Bluepica 4th Gear August 27, 2021 Share August 27, 2021 Hi, I have to change the floor mat at the driver side quite often due to the breakage where my right heel keep resting all the time while stepping on the accelerator n brakes . the rubber under the mat and even the second layer mat under the first one also got one “hole”. anyone facing the same problem and any solution ? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
macrosszero Turbocharged August 27, 2021 Share August 27, 2021 Driver floor mat heel pad 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic August 27, 2021 Share August 27, 2021 Change your high-heel shoes to rubber sole shoes lo. 3 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 27, 2021 Share August 27, 2021 Many options, change floor mat, change shoe, change car. 1 8 Link to post Share on other sites More sharing options...
Inlinefour Twincharged August 27, 2021 Share August 27, 2021 Barefoot driving 🤣🤣🤣 Link to post Share on other sites More sharing options...
Fitvip Supersonic August 27, 2021 Share August 27, 2021 My set of floor mats already 13 years,still swee swee! You must have been using your heel to dig in! Use the front of the sole instead. 1 Link to post Share on other sites More sharing options...
Gnahp Supercharged August 27, 2021 Share August 27, 2021 @Fitvip same here I find factory mats are the most durable the set on my car are 9.5 years 280,000km now still swee swee at the driver right heel area 5 Link to post Share on other sites More sharing options...
Ct3833 Supersonic August 27, 2021 Share August 27, 2021 (edited) 23 minutes ago, Phang said: @Fitvip same here I find factory mats are the most durable the set on my car are 9.5 years 280,000km now still swee swee at the driver right heel area The wear of 280000km is on the tyres lah, not the mat. Not I say one🤣🤣🤣 My previous car mat also lasted for 10 years of 240k km. Recently just bought the 3d mat, let's see how long it will last Edited August 27, 2021 by Ct3833 1 2 Link to post Share on other sites More sharing options...
RadX Moderator August 27, 2021 Share August 27, 2021 2 hours ago, Macrosszero said: Driver floor mat heel pad Double heel pad! They can customize for u one Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 27, 2021 Share August 27, 2021 Stick 1 pc of thin Aluminum Plate on top. 2 Link to post Share on other sites More sharing options...
zipping Supersonic August 27, 2021 Share August 27, 2021 If ur heels can go thru these....... 8 Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 27, 2021 Share August 27, 2021 I saw one used car use the big one on passenger side and the smaller on driver side Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator August 28, 2021 Share August 28, 2021 Can just change the driver side. not an issue. Link to post Share on other sites More sharing options...
Freeder Hypersonic August 28, 2021 Share August 28, 2021 (edited) Just change the car .. MCF motto,.. Edited August 28, 2021 by Freeder 1 5 Link to post Share on other sites More sharing options...
Wormee 5th Gear August 28, 2021 Share August 28, 2021 Right heel resting on the floor mat while stepping on the accelerator is alright. But many of us did the wrong thing by just shifting our toes to step on brakes while still resting the heel. The correct way to brake is to lift up your lazy right foot and step on the brakes without having your heel to touch the floor mat. Take a min to recall, this should be the way we are taught in driving school. It would reduce the wear and tear as the shifting of toes while resting the heel action (left and right rubbing of the floor mat) is lesser. Nonetheless, can alway get a good set of floor mat. Those customised one usually comes with stronger heel plate. Cheers. 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 28, 2021 Share August 28, 2021 1 hour ago, Wormee said: The correct way to brake is to lift up your lazy right foot and step on the brakes without having your heel to touch the floor mat. What is the benefit of braking this way besides not "wearing out" your floor mats? When I am pressing the brake as the car is front is becoming bigger and bigger wear and tear of the floor mat is the least of my worries. Link to post Share on other sites More sharing options...
Jamesc Hypersonic August 28, 2021 Share August 28, 2021 I have driven many cars and I have never worn out any floor mats. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged August 28, 2021 Share August 28, 2021 4 hours ago, Wormee said: The correct way to brake is to lift up your lazy right foot and step on the brakes without having your heel to touch the floor mat. IMHO For hard braking i think that's the way.. most time we just reduce speed gradually.. but of cos depends on the way you drive lah.. ↡ Advertisement Link to post Share on other sites More sharing options...
Where to get MCF dash mat?
Mat for the boot
Mat for the boot
Where to buy front seat back protective mat?
