Vratenza Supersonic May 30, 2022 Share May 30, 2022 I have an issue with my exterior black plastic trim being stained by the front bonnet hinge grease (I suspect) that trickled down the side with the rainor car wash water. Overtime it formed this whitish unsightly stain that cannot be washed off using normal car shampoo. So I decided to try the Armorall Multigpurpose cleaner which removed about 90% of the problem.. But still qhite visible. Before: After: Before: After: Anyone have a better product(s) to recommend that can clean and protect the trim thoroughly? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
mersaylee Supersonic May 30, 2022 Share May 30, 2022 5 minutes ago, Vratenza said: I have an issue with my exterior black plastic trim being stained by the front bonnet hinge grease (I suspect) that trickled down the side with the rainor car wash water. Overtime it formed this whitish unsightly stain that cannot be washed off using normal car shampoo. So I decided to try the Armorall Multigpurpose cleaner which removed about 90% of the problem.. But still qhite visible. Before: After: Before: After: Anyone have a better product(s) to recommend that can clean and protect the trim thoroughly? Spray paint for permanent solution. Good sanding to prep for painting is very important though. Link to post Share on other sites More sharing options...
Vratenza Supersonic May 30, 2022 Author Share May 30, 2022 9 minutes ago, mersaylee said: Spray paint for permanent solution. Good sanding to prep for painting is very important though. I have read up about it more online and apparently it is a common problem for mini due to the design of the bonnet allowing some of the grease (cosmolene?) to drip down the fenders. If I cannot find a simple solution to solve it myself, will just book in an appointment with the AD to let them give me a solution (since mine is still under warranty) 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic May 30, 2022 Share May 30, 2022 Why not try it with shoe polish. Get a cassette of Kiwi shoe black and brush on the plastic trim. It may not be permanent, but at least it gets a uniform black colour. 1 1 Link to post Share on other sites More sharing options...
Etnt Turbocharged May 30, 2022 Share May 30, 2022 would think duragloss would have something in it's large arsenal to tackle exterior trims. @Maddriveranything in your toolbox? Link to post Share on other sites More sharing options...
Maddriver 4th Gear May 30, 2022 Share May 30, 2022 @Etnt Yes sir.. something like this.. Link to post Share on other sites More sharing options...
Vratenza Supersonic May 30, 2022 Author Share May 30, 2022 1 hour ago, Maddriver said: @Etnt Yes sir.. something like this.. Great! Will try this! Link to post Share on other sites More sharing options...
Macrosszero Turbocharged May 30, 2022 Share May 30, 2022 Acetone is an option but use it very sparingly and only as much as is needed to get rid of the marks. Google and follow the instructions, otherwise it could be worse than it is now. Link to post Share on other sites More sharing options...
mersaylee Supersonic May 30, 2022 Share May 30, 2022 6 hours ago, Maddriver said: @Etnt Yes sir.. something like this.. Not sure why... so give you a 👍 here 😁 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator May 31, 2022 Share May 31, 2022 22 hours ago, Vratenza said: I have an issue with my exterior black plastic trim being stained by the front bonnet hinge grease (I suspect) that trickled down the side with the rainor car wash water. Overtime it formed this whitish unsightly stain that cannot be washed off using normal car shampoo. So I decided to try the Armorall Multigpurpose cleaner which removed about 90% of the problem.. But still qhite visible. Before: After: Before: After: Anyone have a better product(s) to recommend that can clean and protect the trim thoroughly? If this is pure plastic, you can just kiwi it. No need fancy item one. You kiwi black black looks nice can le. Kiwi is not permanent also, will wear off and need to reapply. Just take a small amout of kiwi and try on a small area first then you like the effect you can venture to the whole panel. If there is paint on the trim, then you need to buff and polish. Cuz got laquer mah. no choice. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator May 31, 2022 Share May 31, 2022 22 hours ago, Fitvip said: Why not try it with shoe polish. Get a cassette of Kiwi shoe black and brush on the plastic trim. It may not be permanent, but at least it gets a uniform black colour. hahaha. great mind think alike! 2 Link to post Share on other sites More sharing options...
Fitvip Supersonic May 31, 2022 Share May 31, 2022 5 minutes ago, kobayashiGT said: hahaha. great mind think alike! When people bought tyre black, I applied kiwi black shoe polish to the tyres.👍 1 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 31, 2022 Author Share May 31, 2022 38 minutes ago, kobayashiGT said: If this is pure plastic, you can just kiwi it. No need fancy item one. You kiwi black black looks nice can le. Kiwi is not permanent also, will wear off and need to reapply. Just take a small amout of kiwi and try on a small area first then you like the effect you can venture to the whole panel. If there is paint on the trim, then you need to buff and polish. Cuz got laquer mah. no choice. I read that show polish on car black trim is just a dressing, ie. covering the problem up till it wears off and have to reapply again. I am also afraid of the kiwi black rubbing off my pants if i accidentally brush against those trim pieces. I might try it if my car is out of warranty and it does not make economical sense to change out the trim. Since my car is still well within warranty, I don't see why I have to live with permanently stained trim pieces when it is obviously a manufacturer/design issue.😅 2 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 31, 2022 Author Share May 31, 2022 41 minutes ago, Fitvip said: When people bought tyre black, I applied kiwi black shoe polish to the tyres.👍 hahaha, this, I'll try😁 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic May 31, 2022 Share May 31, 2022 6 minutes ago, Vratenza said: I read that show polish on car black trim is just a dressing, ie. covering the problem up till it wears off and have to reapply again. I am also afraid of the kiwi black rubbing off my pants if i accidentally brush against those trim pieces. I might try it if my car is out of warranty and it does not make economical sense to change out the trim. Since my car is still well within warranty, I don't see why I have to live with permanently stained trim pieces when it is obviously a manufacturer/design issue.😅 The kiwi black has to be brushed on to the trim thoroughly, not just applied. When it is properly brushed, it won't stain your pants when they come into contact with it. Btw, are you the miw?🤐 1 Link to post Share on other sites More sharing options...
RadX Moderator May 31, 2022 Share May 31, 2022 12 minutes ago, Vratenza said: I read that show polish on car black trim is just a dressing, ie. covering the problem up till it wears off and have to reapply again. I am also afraid of the kiwi black rubbing off my pants if i accidentally brush against those trim pieces. I might try it if my car is out of warranty and it does not make economical sense to change out the trim. Since my car is still well within warranty, I don't see why I have to live with permanently stained trim pieces when it is obviously a manufacturer/design issue.😅 normally u shd change car 5 Link to post Share on other sites More sharing options...
Vratenza Supersonic May 31, 2022 Author Share May 31, 2022 @Fitvip I don't own any white pants.....ever....😆 2 Link to post Share on other sites More sharing options...
RadX Moderator May 31, 2022 Share May 31, 2022 Just now, Vratenza said: @Fitvip I don't own any white pants.....ever....😆 eh dun bluff...i know ur school is white pants one ↡ Advertisement 2 Link to post Share on other sites More sharing options...
ItzJuzCarbon can customise any of your steering wheels, car parts, interior trims, side panels and accessories with Carbon Fiber!
Interior wrapping
Interior wrapping
Black flakes from washing machine
Automatic (robotic) vacuum cleaner
Iconic Tupperware warns it could go out of business
Black ants - How to get rid of them in the house?
DPF Cleaner
DPF Cleaner
