Watwheels Supersonic August 24, 2020 Share August 24, 2020 7 minutes ago, Contipro said: noted your advise: greenish coolant mix with engine oil = engine oil will turn greenish. Most private workshops will prefer to use green coolant as it's easy for the mechanic to identify there is a leak. If it's red coolant it's not easy to identify. ↡ Advertisement Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 24, 2020 Share August 24, 2020 10 minutes ago, kobayashiGT said: I still warm up no matter what. just to make sure the lubricant is flowing in every part of my engine first. 🤣 Recently I need to wait at least 5 mins for temperature to reach operating level before I drive off otherwise sometimes the idling rpm will get stuck get 1500,1800 or even 2000....can visualise the petrol wasting away. Already checked and cleaned TB and got new IAC liao... 😔 Happened again this morning. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 24, 2020 Share August 24, 2020 3 minutes ago, Phluvcat said: Recently I need to wait at least 5 mins for temperature to reach operating level before I drive off otherwise sometimes the idling rpm will get stuck get 1500,1800 or even 2000....can visualise the petrol wasting away. Already checked and cleaned TB and got new IAC liao... 😔 Happened again this morning. Is it time to replace the radiator thermostat? It's suppose to help warm up your engine on cold starts. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 24, 2020 Share August 24, 2020 8 minutes ago, Watwheels said: Is it time to replace the radiator thermostat? It's suppose to help warm up your engine on cold starts. The temperature is showing normal leh. Btw this started way before 7 month. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 24, 2020 Share August 24, 2020 18 minutes ago, Phluvcat said: The temperature is showing normal leh. Btw this started way before 7 month. I think the thermostat is stuck in open position. https://axleaddict.com/auto-repair/How-to-Determine-if-a-Cars-Engine-Thermostat-is-Stuck You scroll down to Thermostat Symptom Tests and Explanations. On the table you try the 3rd cold engine test. Quote Cold engine test: Start the engine. Time how long it takes the engine to warm up enough to produce heat when the heater is turned on. Provided your car has a heater function (from the air conditioning). Quote If it takes more than five minutes for the heater to produce heat, it is a sign that the thermostat is stuck open, allowing all the coolant to flow all the time. This causes it to take a good deal longer for the engine to warm up. 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 24, 2020 Share August 24, 2020 3 hours ago, Watwheels said: I think the thermostat is stuck in open position. https://axleaddict.com/auto-repair/How-to-Determine-if-a-Cars-Engine-Thermostat-is-Stuck You scroll down to Thermostat Symptom Tests and Explanations. On the table you try the 3rd cold engine test. Provided your car has a heater function (from the air conditioning). Thank you boss! Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 24, 2020 Share August 24, 2020 8 hours ago, Phluvcat said: Boss u tasted? No lah. Hahahha. If I drink, I can only talk to you this month leh.hahahah. They always say cannot anyhow throw your coolant, the dog and cat will drink it. Must dispose it correctly. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 24, 2020 Share August 24, 2020 8 hours ago, Phluvcat said: Recently I need to wait at least 5 mins for temperature to reach operating level before I drive off otherwise sometimes the idling rpm will get stuck get 1500,1800 or even 2000....can visualise the petrol wasting away. Already checked and cleaned TB and got new IAC liao... 😔 Happened again this morning. Need a remap liao. 😎 Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 24, 2020 Share August 24, 2020 13 hours ago, kobayashiGT said: I still warm up no matter what. just to make sure the lubricant is flowing in every part of my engine first. 🤣 Just move off slowly in Carpark will do....Warm up better this way. 5 Link to post Share on other sites More sharing options...
t0y0ta Supercharged August 24, 2020 Share August 24, 2020 13 hours ago, Phluvcat said: Recently I need to wait at least 5 mins for temperature to reach operating level before I drive off otherwise sometimes the idling rpm will get stuck get 1500,1800 or even 2000....can visualise the petrol wasting away. Already checked and cleaned TB and got new IAC liao... 😔 Happened again this morning. Just need a few seconds (10-20) to ensure the oil pump deliver the lubricant to all parts of engine first Then slowly move out of carpark. Should hit operating temp in a few minutes of easy driving. This shouldn't harm your engine Easier than stressed out trying to wait in car park lot. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 25, 2020 Share August 25, 2020 10 hours ago, ER-3682 said: Just move off slowly in Carpark will do....Warm up better this way. old habit die hard. hahha. Link to post Share on other sites More sharing options...
