AISIN car care is now available on Sgcarmart e-Shop!
e-Shop
Looking for new Car Grooming Products to keep your ride clean and protected?
AISIN's lineup of car care products allows you to keep your vehicle's exterior and interior clean.
Formulated to remove scratches, blemishes, and swirls from the surface, they help owners maintain their vehicles optimally while offering long-lasting protection.
AISIN Bug and Tar Remover
Formulated as a water-based and solvent-free solid formula. Effective removal of tar, asphalt, adhesives, bugs, smudges, heavy oil, and bird droppings is said to be safe for use on all exterior surfaces.
AISIN Wash and Wax
Solvent-free formula for scratch-free cleaning with soft and smooth bubbles. It contains water-soluble wax for an enhanced brightness and shine after use while being gentle on your vehicle sealant and coatings.
AISIN Car Wax
Deliver a hydrophobic effect and your vehicle surface will repel water, dirt, dust, and other significant contaminants, and leaves a brilliant high gloss look and smooth surface.
AISIN Tyre and Trim Coating
Long-lasting, water-resistant coating on surfaces with a deep black look.
Protects tyres from fading and cracking against UV rays and other contaminants.
AISIN Interior Cleaner
Effectively removes grease, oil, wrinkles, dirt, marks, coffee, makeup stains, and more!
Suitable for vinyl, leather, fibreglass, carpet, fabric seats, and plastic parts, except suede (Alcantara).
AISIN Leather Conditioner
Restore the natural shine and softness of leather surfaces.
It prevents surface deterioration and cracking, protects surfaces from damaging UV rays, and is safe for human skin and surfaces.
Enjoy $9 OFF with every $40 spent on the e-Shop with the promo code, "AISIN9OFF". AISIN's range of car care products can be purchased from Sgcarmart e-Shop HERE.
@ER-3682  You are right! It is the AISIN brand that supplies transmission and compenents for both OE and aftermarket.
Give their range of car grooming products a try.
Purchase with the promo code, "AISIN9OFF"  on Sgcarmart e-Shop.
September Steals! Save $9 on AISIN Products 🎉
Get your car looking and feeling its BEST 💖 with AISIN car care products!
This September, enjoy $9 OFF on AISIN products with a minimum $40 purchase—just use promo code 🏷️ AISIN9OFF at checkout.
Whether it’s interior or exterior care, AISIN has you covered. 🤗 Suitable for all vehicles, AISIN products ensure your car stays in top condition with long-lasting protection! 🤩
Don’t miss out on this exclusive promo. 🛒 Shop now at Sgcarmart e-Shop!
SHOP NOW
@BanCoe Hi 😊 We’re a GST-registered company, so a 9% GST is applied at checkout. We appreciate your understanding and are here if you have any further questions! 🙏
EXTERIOR CLEANING - AISIN WASH AND WAX
Specially developed to be Strong Solvent free formula for scratch-free cleaning with effectively soft and smooth bubbles. It contains Water Soluble Wax which provides enhanced brightness and shine after use. Moreover, it's safe for all paint finishes and gentle on sealant & wax coatings, easily to washed off and does not cause rust.
Suitable For
All colour of vehicles
Unique Selling Points
  1. Clean & Protect in one step (2 in 1)
  2. Special water soluble wax
  3. Saving quantity
  4. No leaving stains or caused any rust
  5. Smooth polishing with high-quality of bubble
  6. High durable, density and stabilize of bubble
  7. Safe for all paint finishes and gentle on sealant & wax coatings
  8. Excellent high gross and smooth surface
Direction of Use
  1. Cleaning the surface with clean water
  2. Mix AISIN WASH & WAX with Water at 1:80 ratio
  3. Frothing a foam to reduce friction and wrinkles while cleaning
  4. Cleaning by one side at a time
  5. Rinse off with clean water and dry with clean and soft cloth
Recommendation Usage
  • AISIN WASH & WAX should be used on normal temperature car surfaces
Suggested Equipment
SHOP NOW
Edited by e-Shop
AISIN INTERIOR CLEANER
Formulated cleaning agents by non-harmful solvents and natural ingredient with pH balance. With the special Micellar Liquid Technology, it effectively remove varieties of stains without wash off with water after use such as; grease, oil, wrinkle, dirt, marks, coffee, make up stain and etc.
