ismailmiller 1st Gear July 16, 2020 Share July 16, 2020 Hi Guys, Just an interesting question. My 2010 altis is on 16 inch and my tires are wearing out. When the car is driven around 100-110km, the ride is quite stable with 16 inch rims (205/55). I was wondering if I change back to original stock settings of 195/65/15 would the stability be reduced? I remembered driving my old vios at 100km/hr and the car feels like it's unstable on the stock rims (195/65/15) maybe because the kerb weight is only 1095 kg. Of course altis weighs 1255 kg so theoretically the car should have better stability. Just wondering if anyone here is on stock rims (195/65/15) can share their experience driving at those higher speeds >100km/h. Thanks. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Beregond Supersonic July 16, 2020 Share July 16, 2020 12 minutes ago, ismailmiller said: Hi Guys, Just an interesting question. My 2010 altis is on 16 inch and my tires are wearing out. When the car is driven around 100-110km, the ride is quite stable with 16 inch rims (205/55). I was wondering if I change back to original stock settings of 195/65/15 would the stability be reduced? I remembered driving my old vios at 100km/hr and the car feels like it's unstable on the stock rims (195/65/15) maybe because the kerb weight is only 1095 kg. Of course altis weighs 1255 kg so theoretically the car should have better stability. Just wondering if anyone here is on stock rims (195/65/15) can share their experience driving at those higher speeds >100km/h. Thanks. 205.55.16 confirm more stable then 195.65.15. u will feel it esp when the road is uneven. nothing to do with the weight of the rim, but the width and thickness of your tyres 3 Link to post Share on other sites More sharing options...
Watwheels Supersonic July 16, 2020 Share July 16, 2020 (edited) Stability should be looking at the car's chassis setup, suspension and center of gravity (engine and gb). For a car it's never a one off factor or item that affect the stability and handling. Dunno why some guys always like to focus on one thing and ignore the rest. Edited July 16, 2020 by Watwheels 4 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged July 16, 2020 Share July 16, 2020 58 minutes ago, ismailmiller said: Hi Guys, Just an interesting question. My 2010 altis is on 16 inch and my tires are wearing out. When the car is driven around 100-110km, the ride is quite stable with 16 inch rims (205/55). I was wondering if I change back to original stock settings of 195/65/15 would the stability be reduced? I remembered driving my old vios at 100km/hr and the car feels like it's unstable on the stock rims (195/65/15) maybe because the kerb weight is only 1095 kg. Of course altis weighs 1255 kg so theoretically the car should have better stability. Just wondering if anyone here is on stock rims (195/65/15) can share their experience driving at those higher speeds >100km/h. Thanks. I was on 195/16 and changed to 205/16 before and honestly, not much difference. But i can comfortably go around 120 and the kerb weight of my car is slightly less than your vios. Stability on higher speeds depends more on the kerb weight, steering feedback, suspension setup and your guts. Lol. Up north, alot of stock Altis can overtake me with ease. I've driven the first gen vios and I don't feel is unstable above 100kmph. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic July 16, 2020 Share July 16, 2020 (edited) Stick to stock size. If they give you 60 pr 65 profile tyre size, you are in luck. Too low a profile with broad rectangular shape contact patch is a magnet for punctured tyre and aquaplaning. Edited July 16, 2020 by Kangadrool 2 Link to post Share on other sites More sharing options...
Cephas 3rd Gear July 16, 2020 Share July 16, 2020 (edited) I find rim change is more towards aesthetic consideration unless there a compromise on safety. I believe stock rims are designed with good safety factor in mind on what the car's can-do limitations. Edited July 16, 2020 by Cephas Link to post Share on other sites More sharing options...
Toeknee_33 Turbocharged July 16, 2020 Share July 16, 2020 3 hours ago, ismailmiller said: Hi Guys, Just an interesting question. My 2010 altis is on 16 inch and my tires are wearing out. When the car is driven around 100-110km, the ride is quite stable with 16 inch rims (205/55). I was wondering if I change back to original stock settings of 195/65/15 would the stability be reduced? I remembered driving my old vios at 100km/hr and the car feels like it's unstable on the stock rims (195/65/15) maybe because the kerb weight is only 1095 kg. Of course altis weighs 1255 kg so theoretically the car should have better stability. Just wondering if anyone here is on stock rims (195/65/15) can share their experience driving at those higher speeds >100km/h. Thanks. What do you mean when you use the word "stable/unstable"? Can you describe? 2 hours ago, Watwheels said: Stability should be looking at the car's chassis setup, suspension and center of gravity (engine and gb). For a car it's never a one off factor or item that affect the stability and handling. Dunno why some guys always like to focus on one thing and ignore the rest. I agree with you that the rims size is not the only consideration when it comes to handling, grip and stability. Different cars have different characteristics. If we are talking about the same car, then choice of tyre brand/model, damper condition, suspension arms/bushes condition, wheel alignment, aerodynamics - they all play a part. Oh! And also weight distribution. Carry more passengers or heavy load in the boot also has drastic effects. It is also a common fallacy that heavier cars are more stable. Its not true. The heavier the car, the harder to control the body movements on uneven roads, the harder for the tyres to change directions. The Lotus Elise is light, F1 cars are light. Anyway, 100kmh is not that high a speed lah..but these are my thoughts - Bigger rims = lower profile tyres = less ride comfort and more road noise. Bigger rims = thinner tyre sidewalls = less flexing of tyre during hard corners = more precise handling and road feel (if TS is sensitive enough to feel it and its important to him, that is) Bigger rims = heavier rim/tyre combo = more unsprung weight = harder for dampers to control the movement of the wheels = more bouncing around on uneven roads. 1 Link to post Share on other sites More sharing options...
Soya Supersonic July 21, 2020 Share July 21, 2020 The car is 10yrs old. The wear n tear on suspension, driveshafts, steering rack, engine & GB mounts all contribute to the problem. Upsizing the rims will juz amplify instead of solving it. 1 Link to post Share on other sites More sharing options...
SamuelWyatt Neutral Newbie November 24, 2020 Share November 24, 2020 I ordered tires for my truck, which were about $1200. Rims look pretty ratty, about $1000 to have them refinished, and i would be without my truck for 3-4 days. Looked at the online classifieds (like craigslist) and found somebody selling the factory rims and tires from their higher trim level truck for $1250 because they put something flashier on their truck. They are called takeoffs, and quite common. So look around before to spend money on new tires. Link to post Share on other sites More sharing options...
SamuelWyatt Neutral Newbie November 26, 2020 Share November 26, 2020 On 11/24/2020 at 5:17 PM, SamuelWyatt said: I ordered tires for my truck, which were about $1200. Rims look pretty ratty, about $1000 to have them refinished, and i would be without my truck for 3-4 days. Looked at the online classifieds (like craigslist) and found somebody selling the factory rims and tires from their higher trim level truck for $1250 because they put something flashier on their truck. They are called takeoffs, and quite common. So look around before to spend money on new tires. Tweakbox issue got solved ↡ Advertisement Link to post Share on other sites More sharing options...
[Official] 2024 Lexus LBX
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota Corolla AE86 Revival! Initial D Fans COME IN!
Reliable PI: Toyota Camry
