Lala81 Hypersonic November 12, 2021 Share November 12, 2021 (edited) Eh guys. Stuck at yishun Central carpark. Is this a starter problem? Not a battery problem right? Edited November 12, 2021 by Lala81 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
mersaylee Supersonic November 12, 2021 Share November 12, 2021 Most likely it's the battery. Any voltage reader like those plug into ciggy lighter port? Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2021 Author Share November 12, 2021 (edited) My battery died on me few times. Not like this leh. Nevermind. I call those car towing services. Think something faulty with the starter. Probably just need to be jump started. Haha noob at this. Edited November 12, 2021 by Lala81 Link to post Share on other sites More sharing options...
t0y0ta Supercharged November 12, 2021 Share November 12, 2021 7 minutes ago, Lala81 said: Eh guys. Stuck at yishun Central carpark. Is this a starter problem? But my sparkplug are less than 30k old only. Not a battery problem right? Get someone to jump start your car and try. Could happen when CCA is really too low even to trigger the starter to crank 1 Link to post Share on other sites More sharing options...
Kopites Supersonic November 12, 2021 Share November 12, 2021 (edited) Likely battery. Starter it won't has response at all. Edited November 12, 2021 by Kopites 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2021 Author Share November 12, 2021 Somehow car managed to start up like one out of hundred attempts. Driving to workshop 5 Link to post Share on other sites More sharing options...
Jtis 4th Gear November 12, 2021 Share November 12, 2021 Actually, looks like battery conk out to me. Had that before, no warning, one fine day dashboard lights flicker when starting the car, couldnt start, when try to restart again, dashboard lights went dead. 3 Link to post Share on other sites More sharing options...
mersaylee Supersonic November 12, 2021 Share November 12, 2021 I occasionally check battery health with this type...not 100% accurate but you know it's an early warning if it falls to below 12 before crank. 2 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 12, 2021 Share November 12, 2021 (edited) Battery most likely has drop below the 12V. After jump start you have to keep the engine running until you reach the battery shop. Do you keep your camera running on the car battery? Stop doing that. Edited November 12, 2021 by Watwheels 3 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2021 Share November 12, 2021 2 minutes ago, mersaylee said: I occasionally check battery health with this type...not 100% accurate but you know it's an early warning if it falls to below 12 before crank. Good enough. Hey but 13.7v ? Your engine was running idel when taking this reading ? Link to post Share on other sites More sharing options...
mersaylee Supersonic November 12, 2021 Share November 12, 2021 Just now, Ct3833 said: Good enough. Hey but 13.7v ? Your engine was running idel when taking this reading ? Yup. After 4 days of wasted coe ...13.7 not bad liao 😅 12.2 without crank 1 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2021 Share November 12, 2021 (edited) 3 minutes ago, mersaylee said: Yup. After 4 days of wasted coe ...13.7 not bad liao 😅 12.2 without crank Ah so I guess was correct, idle 12.2v is still good for a few days of resting. @Lala81's problem is likely starter, it spins but the gear did not engage the flywheel. Edited November 12, 2021 by Ct3833 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2021 Author Share November 12, 2021 OK lah probably battery. But car also need to service so shun bian lol. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2021 Author Share November 12, 2021 25 minutes ago, Jtis said: Actually, looks like battery conk out to me. Had that before, no warning, one fine day dashboard lights flicker when starting the car, couldnt start, when try to restart again, dashboard lights went dead. Yes that happened before to me. But this one haha u can still run radio and ac fan etc. Anyway probably battery lah. Just dropped off car at workshop. Shun bian do servicing. Link to post Share on other sites More sharing options...
Beregond Supersonic November 12, 2021 Share November 12, 2021 should be battery. see the light flashing. if u hear tac tac tac tac tac , sound.90% is battery issue, weak bat, or the connector loose. starter sound, u press the button, either no sound, or u hear 1 tac only and no more respond. 4 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2021 Share November 12, 2021 4 minutes ago, Lala81 said: Yes that happened before to me. But this one haha u can still run radio and ac fan etc. Anyway probably battery lah. Just dropped off car at workshop. Shun bian do servicing. Good luck. Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged November 12, 2021 Share November 12, 2021 1 hour ago, Lala81 said: Eh guys. Stuck at yishun Central carpark. Is this a starter problem? Not a battery problem right? Most probably battery issue. Discounting low fuel. I experienced similar. 2 Link to post Share on other sites More sharing options...
Volvobrick Supersonic November 12, 2021 Share November 12, 2021 Yeah sounds like battery bo lak. Nothing serious. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
A Snowstorm Trapped 50 People in a Remote Pub With an Oasis Tribute Band for 3 Days
Tesla app also got outage, owners can't start car
Well done Traffic Police Officers & passerbys for helping car driver to push stalled car from junction!
Video: Malaysia Racism Experiment 2.0 – Car Breakdown
5 Cars That Wont Last 100,000 Miles
Hong Kong MTR 6 Hours Breakdown
Rear seat belt stuck
