BabyBlade Internal Moderator January 12, 2023 Share January 12, 2023 SINGAPORE – It is a delivery run for the history books, with the public getting its first look in Singapore at a van fitted with puncture-proof tyres as it made its way from the DHL Express office in Tai Seng Drive to Potong Pasir. Right from the get-go, onlookers’ eyes were drawn to the prototype tyres, which look visibly different from conventional ones. The tyres have sturdy rubbery strut-like structures to keep them propped up, instead of being filled with air. By the end of 2023, DHL Express will have around 50 vans fitted with such tyres as part of a trial by French tyre maker Michelin. The test will run until 2025, following smaller-scale tests under controlled conditions here, which The Straits Times reported on in December 2022. The tyres looked slightly compressed under the weight of the van but Michelin said this is how they usually look. The imprint at the edge of the tyres indicates that they can each bear a maximum load of 650kg. Besides Singapore, the puncture-proof tyre technology is also being tested in Thailand and the United States. Michelin said the puncture-proof tyres last as long as conventional tyres. It said it is also researching the use of 3D-printing technology to add new materials onto a worn tyre, extending its service life and reducing waste. The tyre company estimated that globally, 20 per cent of tyres on the road are taken out of service before they are fully worn because of flats, blowouts or irregular wear and tear when they are not pumped to the right amount of air pressure. Michelin said this means its puncture-proof tyres could save up to 200 million tyres annually from being prematurely scrapped. https://www.straitstimes.com/singapore/transport/first-van-with-puncture-proof-tyres-hits-the-road-in-singapore If you have trypophobia, don't click on the video. 😢 ↡ Advertisement 4 Link to post Share on other sites More sharing options...
Wildfaye29 Turbocharged January 12, 2023 Share January 12, 2023 Knn wtf sms is trypophobia 3 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 12, 2023 Share January 12, 2023 dun need use so deep words leh just phobia of mark lee face can liao 🤐🤐🤐 just kidding 🤣🤣🤣 BTW passenger car can trial bo looks good 👍 2 Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear January 12, 2023 Share January 12, 2023 Wonder over time, will these tyres able to stay in shape. 1 Link to post Share on other sites More sharing options...
Fitvip Supersonic January 12, 2023 Share January 12, 2023 After driving through mud, you will have the problem cleaning them. 1 Link to post Share on other sites More sharing options...
ER-3682 Twincharged January 12, 2023 Share January 12, 2023 Come with the Plastic Wheel.?Hmmmm....i wonder how much per Wheel/Tyre cost.?$300 each.? 1 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged January 12, 2023 Share January 12, 2023 Looks like uni direction wheels. Saw a video on YT last year. Glad it is rolled out rather than some concept idea that will never come to fruitation. 2 Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic January 12, 2023 Share January 12, 2023 Is it comfy? Link to post Share on other sites More sharing options...
BanCoe Hypersonic January 13, 2023 Share January 13, 2023 (edited) I remember seeing them on rental bikes ….. must be maintainence free likely…. If it takes off in a big way …and costs brought down ….. Will be good …… another thing is the fuel consumption of course and safety and wet weather ….. Edited January 13, 2023 by BanCoe Link to post Share on other sites More sharing options...
Watwheels Supersonic January 13, 2023 Share January 13, 2023 (edited) Omg, are these adhesive beads? LoL So the tires have to come with the steel or ally rims? Like that it is not going to be cheap. It obviously cannot fit into our existing alloy rims. Cos if you see how tire dealers fit your rubber tire onto the rim it is by air expansion and circumference of the rim act as a stopper for the rubber tires to fit snugly w/o any air leaks. It is not going to fit onto your fancy alloy rims. These couldnt expand. So it has to come glued with the rim. Yucks! Good luck using them. It looks like a 3-piece assembly. The outer diameter containing the tire threads...glued to the ribs...glued to the rim. LoL Edited January 13, 2023 by Watwheels 2 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 13, 2023 Share January 13, 2023 puncture-proof tyres could save up to 200 million tyres annually from being prematurely scrapped. Save the earth and no need to check air pressure at the service station. Save time Link to post Share on other sites More sharing options...
Volvobrick Supersonic January 13, 2023 Share January 13, 2023 The invention has been around for many years. I wonder why never took off. Maybe expensive, poor fuel economy/longevity etc. One obvious shortcoming is not able to adjust the air pressure to cater to heavier or lighter loads. And it is not aerodynamic too. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 13, 2023 Share January 13, 2023 They made airless tyres for bicycles years ago 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 13, 2023 Share January 13, 2023 No rim even more comfortable Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 13, 2023 Share January 13, 2023 The wheel was invented 7,000 years ago. They put a man on the moon in 1969. The most important thing I never leave home without to go on holiday was only invented in 1974. Mankind is not as smart as they like to think. Link to post Share on other sites More sharing options...
Jamesc Hypersonic January 13, 2023 Share January 13, 2023 So poor Neil Armstrong went all the way to the moon came back to Earth and when he went home he had to carry his luggage all the way home because he couldn't wheel it alone as the suitcase with wheels would not be invented for another 5 years! Link to post Share on other sites More sharing options...
BabyBlade Internal Moderator January 13, 2023 Author Share January 13, 2023 11 hours ago, Wildfaye29 said: Knn wtf sms is trypophobia Spoiler wahlau why you purposely screenshot this! 😡 1 Link to post Share on other sites More sharing options...
Beregond Supersonic January 13, 2023 Share January 13, 2023 I think this is more for low speed and rougher use. This design generate way more heat then normal tyres, and it got more contact surface. Plus i dun know how they going to do the balancing?? ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Pilot Sport 5 Improves On The Best Tire In The World
