Confusedboi Supercharged September 8, 2022 Share September 8, 2022 9 hours ago, Mkl22 said: Is this your battery size? The box says CCA is 380A. Typically amaron has a slightly higher than rated CCA when brand new. But not 530A when rated at 380A. 45Ah batt with CCA 360-380A is normal. When it drops to approx 75% then time to change. so either his battery tester is spoilt or he also alibaba….. I think he show me the reading is from another battery size that is bigger than the one in my box. That would explain the higher CCA rating as an example. ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic September 8, 2022 Share September 8, 2022 9 hours ago, Mkl22 said: Is this your battery size? The box says CCA is 380A. Typically amaron has a slightly higher than rated CCA when brand new. But not 530A when rated at 380A. 45Ah batt with CCA 360-380A is normal. When it drops to approx 75% then time to change. so either his battery tester is spoilt or he also alibaba….. If the Amaron battery box is indeed the one that was changed, sound like the workshop put up a good show to sell the battery when the "old" battery is working perfectly fine. Many car workshops these days are hunting for higher revenue and they know existing car owners are more willing to spend to maintain the car since the COE is so high. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 8, 2022 Share September 8, 2022 5 minutes ago, Confusedboi said: I think he show me the reading is from another battery size that is bigger than the one in my box. That would explain the higher CCA rating as an example. important questions are: 1) what is your car's battery size required as stated in your manual. 2) with the size of your specified car battery, you should know the average CCA with a quick google search. 3) If the average CCA is 380A, there is really no good reason to change the battery. Link to post Share on other sites More sharing options...
13177 Supersonic September 8, 2022 Share September 8, 2022 4 minutes ago, Vratenza said: If the Amaron battery box is indeed the one that was changed, sound like the workshop put up a good show to sell the battery when the "old" battery is working perfectly fine. Many car workshops these days are hunting for higher revenue and they know existing car owners are more willing to spend to maintain the car since the COE is so high. Not sure about outside car workshops, but AD always like to ask owners to change this change that, do this do that even the car is still fairly new. Link to post Share on other sites More sharing options...
Vratenza Supersonic September 8, 2022 Share September 8, 2022 4 minutes ago, 13177 said: Not sure about outside car workshops, but AD always like to ask owners to change this change that, do this do that even the car is still fairly new. the golden question to ask the AD is : " is this covered under warranty or FOC service package?" That will give you a clue if it is really necessary. 4 Link to post Share on other sites More sharing options...
Mkl22 Twincharged September 8, 2022 Share September 8, 2022 18 minutes ago, 13177 said: Not sure about outside car workshops, but AD always like to ask owners to change this change that, do this do that even the car is still fairly new. ya. most notorious is C&C. my mitsubishi lancer asked to change brake pads when only about half worn. lucky i know how to check... else gong gong give the go ahead and just change 2 2 Link to post Share on other sites More sharing options...
Mustank Hypersonic September 8, 2022 Share September 8, 2022 15 hours ago, Confusedboi said: I just change battery for my beat up COE car today even though batt life left about 30% approximately after using batt for 1.5 years only 😓. Must give car “new” lease of life 😆, treat it like precious commodity for remaining 1 year 9months before must scrap 😭 Left 2 years very scary 1 Link to post Share on other sites More sharing options...
