Kopites Supersonic November 12, 2021 Share November 12, 2021 (edited) 17 minutes ago, DOBIEMKZ said: Most probably battery issue. Discounting low fuel. I experienced similar. There is one more. Gear in "d". Someone here ever did that and posted for help . 🤣 Edited November 12, 2021 by Kopites ↡ Advertisement 1 5 Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2021 Share November 12, 2021 Just now, Kopites said: There is one more. Gear in "d". Someone here ever did that. 🤣 Let me guess @Jamesc's MIL.🤣🤣 3 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 12, 2021 Share November 12, 2021 I experience it before too. but mine is fuel pump. hahahaha. 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged November 12, 2021 Share November 12, 2021 Step 1 : Get someone near you and try to connect battery to start again (I always have a pair of cable in the boot for this purpose, regardless if I use it or someone need it) Step 2 : If cannot, probably starter liao. Then you call tow truck😂 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic November 12, 2021 Share November 12, 2021 51 minutes ago, Ct3833 said: Good enough. Hey but 13.7v ? Your engine was running idel when taking this reading ? 13.7V is when headlights are on. I notice that on my car too. My charger has a voltage indicator too. During daytime the voltage is around 12.7V. When charging it is around 14.4V . When deceleration the voltage will jump to above 14V as well. At first I didnt know the alternator can do this. Then I saw it on my charger. But my car isnt mild hybrid or hybrid. 1 Link to post Share on other sites More sharing options...
Arogab Turbocharged November 12, 2021 Share November 12, 2021 9 minutes ago, kobayashiGT said: I experience it before too. but mine is fuel pump. hahahaha. This highest probability is not fuel pump. If pump issue, you will hear the car crank up and then die off lah 4 Link to post Share on other sites More sharing options...
Contipro 5th Gear November 12, 2021 Share November 12, 2021 53 minutes ago, Lala81 said: Yes that happened before to me. But this one haha u can still run radio and ac fan etc. Anyway probably battery lah. Just dropped off car at workshop. Shun bian do servicing. sir. so finally workshop check is battery problem ? Link to post Share on other sites More sharing options...
Mkl22 Twincharged November 12, 2021 Share November 12, 2021 (edited) 1 hour ago, mersaylee said: Yup. After 4 days of wasted coe ...13.7 not bad liao 😅 12.2 without crank you are measuring the alternator charging voltage. all it says is alternator is working. need to do battery load test or analyzer to check status of the battery. 12.2V seems ok after 4 days. Edited November 12, 2021 by Mkl22 1 Link to post Share on other sites More sharing options...
Mkl22 Twincharged November 12, 2021 Share November 12, 2021 (edited) 1 hour ago, Beregond said: should be battery. see the light flashing. if u hear tac tac tac tac tac , sound.90% is battery issue, weak bat, or the connector loose. starter sound, u press the button, either no sound, or u hear 1 tac only and no more respond. i would say 100% battery as the lights all go off when he cranks. anyway lead acid batteries are meant for high discharge. connecting parking camera to it for recording can only kill it faster as it does not light slow slow discharge till low voltages. Edited November 12, 2021 by Mkl22 5 Link to post Share on other sites More sharing options...
mersaylee Supersonic November 12, 2021 Share November 12, 2021 6 minutes ago, Mkl22 said: you are measuring the alternator charging voltage. all it says is alternator is working. need to do battery load test or analyser tocheck status of the battery Certainly…If liddat also cannot start means need to start calling for help liao 😅 Link to post Share on other sites More sharing options...
Beregond Supersonic November 12, 2021 Share November 12, 2021 42 minutes ago, Kopites said: There is one more. Gear in "d". Someone here ever did that and posted for help . 🤣 actually this is a common mistake. not left in D , but in 'R' . the level never engage fully into 'P' mode its at the "P' position but the mechanism is in 'R" the symptom is totally no respond when u crank, but there is light on the dashboard ( or there is power ) 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator November 12, 2021 Share November 12, 2021 38 minutes ago, Arogab said: This highest probability is not fuel pump. If pump issue, you will hear the car crank up and then die off lah I mean speaking of my past experience, what i kenna is not starter or battery. haha, is fuel pump. 🤣 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 12, 2021 Share November 12, 2021 Read this thread too late. I could have come to Lala rescue with my all powerful 400A battrry jump starter. Although it failed on the 1.5L, it might start a 2.4.🤣 6 Link to post Share on other sites More sharing options...
Kopites Supersonic November 12, 2021 Share November 12, 2021 1 hour ago, Hamburger said: Read this thread too late. I could have come to Lala rescue with my all powerful 400A battrry jump starter. Although it failed on the 1.5L, it might start a 2.4.🤣 Those suitcase type? Link to post Share on other sites More sharing options...
Hamburger Hypersonic November 12, 2021 Share November 12, 2021 @Kopites ANKER power Bank type. Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 12, 2021 Share November 12, 2021 (edited) 2 hours ago, Hamburger said: Read this thread too late. I could have come to Lala rescue with my all powerful 400A battrry jump starter. Although it failed on the 1.5L, it might start a 2.4.🤣 You mean it fails to jump start your 1.5L car ? Edited November 12, 2021 by Ct3833 Link to post Share on other sites More sharing options...
Mkl22 Twincharged November 12, 2021 Share November 12, 2021 My take is, test the battery with a hand held tester every 3-4mths when the battery is more than 1year old. A 3min job. Change it when the reading is low. Don’t have to worry about carrying jumper cables, jump pack which can die on you when you need it the most, rely on AAS or other services where you need to wait and then pay sometimes exorbitant charges. Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 12, 2021 Author Share November 12, 2021 Battery problem. Just collected my car. Thanks guys. ↡ Advertisement 9 Link to post Share on other sites More sharing options...
A Snowstorm Trapped 50 People in a Remote Pub With an Oasis Tribute Band for 3 Days
Tesla app also got outage, owners can't start car
Well done Traffic Police Officers & passerbys for helping car driver to push stalled car from junction!
Video: Malaysia Racism Experiment 2.0 – Car Breakdown
5 Cars That Wont Last 100,000 Miles
Hong Kong MTR 6 Hours Breakdown
Rear seat belt stuck
