the pick up is good. I use Allion which has the same CVT and the pick up is not that good. Thank you. I think we need a point of reference. What is good pick up and what is not that good? Try using a car acceleration app? A good old stop watch to time 0-60kmh? Then compare with specs or another similar car? I reckon you should be clocking 0-100kmh in 12secs. Link to post Share on other sites More sharing options...
Djonitan Clutched July 29, 2019 Share July 29, 2019 the acceleration is held for a while and the engine rpm increases without significant acceleration. It is like when your clutch worn out if you are using manual transmission. Link to post Share on other sites More sharing options...
HansLoh Neutral Newbie October 27, 2019 Share October 27, 2019 Hi.. Does any bros here know the part number for the ignition coil of 2007 toyota axio? Thank you in advance. Link to post Share on other sites More sharing options...
Wallaw819 4th Gear October 27, 2019 Share October 27, 2019 1 hour ago, HansLoh said: Hi.. Does any bros here know the part number for the ignition coil of 2007 toyota axio? Thank you in advance. Link to post Share on other sites More sharing options...
HansLoh Neutral Newbie October 27, 2019 Share October 27, 2019 14 hours ago, Wallaw819 said: Hi Wallaw819, thank you for your help to provide the information. Can check with you, my toyota axio is 2007 1500cc model so the ignition coil part number should be 9091902248 right? Other ignition coil part number ending like 2240 cannot be used right? Hope you can share with me if you know. Thank you for your kind help Link to post Share on other sites More sharing options...
Ct3833 Supersonic October 28, 2019 Share October 28, 2019 3 hours ago, HansLoh said: Hi Wallaw819, thank you for your help to provide the information. Can check with you, my toyota axio is 2007 1500cc model so the ignition coil part number should be 9091902248 right? Other ignition coil part number ending like 2240 cannot be used right? Hope you can share with me if you know. Thank you for your kind help @HansLohif you are going to buy one and replace it yourself, it would be better if you pull out one and look at the part number, or if you go to workshop, I am sure they have spare abmvaiabl, this is a very common part. Link to post Share on other sites More sharing options...
Wallaw819 4th Gear October 28, 2019 Share October 28, 2019 3 hours ago, HansLoh said: Hi Wallaw819, thank you for your help to provide the information. Can check with you, my toyota axio is 2007 1500cc model so the ignition coil part number should be 9091902248 right? Other ignition coil part number ending like 2240 cannot be used right? Hope you can share with me if you know. Thank you for your kind help Sorry can't advise on this. Link to post Share on other sites More sharing options...
HansLoh Neutral Newbie April 19, 2021 Share April 19, 2021 (edited) Hi brothers and sisters Has anyone heard about shock absorber under this brand “VETTO”? If have any information or review, kindly share with me. Thank you 🙏 😊 Edited April 19, 2021 by HansLoh Wrong spelling ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 4th Generation Toyota Alphard & Vellfire
Nissan Claims Toyota RAV4 Hybrid Fuel Economy Estimates Are Unrealistic
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