Suitable For
Varieties of surfaces such as, vinyl, leather, carpet, upholstery fabric and plastics. Except for Alcantara
  1. Natural ingredients
  2. Micellar Liquid Removing Technology
  3. pH Balance and no harmful solvents
  4. Safe for all users
  5. Grease, wrinkles, dirt, marks and make up remover
  6. Easy to use without water and does not leave an oily stains
  7. Suitable for varieties of surfaces such as, vinyl, leather, carpet, upholstery fabric and plastics. Except for Alcantara
  8. Long-lasting protection for 2-3 weeks
Direction of Use
  1. Clean and dry surfaces before using
  2. Shake well before use
  3. Spray on sponge or clean cloth then wipe on surfaces
  4. Wipe off with clean and soft cloth
  5. Repeat again on dirty area
  • For the most effectiveness, it should be used on the dry surfaces.
Suggested Equipment
SHOP NOW
 AISIN CAR WAX
Formulated from Silica-modified film layer to deliver hydrophobic effect. It efficiently reduces the static electricity on the surfaces to repel water, dirt, dust, and other major contaminants. After applying, it creates a brilliant high gloss look and smooth surface. It does not leave wax stain that causes yellowish marks on the light-colored paint surfaces.
Safe for glass-coated surfaces and not damage to coating layer.
Suitable For
Car paints, glass-coated surfaces, headlights and trim.
  1. Hydrophobic Effect
  2. UV Protection
  3. Same coating material with Glass and Ceramic Coating
  4. Safe for glass-coated surfaces without damaging the coating layer
  5. Carnauba & Synthetic wax formulation
  6. Reduces the electrostatic on the surfaces
  7. Easy to use without leaving wax stain or yellowish marks
  8. Safe for car paints, headlights and trim
  9. Long-lasting protection 3-4 weeks
Direction of Use
  3. Spray AISIN CAR WAX onto paint surfaces
  • For the most effectively, should be used on the dry surfaces and normal temperature of surfaces
Suggested Equipment
SHOP NOW
 AISIN TYRE & TRIM COATING
Designed for long-last coating with water resistant onto surfaces with deep black look. It also restores and protects tires from fading and cracking against UV rays and other contaminants. By not leave black stain or causes black marks on surfaces or human skin.
Suitable For
Exterior rubber, trim and plastic surfaces
  2. UV Protection
  3. Enhance deep black look onto rubber and trim
  4. Restores and protects tyres from fading and cracking
  5. Water, mud and dust resistant
  6. Easy to use with long-lasting protection for 3-4 weeks
  7. Safe for car paints, rubber and plastic surfaces
  8. Removable once spray on other surfaces
Direction of Use
  3. Spray AISIN TYRE & TRIM COATING directly onto the surface or sponge
  4. Wipe over the entire surface with sponge
• Suitable for exterior parts only.
• For the most effectively, should be used on the dry surfaces and normal temperature of surfaces.
• Immediately remove once drop on other surfaces.
Suggested Equipment
SHOP NOW
 AISIN LEATHER CONDITIONER
Formulated from natural ingredients to restores natural shine, softness and new-look to leather surfaces. It prevents deterioration and cracking of surface and protects surfaces from damaging UV rays. It’s safe for human skin and surfaces. Moreover, it reduces the accumulation of stains and do not leave an oily feeling on the surface.
Suitable For
All kinds of leathers and interior plastic surfaces such as console. Except for Alcantara.
  1. Natural ingredients (Plant based oil)
  2. UV Protection
  3. Leather restorer and prevents deterioration, cracking and fading
  4. Long-last conditioning and restoring for 1-2 weeks
  5. Reduces the accumulation of stains on the surface
  6. Safe for all users
  7. Greasy free formulation without oily feeling
  8. Suitable for leather, vinyl and plastic surfaces such as console. Except for Alcantara
Direction of Use
  3. Spray on sponge or clean cloth and wipe on surfaces
Suggested Equipment
SHOP NOW
