Atonchia Supersonic January 14, 2022 Share January 14, 2022 15 hours ago, Victor68 said: Actually what can the pilot do if system is totally down? I was told with the drone technology already proven, future will be all by remote. Usually it's one or two emergencies is enough to cause serious problem. But if total power failure then suck thumb already. Because all are fly by wire now. Meaning of no power, then actuators will not work, radar will not work, Comms and PA system will not work, screen / sat nav will not work, flight controls will not works because all flight surface requires motors like power steering in cars. If one engine flame out or on fire. Still safer than total power failure and can land at nearest alternate airfield. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic January 14, 2022 Share January 14, 2022 5 hours ago, Atonchia said: Usually it's one or two emergencies is enough to cause serious problem. But if total power failure then suck thumb already. Because all are fly by wire now. Meaning of no power, then actuators will not work, radar will not work, Comms and PA system will not work, screen / sat nav will not work, flight controls will not works because all flight surface requires motors like power steering in cars. If one engine flame out or on fire. Still safer than total power failure and can land at nearest alternate airfield. Airplane has a tiny rotary turbine to generate electricity just in case both engine flame out. 2 Link to post Share on other sites More sharing options...
Atonchia Supersonic January 14, 2022 Share January 14, 2022 59 minutes ago, inlinesix said: Airplane has a tiny rotary turbine to generate electricity just in case both engine flame out. Total electrical or power failure meant the back up generator also failed. So meant totally no wattage.😱😱😱 1 Link to post Share on other sites More sharing options...
inlinesix Supersonic January 15, 2022 Share January 15, 2022 (edited) 1 hour ago, Atonchia said: Total electrical or power failure meant the back up generator also failed. So meant totally no wattage.😱😱😱 It will not happens as there is a backup turbine to generate electricity Edited January 15, 2022 by inlinesix 2 Link to post Share on other sites More sharing options...
Karoon Turbocharged January 15, 2022 Share January 15, 2022 20 hours ago, Inlinefour said: My co pilot 😍😍😍 You like runway 2 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 15, 2022 Share January 15, 2022 6 minutes ago, Karoon said: You like runway I love sunny side up ❤️❤️❤️ 1 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged January 15, 2022 Share January 15, 2022 55 minutes ago, inlinesix said: It will not happens as there is a backup turbine to generate electricity APU.. Auxiliary Power Unit 2 Link to post Share on other sites More sharing options...
Atonchia Supersonic January 15, 2022 Share January 15, 2022 4 hours ago, Ody_2004 said: APU.. Auxiliary Power Unit APU is use on ground? For starting Aircraft engine? Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 15, 2022 Share January 15, 2022 4 minutes ago, Atonchia said: APU is use on ground? For starting Aircraft engine? When the plane loses all its engines there is no power for all the electrical items. So a little propeller pops out of the belly and the wind will turn it making electricity like a bicycle dynamo. 2 4 Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged January 15, 2022 Share January 15, 2022 1 hour ago, Jamesc said: When the plane loses all its engines there is no power for all the electrical items. So a little propeller pops out of the belly and the wind will turn it making electricity like a bicycle dynamo. wah! I thought Bro @Jamesc only specialized in MIL din know he can be LAME too! whahahahahha.. LAME is Licensed Aircraft Maintenance Engineer hoh! 5 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 15, 2022 Share January 15, 2022 4 minutes ago, Ody_2004 said: wah! I thought Bro @Jamesc only specialized in MIL din know he can be LAME too! whahahahahha.. LAME is Licensed Aircraft Maintenance Engineer hoh! I always play aeroplane one. 4 Link to post Share on other sites More sharing options...
Atonchia Supersonic January 15, 2022 Share January 15, 2022 2 hours ago, Jamesc said: I always play aeroplane one. Must use the master hand. The plane glide path will be very smooth right? Sometimes with a bit more force, the plane can roll over the top. 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2022 Share January 17, 2022 Yes yes I am actually a LAME. Licenced Asian Massage Expert. On 1/15/2022 at 3:08 PM, Ody_2004 said: wah! I thought Bro @Jamesc only specialized in MIL din know he can be LAME too! whahahahahha.. LAME is Licensed Aircraft Maintenance Engineer hoh! 2 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 17, 2022 Author Share January 17, 2022 57 minutes ago, Jamesc said: Yes yes I am actually a LAME. Licenced Asian Massage Expert. So you got some nice tricks up in your sleeves!?😁😁😁 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2022 Share January 17, 2022 (edited) But I don't wear any sleeves. I don't wear any clothes at all when I am working. You heard of the naked chef? I am the naked masseuse. And no tricks at all. What they see is what they get. I have a policy of total transparency. 58 minutes ago, DOBIEMKZ said: So you got some nice tricks up in your sleeves!?😁😁😁 Edited January 17, 2022 by Jamesc 1 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 17, 2022 Author Share January 17, 2022 9 minutes ago, Jamesc said: But I don't wear any sleeves. I don't wear any clothes at all when I am working. You heard of the naked chef? I am the naked masseuse. And no tricks at all. What they see is what they get. I have a policy of total transparency. Sometimes too much transparency can be off-putting leh! 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 17, 2022 Share January 17, 2022 (edited) My customers insist on it! How can I say no? 9 minutes ago, DOBIEMKZ said: Sometimes too much transparency can be off-putting leh! Edited January 17, 2022 by Jamesc 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 17, 2022 Author Share January 17, 2022 5 minutes ago, Jamesc said: My customers insist on it! ↡ Advertisement Link to post Share on other sites More sharing options...
Car decals of rsaf n airplanes
