Contipro 5th Gear October 28, 2020 Share October 28, 2020 47 minutes ago, inlinesix said: ABS is anti-lock brake system le. Anti-skid is traction control. If not required to slam hard, why would Merc invent brake assist? are we in braking situation or moving situation ? ↡ Advertisement Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator October 28, 2020 Author Share October 28, 2020 16 hours ago, Mkl22 said: Were you on Yokohama aspec DB in the wet? Hahaha those are the most CMI tires I have ever used. When I was driving my father van last time, the only tyres he trust is Yokohama Deliverystar. 😎 Link to post Share on other sites More sharing options...
Apple-Tree 6th Gear October 28, 2020 Share October 28, 2020 22 hours ago, Mkl22 said: Were you on Yokohama aspec DB in the wet? Hahaha those are the most CMI tires I have ever used. Kumho BEST !! But bobian, many times step brake the ABS start to pulse lor. Best is BUY Jaguar, solid solid CAR. Link to post Share on other sites More sharing options...
Atonchia Supersonic October 28, 2020 Share October 28, 2020 (edited) On 10/27/2020 at 10:01 AM, kobayashiGT said: Nowadays an anti lock braking system is used in almost all modern vehicles. This system prevents accidents like this, where you lose control of the steering as you apply the brakes. With ABS you will be able to steer the vehicle properly and it also reduces the braking distance. What is ABS? How is it able to prevent accidents due to the braking? We will explore these questions in this video. I jammed braked really hard..... ABS activated.... No need to steer..... Bcos will not hit the car in front....... Then bang..... My car got hit from behind then surge forward... Hit the front vehicle... Still kept stepping hard on brake pedal.... Then few more bangs... That's the only time I really felt ABS...... 3rd of a 7 chain accident 😅 Activated... but the situation.... No use... Edited October 28, 2020 by Atonchia 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator October 29, 2020 Author Share October 29, 2020 11 hours ago, Apple-Tree said: Kumho BEST !! But bobian, many times step brake the ABS start to pulse lor. Best is BUY Jaguar, solid solid CAR. I can atest to it. I bang a Jag before. hahahahahahhaha. 2 Link to post Share on other sites More sharing options...
Syedale123 Neutral Newbie May 12, 2022 Share May 12, 2022 (edited) Hi! New here, hope you’re all well. My brother has a suzuki cervo sr 2009, a week ago i was having the car’s wheel hub adjusted and the right wheel abs speed sensor broke while taking off the hub. The sensor wasn’t available atm so i drove home and got back the next to to get the sensor. Sensor didn’t work, the code error about speed sensor not right didn’t go away after trying to clear the error with the odc software. also tried to put the already working left sensor to right, the error didn’t go. (Now it had two errors left and right, error for left sensor went away when the sensor was put back on the left). Please guide me how can that be fixed, the mechanic says might have to replace the whole abs module, which i cant understand how can that get faulty. It was working fine before the sensor and the sensor broke so its obviously the sensor’s problem. Shouldn’t it work when we put a new sensor there!? please give you expert opinion on the matter. thanks. Edited May 12, 2022 by Syedale123 Writing mistake Link to post Share on other sites More sharing options...
Jamesc Hypersonic May 12, 2022 Share May 12, 2022 I no need abs I never bang anybody. If I want to bang someone I dun one abs. Link to post Share on other sites More sharing options...
Syedale123 Neutral Newbie May 12, 2022 Share May 12, 2022 15 hours ago, Syedale123 said: Hi! New here, hope you’re all well. My brother has a suzuki cervo sr 2009, a week ago i was having the car’s wheel hub adjusted and the right wheel abs speed sensor broke while taking off the hub. The sensor wasn’t available atm so i drove home and got back the next to to get the sensor. Sensor didn’t work, the code error about speed sensor not right didn’t go away after trying to clear the error with the odc software. also tried to put the already working left sensor to right, the error didn’t go. (Now it had two errors left and right, error for left sensor went away when the sensor was put back on the left). Please guide me how can that be fixed, the mechanic says might have to replace the whole abs module, which i cant understand how can that get faulty. It was working fine before the sensor and the sensor broke so its obviously the sensor’s problem. Shouldn’t it work when we put a new sensor there!? please give you expert opinion on the matter. thanks. Link to post Share on other sites More sharing options...
AKLT Neutral Newbie May 13, 2022 Share May 13, 2022 @Kklee ABS has saved more than my fair share of drivers Link to post Share on other sites More sharing options...
Syedale123 Neutral Newbie May 16, 2022 Share May 16, 2022 On 5/12/2022 at 8:58 AM, Syedale123 said: Hi! New here, hope you’re all well. My brother has a suzuki cervo sr 2009, a week ago i was having the car’s wheel hub adjusted and the right wheel abs speed sensor broke while taking off the hub. The sensor wasn’t available atm so i drove home and got back the next to to get the sensor. Sensor didn’t work, the code error about speed sensor not right didn’t go away after trying to clear the error with the odc software. also tried to put the already working left sensor to right, the error didn’t go. (Now it had two errors left and right, error for left sensor went away when the sensor was put back on the left). Please guide me how can that be fixed, the mechanic says might have to replace the whole abs module, which i cant understand how can that get faulty. It was working fine before the sensor and the sensor broke so its obviously the sensor’s problem. Shouldn’t it work when we put a new sensor there!? please give you expert opinion on the matter. thanks. Opinions anyone? Please ↡ Advertisement Link to post Share on other sites More sharing options...
How Much Do You Know About ABS?
Mazda 5 ABS error
Mazda 5 ABS error
Braking - "Croaking" Sound
Screeching sound when braking
ABS warning lamp
ABS warning lamp
Honda Sensing
Honda Sensing
What is cheapest passenger car with auto gear & ABS
