Volvobrick Supersonic August 23, 2020 Share August 23, 2020 Maybe @Notiwain from Cowtax... ↡ Advertisement Link to post Share on other sites More sharing options...
Enye Hypersonic August 23, 2020 Share August 23, 2020 wah... 12 yo car only travel 400km maybe engine oil turn mouldy already... 😅🤣 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 23, 2020 Share August 23, 2020 On 8/22/2020 at 12:46 PM, Notitwain said: Hi, Anybody using Sinopec xpower? I tried last week and after travelling 400km on my 12years old honda, I encountered my engine oil turning green. My friend who drive a new Toyota also has the same issue. Anybody face the same problem? The both of you have a large amount of coolant leaking into your engine oil. Check what colour is in the coolant reservoir. If it's brown or black you have a leak. Link to post Share on other sites More sharing options...
Shibadog Turbocharged August 23, 2020 Share August 23, 2020 18 hours ago, Yippe said: Greed colored Engine Oil, I known was from Bell-Ray (Racing Oil) for Bikes. I used on my Bikes years ago, high rev. NP 1. So was the Engine Oil previous owner filled . Or you purchased the Bell-Ray. this oil is also a light translucent green when new. Reminds me of dishwashing liquid. Turns brown/black quickly though https://www.schaefferoil.com/9000-racing-oil.html Link to post Share on other sites More sharing options...
Contipro 5th Gear August 23, 2020 Share August 23, 2020 1 hour ago, Watwheels said: The both of you have a large amount of coolant leaking into your engine oil. Check what colour is in the coolant reservoir. If it's brown or black you have a leak. if you mentioned coolant "large amount" leak into engine oil, means coolant side having high pressure than engine oil side. then not look at coolant colour, instead check whether large drop of coolant level. Link to post Share on other sites More sharing options...
Albeniz Turbocharged August 23, 2020 Share August 23, 2020 23 hours ago, Ganwb79 said: Instead of asking in forums, you should go to your mechanic/workshop... Maybe the mechanic also don't know. 1 Link to post Share on other sites More sharing options...
Daniu82 Supercharged August 23, 2020 Share August 23, 2020 10 minutes ago, Albeniz said: Maybe the mechanic also don't know. Then need more upgrading or get a more knowledgeable person in the workshop. Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 23, 2020 Share August 23, 2020 28 minutes ago, Albeniz said: Maybe the mechanic also don't know. Quite possible. Once I went JB to flush out my coolant and put new one in. They flush out my radiator and then put in my new pink coolant. I open the bonnet and saw the old green coolant still in the reserve container. The only thing they could do is suck out the old green coolant and add new coolant. Most mechanics never studies car engines. They learn on the job by seeing the old birds do what. The old birds also never went to technical school and also learn from seeing other people do what. And cooling system is the least understood of all car systems. Coolant is not only in the radiator and reserve tank, its actually in the engine block lining. 5 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 23, 2020 Share August 23, 2020 1 hour ago, Jamesc said: Quite possible. Once I went JB to flush out my coolant and put new one in. They flush out my radiator and then put in my new pink coolant. I open the bonnet and saw the old green coolant still in the reserve container. The only thing they could do is suck out the old green coolant and add new coolant. Most mechanics never studies car engines. They learn on the job by seeing the old birds do what. The old birds also never went to technical school and also learn from seeing other people do what. And cooling system is the least understood of all car systems. Coolant is not only in the radiator and reserve tank, its actually in the engine block lining. They watch from youtube lah. hahah. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 23, 2020 Share August 23, 2020 7 minutes ago, kobayashiGT said: They watch from youtube lah. hahah. This Video is telling People Modern Car no need to warm up,esp in Warm Countries like Ours... 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 23, 2020 Share August 23, 2020 (edited) 5 hours ago, Contipro said: if you mentioned coolant "large amount" leak into engine oil, means coolant side having high pressure than engine oil side. then not look at coolant colour, instead check whether large drop of coolant level. You can Google. If the engine head gasket is compromised the engine oil and coolant will leak both ways with the engine oil filling up the coolant reservoir. This is common for cars over 10yo. The engine head gasket needs replacement. Edited August 23, 2020 by Watwheels 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 23, 2020 Share August 23, 2020 16 minutes ago, Watwheels said: You can Google. If the engine head gasket is compromised the engine oil and coolant will leak both ways with the engine oil filling up the coolant reservoir. This is common for cars over 10yo. The engine head gasket needs replacement. Yes I kanna on my previous 23 y o ek3. My coolant become tehsi colour, if I sell the mixture as tehsi, nobody can tell. 2 Link to post Share on other sites More sharing options...
Contipro 5th Gear August 24, 2020 Share August 24, 2020 10 hours ago, Watwheels said: You can Google. If the engine head gasket is compromised the engine oil and coolant will leak both ways with the engine oil filling up the coolant reservoir. This is common for cars over 10yo. The engine head gasket needs replacement. ok Google, engine oil mix with water turn greenish or milky ? Link to post Share on other sites More sharing options...
Watwheels Supersonic August 24, 2020 Share August 24, 2020 (edited) 8 minutes ago, Contipro said: ok Google, engine oil mix with water turn greenish or milky ? FYI coolant is either greenish or red-ish for Japanese cars. Edited August 24, 2020 by Watwheels Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 24, 2020 Share August 24, 2020 10 hours ago, Phluvcat said: Yes I kanna on my previous 23 y o ek3. My coolant become tehsi colour, if I sell the mixture as tehsi, nobody can tell. hahaha. Cannot lah. Ppl might really drink. coolant have sweet taste to it. might really can pull off as tehsi. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 24, 2020 Share August 24, 2020 11 hours ago, ER-3682 said: This Video is telling People Modern Car no need to warm up,esp in Warm Countries like Ours... I still warm up no matter what. just to make sure the lubricant is flowing in every part of my engine first. 🤣 1 Link to post Share on other sites More sharing options...
Contipro 5th Gear August 24, 2020 Share August 24, 2020 32 minutes ago, Watwheels said: FYI coolant is either greenish or red-ish for Japanese cars. noted your advise: greenish coolant mix with engine oil = engine oil will turn greenish. 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 24, 2020 Share August 24, 2020 12 minutes ago, kobayashiGT said: hahaha. Cannot lah. Ppl might really drink. coolant have sweet taste to it. might really can pull off as tehsi. Boss u tasted? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Is It Really Cheaper To own An EV Versus A Gas Car?
Fuel Plus Meet Up
Fuel Plus Meet Up
Share Your Car Fuel Consumption
Patch Fuel Tank,use what type of Epoxy.?
