Techgod Clutched March 6, 2021 Share March 6, 2021 Hi, in Singapore how often does Audi change the brake fluid? Is it 2 years? Or must i verbally tell the AD to change the brake fluid? ↡ Advertisement Link to post Share on other sites More sharing options...
inlinesix Supersonic March 6, 2021 Share March 6, 2021 Use Brake Fluid Tester to check. Link to post Share on other sites More sharing options...
Optramagnum 6th Gear March 6, 2021 Share March 6, 2021 Refer to your owner's manual. It state the change interval for every kind of fluid. Link to post Share on other sites More sharing options...
Yeobh 4th Gear March 6, 2021 Share March 6, 2021 Brake fluid tends to absorb water vapor and overtime it will loose its default high boiling temperature , resulting in slow responses and weak braking forces. Singapore has very high humility , a two years rule of thumb to flush the brake system and replace with fresh fluid seems to be accurate. Link to post Share on other sites More sharing options...
1fast1 Supersonic March 6, 2021 Share March 6, 2021 3 hours ago, Yeobh said: Brake fluid tends to absorb water vapor and overtime it will loose its default high boiling temperature , resulting in slow responses and weak braking forces. Singapore has very high humility , a two years rule of thumb to flush the brake system and replace with fresh fluid seems to be accurate. Well, clearly, full cash, full cigar, full gold Rolex MCF doesn't really represent Singapore then. 😁 1 4 Link to post Share on other sites More sharing options...
Albeniz Turbocharged March 6, 2021 Share March 6, 2021 3 minutes ago, Turboflat4 said: Well, clearly, full cash, full cigar, full gold Rolex MCF doesn't really represent Singapore then. 😁 Muahahaha. 3 Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 7, 2021 Share March 7, 2021 Don't waste money lah. I haven't changed my MIL brake fluid for years and so far nothing has happened yet. If she crashes then I will change and tell everyone here the good news. ↡ Advertisement Link to post Share on other sites More sharing options...
2017 2nd Generation Audi Q5
New Q5 Sportback
New Q5 Sportback