Sdf4786k Twincharged August 25, 2020 Share August 25, 2020 (edited) On 8/24/2020 at 9:14 AM, kobayashiGT said: I still warm up no matter what. just to make sure the lubricant is flowing in every part of my engine first. 🤣 2 problem bro.. 1. If someone wants to pautao you, Oneservice app with video will get you a fine for idleing with engine on. 2. IF really worried, which you shouldn't be for your year of manufacture. leave driver door open, put ignition to on without starting. See if you hear a whining sound. Sound be the fuel and motor pump priming. Wait for 3 secs then start ... else wasting fuel and time can never be recouped. Edited August 25, 2020 by Sdf4786k 1 Link to post Share on other sites More sharing options...
Ake109 6th Gear August 25, 2020 Share August 25, 2020 Spend time idling in car park is actually worse for the engine as it warms up slower. Drive of gently immediately lubricates the engine better and warms up faster and dont waste petrol. 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 25, 2020 Share August 25, 2020 On 8/24/2020 at 5:40 PM, kobayashiGT said: Need a remap liao. 😎 U mean direct remap ecu or use piggy back? I actually remap before by the guy who use skm compound. Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 25, 2020 Share August 25, 2020 20 hours ago, ER-3682 said: Just move off slowly in Carpark will do....Warm up better this way. Cannot... now I start engine wait about 5 mins let engine settle to about 1000 before turtling off down the mscp. Used to just release clutch let the car turtle in 1st or 2nd gear down the mscp. After that my usual routine of short shifting driving for about ten minutes... gentle driving. 1 Link to post Share on other sites More sharing options...
Phluvcat 6th Gear August 25, 2020 Share August 25, 2020 1 hour ago, Ake109 said: Spend time idling in car park is actually worse for the engine as it warms up slower. Drive of gently immediately lubricates the engine better and warms up faster and dont waste petrol. My car cold start at 2000 and drops to about 900 for normal idling. Link to post Share on other sites More sharing options...
DylanChen 2nd Gear August 26, 2020 Share August 26, 2020 13 hours ago, Phluvcat said: Cannot... now I start engine wait about 5 mins let engine settle to about 1000 before turtling off down the mscp. Used to just release clutch let the car turtle in 1st or 2nd gear down the mscp. After that my usual routine of short shifting driving for about ten minutes... gentle driving. 10s is enough for u to move on. unless yours is a carburetors Link to post Share on other sites More sharing options...
Tohto Hypersonic August 26, 2020 Share August 26, 2020 (edited) 17 hours ago, Phluvcat said: Cannot... now I start engine wait about 5 mins let engine settle to about 1000 before turtling off down the mscp. Used to just release clutch let the car turtle in 1st or 2nd gear down the mscp. After that my usual routine of short shifting driving for about ten minutes... gentle driving. Modern engine no need to wait lah, just start and drive off with lighter foot at the beginning. If need to wait, cold climate country how? I drive in Germany in winter, temperature -10deg C. 15 mins from hotel to office. Reach office still have not reach operating temperature. For our local temperature, typically my car warm up light already disappear after slow drive from car park to main road. Edited August 26, 2020 by Tohto ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Is It Really Cheaper To own An EV Versus A Gas Car?
Fuel Plus Meet Up
Fuel Plus Meet Up
Share Your Car Fuel Consumption
Patch Fuel Tank,use what type of Epoxy.?