Confusedboi Supercharged September 8, 2022 Share September 8, 2022 34 minutes ago, Vratenza said: important questions are: 1) what is your car's battery size required as stated in your manual. 2) with the size of your specified car battery, you should know the average CCA with a quick google search. 3) If the average CCA is 380A, there is really no good reason to change the battery. I called guan lee up again and he say new battery size for my car should have much higher reading CCA than 380A. Normally 400 plus to 500 CCA. He clarify the new one tested showing 500+ CCA was indeed same battery size that was put into my car. Previously at my regular workshop about 2 months ago they did tell me my old battery was running low about 40% life with a couple months of life yet. That time I didn’t change. So now I just change the battery to be safe. Last year 1 March almost got stranded when alternator kaput plus battery went flat. Literally lost power right at Newton petrol station entrance with the Stamford tyre shop, managed to turn in to avoid blocking main road. The battery warning light turned on when I was near tan tock Seng hospital, surprised how fast it went flat.. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 8, 2022 Share September 8, 2022 4 minutes ago, Confusedboi said: I called guan lee up again and he say new battery size for my car should have much higher reading CCA than 380A. Normally 400 plus to 500 CCA. He clarify the new one tested showing 500+ CCA was indeed same battery size that was put into my car. Previously at my regular workshop about 2 months ago they did tell me my old battery was running low about 40% life with a couple months of life yet. That time I didn’t change. So now I just change the battery to be safe. Last year 1 March almost got stranded when alternator kaput plus battery went flat. Literally lost power right at Newton petrol station entrance with the Stamford tyre shop, managed to turn in to avoid blocking main road. The battery warning light turned on when I was near tan tock Seng hospital, surprised how fast it went flat.. I tend to rely on my own independent research for information especially when the other person is benefiting from the transaction. But of course, sometimes, peace of mind is not something money can measure. anyhow, just to share my experience so that everyone can learn and maybe next time save a couple of dollars. 👍 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 8, 2022 Share September 8, 2022 I always just change batteries after 2.5 years because COE is 10 years. Some people try to stretch to 3 years but when they scrap the battery is only 1 year old. A bit wasted. 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 8, 2022 Share September 8, 2022 (edited) Brake fluid I always change after 2 years. Except my MIL car. That one use until die. Edited September 8, 2022 by Jamesc 3 Link to post Share on other sites More sharing options...
13177 Supersonic September 8, 2022 Share September 8, 2022 1 hour ago, Vratenza said: the golden question to ask the AD is : " is this covered under warranty or FOC service package?" That will give you a clue if it is really necessary. I think all the things that they ask you to change, should not cover under warranty de. Lol. If covered or FOC, dont think they would ask you to change lo. 1 Link to post Share on other sites More sharing options...
Vratenza Supersonic September 8, 2022 Share September 8, 2022 11 minutes ago, 13177 said: I think all the things that they ask you to change, should not cover under warranty de. Lol. If covered or FOC, dont think they would ask you to change lo. Not really, like got once my battery was changed because of a factory recall, the SA called me to tell me that they are changing the battery FOC, just informing me. 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic September 8, 2022 Share September 8, 2022 (edited) 1 hour ago, Confusedboi said: I called guan lee up again and he say new battery size for my car should have much higher reading CCA than 380A. Normally 400 plus to 500 CCA. He clarify the new one tested showing 500+ CCA was indeed same battery size that was put into my car. Previously at my regular workshop about 2 months ago they did tell me my old battery was running low about 40% life with a couple months of life yet. That time I didn’t change. So now I just change the battery to be safe. Last year 1 March almost got stranded when alternator kaput plus battery went flat. Literally lost power right at Newton petrol station entrance with the Stamford tyre shop, managed to turn in to avoid blocking main road. The battery warning light turned on when I was near tan tock Seng hospital, surprised how fast it went flat.. No need confused boi. 🤣 He won’t cheat you la. He’s so honest that he wanted to charge me $8 for tyre repair because I’m regular but I gave him $10. I want him to stay in the business, I will be worried if he close down. Just a decent and honest one man show shop trying to make a living. Edited September 8, 2022 by Fcw75 6 Link to post Share on other sites More sharing options...
Eyke Supercharged September 8, 2022 Share September 8, 2022 1 hour ago, Jamesc said: Brake fluid I always change after 2 years. Except my MIL car. That one use until die. until who/what die? 😄 5 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 9, 2022 Share September 9, 2022 On 9/8/2022 at 11:46 AM, Eyke said: until who/what die? 😄 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 9, 2022 Share September 9, 2022 I really don't know why people complain about high COE. So many people are buying cars and have no problem with high COEs. Link to post Share on other sites More sharing options...
SLing 1st Gear September 9, 2022 Share September 9, 2022 https://carbuyer.com.sg/singapore-coe-analysis-september-2022-1st-round/ which is the rental company with the car park in central Singapore? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
COE Bidding - March 2024
Cars at Expo - Apr 2024
Xiaomi EV is Coming
Xiaomi EV is Coming
2024 COE trend..
2024 COE trend..
