Lala81
Urgent - battery or other problem?
Hypersonic (edited)
Eh guys. Stuck at yishun Central carpark.
Is this a starter problem?
Not a battery problem right?
Edited by Lala81
Share this post
Supersonic
Most likely it's the battery. Any voltage reader like those plug into ciggy lighter port?
Share this post
Hypersonic (edited)
My battery died on me few times. Not like this leh.
Nevermind. I call those car towing services. Think something faulty with the starter. Probably just need to be jump started.
Haha noob at this.
Edited by Lala81
Share this post
Supercharged
Is this a starter problem? But my sparkplug are less than 30k old only.
Get someone to jump start your car and try.
Could happen when CCA is really too low even to trigger the starter to crank
Share this post
Twincharged (edited)
Likely battery.
Starter it won't has response at all.
Edited by Kopites
Share this post
Hypersonic
Somehow car managed to start up like one out of hundred attempts. Driving to workshop
  • Praise 5
Share this post
Actually, looks like battery conk out to me. Had that before, no warning, one fine day dashboard lights flicker when starting the car, couldnt start,  when try to restart again, dashboard lights went dead.
  • Praise 3
Share this post
Supersonic
I occasionally check battery health with this type...not 100% accurate but you know it's an early warning if it falls to below 12 before crank.
  • Praise 2
Share this post
Supersonic (edited)
Battery most likely has drop below the 12V.
After jump start you have to keep the engine running until you reach the battery shop.
Do you keep your camera running on the car battery? Stop doing that.
Edited by Watwheels
  • Praise 3
Share this post
Twincharged
Good enough.  Hey but 13.7v ? Your engine was running idel when taking this reading ?
Share this post
Supersonic
Yup. After 4 days of wasted coe ...13.7 not bad liao 😅
12.2 without crank
Share this post
12.2 without crank
Ah so I guess was correct, idle 12.2v is still good for a few days of resting.
@Lala81's problem is likely starter, it spins but the gear did not engage the flywheel.
Edited by Ct3833
Share this post
Hypersonic
OK lah probably battery. But car also need to service so shun bian lol.
  • Haha! 1
Share this post
Hypersonic
Yes that happened before to me. But this one haha u can still run radio and ac fan etc.
Anyway probably battery lah. Just dropped off car at workshop. Shun bian do servicing
Share this post
Supersonic
should be battery. see the light flashing.
if u hear tac tac tac tac tac , sound.90% is battery issue, weak bat, or the connector loose.
starter sound, u press the button, either no sound, or u hear 1 tac only and no more respond.
  • Praise 4
Share this post
Twincharged
Good luck.
Share this post
Supercharged
Most probably battery issue.
Discounting low fuel.
I experienced similar.
  • Praise 2
Share this post
Supersonic
Yeah sounds like battery bo lak. Nothing serious.
  • Praise 3
Share this post
