Kklim Supercharged November 19, 2019 Share November 19, 2019 Need to replace my rear shocks (G11 Sylphy). Any difference between oil and gas-filled ones? Don't have much in the boot and usually only one passenger in the rear. ↡ Advertisement Link to post Share on other sites More sharing options...
QQDreamer 4th Gear November 19, 2019 Share November 19, 2019 get the gas filled type. it last longer than the oil type. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 19, 2019 Share November 19, 2019 Yes and no. A popular misconception is that a gas shock works on gas where as an oil (normal) shock works on oil. All conventional automotive shocks work by forcing oil through a programmed set of holes, however, a gas shock will use compressed gas to keep the oil under pressure. This is done largely to minimize aeration or "foaming" of the oil which would reduce the effectiveness of the shock as air passes through the valves rather than fluid. To see what this is like, tip a conventional shock absorber upside down and pump the shaft a few times. You'll notice the movement becomes jerky and uneven as oil and air intermittently pass through the valves. The gas also helps to dissipate heat which keeps the oil cooler and maintains the viscosity and therefore the shock "rate". Gas shocks are ideally suited to long travel applications like rallying and off road. In fact, this is where the technology was primarily developed in the first place as lots of spring travel over big bumps really tests a conventional hydraulic shock. There are many types of gas shock, twin-tube, mono-tube and remote canister combinations for super heavy-duty use like rallying and off-road racing. Most of the economical gas shocks are of a twin-tube construction (low-pressure) whereas most performance or race gas shocks use a mono-tube (high-pressure) system. There is no such thing as an ideal system, it really depends on the application as mono-tubes may have advantages in some respect but the high-pressure gas can act as a spring complicating the suspension design process. The main disadvantage of a gas-pressurized shock costs more of it compared with a conventional hydraulic. This leads to a very simple rule of thumb to help avoid confusion. If faced with a choice of gas or oil for the same price, it's unlikely that the real working part of the gas shock is of the same standard and level of sophistication as the oil. You get what you pay for. And, choosing gas shocks generally, mean you'll need to design the rest of the suspension system around that fact with spring and bar rates being affected. 3 Link to post Share on other sites More sharing options...
Kklim Supercharged November 20, 2019 Author Share November 20, 2019 Thanks, guys. Should replace the rubber bush and mounting as well, right? Looking at this: https://shopee.com.my/APM-REAR-ABSORBER-1-PAIR-NISSAN-SYLPHY-G11-2.0-i.11737756.2086529503 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 20, 2019 Share November 20, 2019 6 minutes ago, Kklim said: Thanks, guys. Should replace the rubber bush and mounting as well, right? Looking at this: https://shopee.com.my/APM-REAR-ABSORBER-1-PAIR-NISSAN-SYLPHY-G11-2.0-i.11737756.2086529503 yeah. just replace one shot. If not next time when you wanna replace, the parts might be cheap, but the labor will add in some cost to it. Link to post Share on other sites More sharing options...
Kklim Supercharged March 4, 2020 Author Share March 4, 2020 (edited) What about the rubber seats (one on top, other below) for the springs? Replace too? But so far, no funny sounds from rear. Edited March 4, 2020 by Kklim Link to post Share on other sites More sharing options...
inlinesix Supersonic March 4, 2020 Share March 4, 2020 Change everything in 1 go including dust cover Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 4, 2020 Share March 4, 2020 21 minutes ago, inlinesix said: Change everything in 1 go including dust cover Yeah. @inlinesix is right. It is cheaper to change everything one go because the labour will cost a bit. You go change 2 times, they charge you 2 times. 26 minutes ago, Kklim said: What about the rubber seats (one on top, other below) for the springs? Replace too? But so far, no funny sounds from rear. Link to post Share on other sites More sharing options...
Discoburg Supersonic March 4, 2020 Share March 4, 2020 Go back stock. ↡ Advertisement Link to post Share on other sites More sharing options...
Google Maps can now tune its eco-friendly navigation for gas, diesel, and electrified vehicles
Gas oil theft from Pulau Bukom refinery; ex-Shell officer jailed 29 years after masterminding S$129m gas oil theft from Pulau Bukom refinery
Getting City Gas Into Landed Property
What's Your Utility Bill Like and how to reduce it
How long does it take for gas to go bad?
