Evo5sg 2nd Gear March 28, 2021 Share March 28, 2021 (edited) Hi, my 15 year N16 Nissan Sunny suddenly has the light on. Friday still ok. Yesterday never use car. can start, but canned accelerate at all. even when stationary, cannot increase rpm at all. car can move slowly. last serviced in December 2020 at agent. any idea what is wrong? Edited March 28, 2021 by Evo5sg ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 28, 2021 Share March 28, 2021 Only OBD Sifu has the answer. 4 Link to post Share on other sites More sharing options...
Volvobrick Supersonic March 28, 2021 Share March 28, 2021 Maybe ignition related (coil, plugs). 1 Link to post Share on other sites More sharing options...
thebutcher 5th Gear March 28, 2021 Share March 28, 2021 Throttle body sensor perhaps. Had the same thing with my previous car Link to post Share on other sites More sharing options...
Ake109 6th Gear March 28, 2021 Share March 28, 2021 (edited) Can't resist. Edited March 28, 2021 by Ake109 1 12 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 28, 2021 Share March 28, 2021 Even if TS has an OBD code reader he has to know how to interpret the fault code. Sometimes it takes experience to know what triggered the fault code or codes. It might not be as straightforward as what the fault code tells you. 1 Link to post Share on other sites More sharing options...
Kangadrool Supersonic March 28, 2021 Share March 28, 2021 Don't kan chong, bring it to tan chong for a checkup. 1 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic March 28, 2021 Share March 28, 2021 11 minutes ago, Watwheels said: Even if TS has an OBD code reader he has to know how to interpret the fault code. Sometimes it takes experience to know what triggered the fault code or codes. It might not be as straightforward as what the fault code tells you. Newer obd II sends out code and also a brief analysis. 3 Link to post Share on other sites More sharing options...
Naimed 5th Gear March 28, 2021 Share March 28, 2021 12 hours ago, Evo5sg said: Hi, my 15 year N16 Nissan Sunny suddenly has the light on. Friday still ok. Yesterday never use car. can start, but canned accelerate at all. even when stationary, cannot increase rpm at all. car can move slowly. last serviced in December 2020 at agent. any idea what is wrong? Simplest is try to do a “reset” by unplugging battery connectivity and wait a while before connecting back, or other methods specific to Nissan vehicles. If CEL is still on and still encounter same problems, call for tow truck and send to agent/workshop. 1 Link to post Share on other sites More sharing options...
Count-Bracula Twincharged March 29, 2021 Share March 29, 2021 14 hours ago, Evo5sg said: Hi, my 15 year N16 Nissan Sunny suddenly has the light on. Friday still ok. Yesterday never use car. can start, but canned accelerate at all. even when stationary, cannot increase rpm at all. car can move slowly. last serviced in December 2020 at agent. any idea what is wrong? I encountered before and had to tow my Sunny to WS. Faulty throttle something, cannot remember. WS had to source from scrape yard a replacement but the 2nd hand part conked out within a week. WS replaced it again, this time FOC but after a long wait as part was hard to come by. In the end, we decided to ditch our 11 yo Nissan Sunny ...... sad lor. 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 29, 2021 Share March 29, 2021 10 hours ago, Hamburger said: Newer obd II sends out code and also a brief analysis. That's not what I'm trying to say. I give an example that is not related to TS issue. Sometimes a loose vacuum hose or a loose connection may trigger several fault codes. It might not be a part's problem, or sensor problem. Not every car part has a sensor attached to it so this is what I meant by not as straightforward as what the fault codes tells you. Not that easy lah. Otherwise your mechanic jiak sai already. 3 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic March 29, 2021 Share March 29, 2021 7 minutes ago, Count-Bracula said: I encountered before and had to tow my Sunny to WS. Faulty throttle something, cannot remember. WS had to source from scrape yard a replacement but the 2nd hand part conked out within a week. WS replaced it again, this time FOC but after a long wait as part was hard to come by. In the end, we decided to ditch our 11 yo Nissan Sunny ...... sad lor. I dunno whether the Sunny(which year which model) throttle body is the electronic controlled or the cable controlled. For cable usually the wire cable has stretched over time, that can be easily rectified. For the electronic controlled is replacing the sensor attached to the throttle body. Now all the new cars are electronically controlled. Link to post Share on other sites More sharing options...
Count-Bracula Twincharged March 29, 2021 Share March 29, 2021 4 minutes ago, Watwheels said: I dunno whether the Sunny(which year which model) throttle body is the electronic controlled or the cable controlled. For cable usually the wire cable has stretched over time, that can be easily rectified. For the electronic controlled is replacing the sensor attached to the throttle body. Now all the new cars are electronically controlled. I think it is electronic. Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 29, 2021 Share March 29, 2021 15 hours ago, Evo5sg said: Hi, my 15 year N16 Nissan Sunny suddenly has the light on. Friday still ok. Yesterday never use car. can start, but canned accelerate at all. even when stationary, cannot increase rpm at all. car can move slowly. last serviced in December 2020 at agent. any idea what is wrong? with all your descriptions above. . . . Agent fault lor. Want you to change car. hahahahha. 1 Link to post Share on other sites More sharing options...
Picnic06-Biante15 Supersonic March 29, 2021 Share March 29, 2021 Believe its the fuel injection pump that is causing the trouble..... TS tried to accelerate but vehicle not moving 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged March 29, 2021 Share March 29, 2021 54 minutes ago, Picnic06-Biante15 said: Believe its the fuel injection pump that is causing the trouble..... TS tried to accelerate but vehicle not moving not necessarily. cannot accelerate is limp home mode. everything is cut back. can be coils, throttle body. unlikely fuel pump as my experience with fuel pumps so far, is they are either working or not. 2 Link to post Share on other sites More sharing options...
UncleAtas Turbocharged March 29, 2021 Share March 29, 2021 Clogged? Link to post Share on other sites More sharing options...
Evo5sg 2nd Gear March 29, 2021 Author Share March 29, 2021 Thanks for the replies. Just go diagnosed. Accelerator assembly need to replace. ↡ Advertisement 4 Link to post Share on other sites More sharing options...
