Illegal car modifications
Yewheng
Old news. I think there’s also another news about being fined for the same traffic offence will increase the 2nd, 3rd and subsequent times?
example, fined parking at yellow line $70. Then within same year will fined increased to $100 2nd time etc.
2 hours ago, Jamesc said:
This type allowed right?
:grin:
Yes allowed. These are electric horns.
I got a few units available. Lai pm.
  • Haha! 1
7 hours ago, Yewheng said:
Screenshot_20200614_095244_com.android.chrome.thumb.jpg.e82b89f458d010e5b4aacbeb7c71a29e.jpg
Change of horns to air horn also not allowed hor.
magnum horns can. those are not considered air horns.
Just curious, are all horns when changing to after mkt requires a new relay and wiring. Is there any plug and play type of horn ?
Internal Moderator
You wanna change horn arh? 🧐
Beep beep for social distancing issit. hahah.
  • Haha! 1
somehow the way the horn is configure for my car is one horn is mid to high pitch, one side is low or (weak).
The horn seems either weak now or one side kaput liao..
when I lean on the horn , it sounds like the horn has asthma attack
Edited by Sdf4786k
  • Haha! 2
Lao Hong = laoya horn
  • Haha! 2
Internal Moderator
My understanding there is 2 type of horns in the market.
One is those trumpet horn.
https://www.amazon.com/PIAA-85115-Superior-Bass-Horn/dp/B0060ZB43G/ref=sr_1_6?dchild=1&keywords=car+horn&qid=1592281789&sr=8-6
And the disc horn.
https://www.amazon.com/HELLA-011225802-Black-77mm-Universal/dp/B01C8F0AUY/ref=sr_1_8?dchild=1&keywords=car%2Bhorn&qid=1592281789&sr=8-8&th=1
If your space is not constrained, then can choose the trumpet one. Sure louder.
I dunno about the relay thou. Never change my horns before. hahah. But if you see me, you don't horn me arh. hahahaha.
Long time ago I had a horn that sounded like having sore throat. Sprayed WD40 into it - worked till the car was scrapped.
Edited by Volvobrick
  • Praise 2
wow! Didn’t know WD40 is for car sore throat maciam this frost spray...
  • Haha! 2
yes need to add a relay.
yes need relay and do some wiring, just change to stebel trombe early this year, the relay already inside the box.
  • Praise 2
thanks.. will try it out...
May I check , so must swap out the old relay and fit new relay or must run a wire separately from the original ?
mine got new wires , different car might be different u might want to check with your car workshop
depending on the current drawn for the horn, some draw a much higher current than the stock horn (check the fuse for the stock horn)
