LifePro_Tips
Save up to $100 on the Brand New Sony XS-AW8 Compact Powered Subwoofer
Enrich your in-car listening with the XS-AW8 compact powered subwoofer. The slim design allows installation in restricted spaces, and fills your car with 160W peak (75W RMS) of clean, dynamic bass. A supplied wired remote enables convenient level control from the driver's seat.
Product Highlights:
1. Ultra-sleek, shallow subwoofer
No space for a big subwoofer enclosure? At only 7.8cm deep, the XS-AW8 powered subwoofer fits in tight spaces in your vehicle for powerful bass sound throughout the car.
2. Optimally Designed Driver Unit and Low-Resonance Cast-Aluminium Enclosure
To reproduce powerful bass sound from its compact dimensions, the slim enclosure is paired with a unique rigid subwoofer diaphragm. The built-in amplifier also integrates a sturdy heat-sink to protect the driver unit and amp without introducing unwanted vibrations and harmonic distortion.
3. Supplied Wired Remote Commander
A supplied wired remote commander allows you to adjust the subwoofer volume from the driver's seat.
4. High Level Input/Audio Line Input
What if you're using a factory radio that doesn't have pre-amp outputs? Simply connect the speaker outputs of your receiver to the high-level inputs. When pre-out audio signals are available from the receiver, connect them to the CH1(R) and CH2(L) terminals. Compatibility with up to 5V pre-outs means you can utilise higher voltage audio input for a clean audio signal and less external noise.
5. Single-Sided Controls and Terminals
Connections and amplifier controls are together on the same side for easy installation and tuning. The amplifier features a variable low-pass filter for simple connection to full-range sources, including the speaker-level inputs.
6. 160W Peak (75W RMS) Output Power
Fill your car with 160W (75W RMS) of clean, dynamic bass sound with our original power IC. The matched class A/B amp is designed for high power and natural, distortion-free sound even at high output levels.
Pair the Sony XS-AW8 with the Sony Media Receiver to save more!
Where To Buy?
Find all Sony’s Authorised Dealers here.
Share this post
