Ct3833 Supersonic January 8, 2020 Share January 8, 2020 (edited) 31 minutes ago, Sdf4786k said: Proof that conti cars like Audi still fair better than Honda Civic Type R. While most conti cars are built tougher which means will help reduce the extent of damage in a case of collision, I choose to believe the extent of the damage mainly depending on how closely one tailgate the other and their reaction speed. If one tailgates the front car too closely , the impact will be greater as he will have little time to react. or if he reacts too late, the side effect will be the car behind will also be given lesser time to react, causing a heavier impact during the collision. So in a chain collision, not all damage are equal, the one who tailgate closely will suffer more severe damage. Edited January 8, 2020 by Ct3833 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 8, 2020 Share January 8, 2020 10 hours ago, Jamesc said: the tricycle for the Ah Peh very interesting good slow excercise for ah Peh also 1 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic January 8, 2020 Share January 8, 2020 14 hours ago, Blueray said: The white car guy has done his best for motor people already his car is already all the way to the right hand side. He tried his best to give more space for motor people Link to post Share on other sites More sharing options...
Sdf4786k Twincharged January 8, 2020 Share January 8, 2020 13 minutes ago, Ct3833 said: While most conti cars are built tougher, I choose to believe the extent of the damage mainly depending on how closely one tailgate the other and their reaction speed. If one tailgate the front car too closely , the impact will be greater as he will have little time to react. or if he reacts too late, the side effect will be the car behind will also be given lesser time to react, causing a heavier impact during the collision. So in a chain collision, not all damage are equal, the one who tailgate closely will suffer more severe damage. so what you are saying is if a vehicle is stationary at the point of impact will be more rigid or because of the two vehicle in motion, at the point of impact the speed is different and hence one vehicle from behind will fair worst than the vehicle (audi) in front ? Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 8, 2020 Share January 8, 2020 5 minutes ago, Sdf4786k said: so what you are saying is if a vehicle is stationary at the point of impact will be more rigid or because of the two vehicle in motion, at the point of impact the speed is different and hence one vehicle from behind will fair worst than the vehicle (audi) in front ? I am saying if a car maintains sufficient safety distance, he would have more time to stop, even if he could not, by the time his car comes into contact with the front one, the speed would have been significantly reduced, thereby reducing the damage of collision. That means, when all else equal, a car that has a longer safety distance will likely to have less damage than one who tailgates closely. That is one of the possibilities why in a chain collision, some cars have more severe damage than others. Of cause there are other reasons as well, like brake efficiency, toughness of a car, driver alertness . 1 Link to post Share on other sites More sharing options...
therock Supersonic January 8, 2020 Share January 8, 2020 When one sees a crumpled hood, it may not mean the car is lesser built .. it depends on how the car was designed. On the other hand, Jap cars tend to maximise fuel economy by making their cars lighter. So something has to give, and typically there is a frame which is reinforced, whilst the metalwork is relatively thin, and tends to bend or fold or dent. But hey, don't whine about the FC then if you want a heavy car.... or get a car with the latest tech, which offers good wind resistance, a good engine and yet has solid metalwork.. 3 Link to post Share on other sites More sharing options...
Eyke Supercharged January 8, 2020 Share January 8, 2020 15 hours ago, Ct3833 said: So all, please as much as we could, keep a good safety distance . A good distance would be one that allow ourselves to stop in time in case of an ebrake situation just to add: BBK doesn't stop you faster; it only helps to delay brake fade when you are doing repeated hard braking (like when on track). 4 Link to post Share on other sites More sharing options...
Ysc3 Twincharged January 8, 2020 Share January 8, 2020 Whose fault? 1 6 Link to post Share on other sites More sharing options...
commonjunks Supercharged January 8, 2020 Share January 8, 2020 11 hours ago, boonhat_91 said: just before the crashes the man's voice says "careful ah" so could it be... woman driver? Would be James MIL 😁 2 Link to post Share on other sites More sharing options...
Mockngbrd Supersonic January 8, 2020 Share January 8, 2020 Just now, Ysc3 said: Whose fault? 8 Link to post Share on other sites More sharing options...
Vid Hypersonic January 8, 2020 Share January 8, 2020 14 minutes ago, Ysc3 said: Whose fault? Toyota's fault lor. Clear cut 1 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 8, 2020 Share January 8, 2020 25 minutes ago, Ysc3 said: Whose fault? No fault, it is stupid to be parking so close to a big vehicle , turning some more. Maybe inexperience, now he learned. 1 2 Link to post Share on other sites More sharing options...
Ysc3 Twincharged January 8, 2020 Share January 8, 2020 6 minutes ago, Ct3833 said: No fault, it is stupid to be parking so close to a big vehicle , turning some more. Maybe inexperience, now he learned. the Toyota want to siam the bikes in front so can make a dash at the green light … but .. 2 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 8, 2020 Share January 8, 2020 (edited) 41 minutes ago, Ysc3 said: the Toyota want to siam the bikes in front so can make a dash at the green light … but .. is it a PXX again ? 🙊🙊 Edited January 8, 2020 by Ct3833 1 Link to post Share on other sites More sharing options...
Stooky 6th Gear January 8, 2020 Share January 8, 2020 1 hour ago, Ct3833 said: is it a PXX again ? 🙊🙊 Yes Vehicle No. SJP1500P Under Private Hire Scheme Yes Vehicle Make TOYOTA Decal No. A116507 1 3 Link to post Share on other sites More sharing options...
Vratenza Supersonic January 8, 2020 Share January 8, 2020 3 hours ago, Ysc3 said: Whose fault? LTA's fault...for allowing idiotic PHV drivers on the road without proper vocational training. 1 5 Link to post Share on other sites More sharing options...
Ysc3 Twincharged January 8, 2020 Share January 8, 2020 22 minutes ago, Stooky said: Yes Vehicle No. SJP1500P Under Private Hire Scheme Yes Vehicle Make TOYOTA Decal No. A116507 Mission statement for PHV : Time is Money ! 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic January 8, 2020 Share January 8, 2020 1 minute ago, Vratenza said: LTA's fault...for allowing idiotic PHV drivers on the road without proper vocational training. Have lah, on the job training, making mistake at the expense of you and me. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Mercedes CLE
Mercedes CLE
Future of Driving
Future of Driving
Mercedes AMG GT Gen 2
2023/2024 6th Generation Mercedes E-Class (W214)
2014 Mercedes CLA
2014 Mercedes CLA
[Spyshots] 2022 2nd Generation Mercedes Benz GLC
Mercedes Owners Thread
